08-09-2021, 08:35 PM | #1 |
Rep 7,514
Sous vide kit recommendations, please.
We have no place to put a grill at our house. At least not without having to walk through most of the house to get between the grill and the kitchen. But this past weekend I brought a couple of nice ribeyes to a friend's house and he grilled them to near perfection. Made me realize I'd like to eat steak more than the few times a year I get one at a restaurant.
Soooooo... I'm thinking sous vide. Seems easy enough and virtually fool proof (and I can be pretty foolish when it comes to cooking). But there seems to be a gazillion companies making the kits. I know there was a sous vide discussion here once and a few folks here use them, so I'm looking for recommendations for brands and any "gotcha's" to avoid. Money is not a big issue as they don't appear to be that pricey to begin with. Also, we have a large pot we could use, but are the sous vide containers (plastic?) better? Or doesn't it matter? And any advice about zip-lock bags vs vacuum wrap? Lastly, as I stated, no grill. Are sous vide steaks finished in a skillet just as good? We (sadly) have an electric stove, if that matters.
08-09-2021, 08:43 PM | #2 |
Rep 4,124
We have the Breville Joule. Works great with the WiFi/Bluetooth app on your phone. Large pot is required but you have that. As for bags, I use a simple ziplock bag, submerge to get the air out, seal and then I use a clip to hold the bag at the top of the pot. No need for vacuum bags in my opinion.
As for finishing, we do have a grill so a quick sear there is all we need. I know folks use a hot skillet on a cooktop as well but have no experience with that. Imagine a hot skillet with a little butter or oil would be excellent as well though good ventilation is a must!
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
08-09-2021, 09:08 PM | #3 | |
Rep 4,857
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
08-09-2021, 09:19 PM | #4 | |
Rep 7,514
08-10-2021, 06:26 AM | #7 | |
Rep 4,124
You do all you seasoning before putting the steaks in the bag. We stick to simple salt and pepper but any seasoning/marinade works.
2021 X3 M40i
08-10-2021, 06:42 AM | #8 |
Rep 3,024
I have been using the Anova WiFi and have been happy with both the unit and app. I would wait for an Anova sale before purchasing. The only negative for sous vide is the time it takes for some recipes that may require planning and starting the day before, e.g. 12 hour cook time requires getting up early or eating later.
Yes, the searing smoke detector thing is a PITA. For ribs, I use the broiler, which should work for the rib eyes too. For non-meats I sometimes don't bother searing. I use a Food Saver to seal bags which is a bit challenging w/liquids. Yes, bags can be expensive but can be thrown away instead of washing. Seems like some people like Stasher bags, I have used them and they do work. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 For the container the 12QT is a good size w/o being too small or too big... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This lid or one like it helps to keep the water from escaping. They make versions w/cutouts in the corner or end, depending on how the sous vide is mounted. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Anova has also introduced an insulated container, which I may buy in the future but for now I already have the pieces that I need for the frequency that I use it. https://anovaculinary.com/sous-vide-...ted-container/ Last edited by omasou; 08-10-2021 at 06:49 AM.. |
08-21-2021, 06:20 PM | #9 |
Rep 7,514
I ended up buying a Breville Joule. Works like a charm. I cooked ribeyes at 132F @ 1.5hrs tonight and they came out on the medium rare side of medium (or the medium side of medium rare). Next time I'll lower that to 130F. They were amazingly consistent throughout, though, which is the whole point of sous vide. The only prep I did was salt and pepper and then we seared in vegetable oil and butter. They tasted ok. But it was steak instead of STEAK, if you know what I mean. I had a ribeye about two weeks ago at a friend's house. He didn't do any prep other than salt and pepper, but he did them on a grill. Those were even more on the medium side than ours tonight, but they were also more flavorful. Could be a slightly different cut of beef or maybe that's the difference between grilling alone and sous vide.
Do any of you sous vide folks do marinade or other prep before bagging? Or before searing?
08-21-2021, 06:25 PM | #10 | |
Rep 43
Drives: M535,328i,328d,330i
M_Six18676.00 |
08-21-2021, 07:42 PM | #11 |
Rep 7,514
Some of the difference may have been due to a difference in marbling. The steaks at my friend's house were well marbled. Lots of white fat sections. The ones we had tonight had surprisingly little fat. Just some around the edges. I'll have to keep that in mind next time I shop for steaks.
08-21-2021, 08:01 PM | #12 |
Rep 4,124
I've always seared my steaks on the grill so not an expert at the cast iron pan method. But just thinking out loud, I would drop the oil and use the butter only, making sure the butter is seasoned/flavored with salt and pepper/herbs etc.
2021 X3 M40i
M_Six18676.00 |
08-21-2021, 08:56 PM | #13 |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
I've used the pan method a couple of times recently. I remove the steak from the refrigerator 45 minutes before cooking and used Tony Chachere's and a touch of pepper to season the steak. I placed butter the pan and heat it to the temp of the sun. On the last one I did 5 mins on the first side and 3-4 mins on the second side. I let the meat relax about 10 mins before serving. I serve on a hot buttered plate with 20 mg of Lipitor.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
M_Six18676.00 |
08-21-2021, 09:02 PM | #14 | |
Rep 7,514
MKSixer34102.00 |
08-22-2021, 06:13 AM | #15 | |
Rep 899
We are on the same page. I cook my red meats to 128 then sear to perfection!
MKSixer34102.00 |
08-22-2021, 07:37 AM | #16 | |
Rep 4,857
MKSixer34102.00 |
