08-23-2011, 10:03 PM | #1 |
Rep 743
Anyone fix pc's
So last night I was using my Dell laptop and was working fine. I shut off after a while and when I went to turn it on today it says on screen "primary hard drive not found". I took it geek squad and they said better to buy new one. Only bad thing is all my files are in my Dell. Can anyone try up fix this or should I give up?
08-23-2011, 10:44 PM | #2 |
Donkey Kong King
89
Rep 1,129
I guess the question would be did your hard drive crash/die, or did you have a bios failure.
My recommendation would be to remove the hard drive and try and find a way to read it (external hard drive adapter, etc). If its readable, you can transfer your data...if its crashed, then your out of luck.
[SIGPIC][/SIGPIC]
08-23-2011, 10:46 PM | #3 |
Rep 8
Sounds like your HDD is malfunctioning
How old is your Dell ? If you turn it facedown, can you see the HDD? If its an old PC you may well kiss your data goodbye. Very few people doe extract the info ,but at a 1000$$$ .
08-23-2011, 11:02 PM | #5 | |
Rep 407
Though, since it is 5 years old, trying to get any data off of it that you need and buying a new laptop would not be a bad idea. |
08-23-2011, 11:35 PM | #6 |
Rep 743
08-24-2011, 08:47 AM | #7 |
One cam is enough
130
Rep 6,801
Remove the hard drive from the laptop and get a 2.5" external enclosure with a USB interface. Then hook that up to another computer and if the hard drive cooperates, you'll be able to access everything on it.
08-24-2011, 09:46 AM | #8 |
Rep 158
Before you purchase your enclosure you need to find out if you hard drive is SATA or IDE.
SATA looks like this, and is found on the later Dell laptops: IDE looks like this, and is found on the older Dell laptops: Dell also used hard drive adapters for IDE drives which look like this: Be careful when removing the adapter as you do not want to bend the pins. Buy the enclosure to match the hard drive. Also, it wouldn't be too expensive to put in a new hard drive in and re-install windows so that you could sell it and recoup some money from it. |
08-24-2011, 10:45 AM | #11 | |
Careful, I Bite.....
153
Rep 504
Never saw an IDE drive that had that type of pins. All of the ones I've seen looked like this: |
08-24-2011, 11:09 AM | #12 | |
One cam is enough
130
Rep 6,801
Isn't your pic of a 3.5"? |
08-24-2011, 12:34 PM | #14 |
Rep 158
08-25-2011, 07:44 PM | #15 |
Rep 161
Drives: 2014 Z4 35is, Alpine White
IT Guy here.
Your hard drive probably crashed. Like what several others have suggest, getting an enclosure or a SATA/IDE to USB adapter is your best bet. I use the following product at work to retrieve data off of IDE and SATA drives http://www.newegg.com/Product/Produc...0usb%20adapter It's $20, not too much and it saves a bunch of headache. If your hard drive is completely FUBARed you're up the creek. However having one of those adapters/enclosures isn't a bad idea. Also, someone else said that the pins look different. The OPs hard drive is a laptop drive, the pins on a IDE are different from the 3.5" drives. And yes buying a new laptop is a good idea. Get your data, get a new laptop and also get an external drive to backup your data regularly. Did Geek Squad charge you for looking at the laptop? |
08-26-2011, 01:26 AM | #16 |
But your honour it's my Affluenza I swear!
58
Rep 533
Another IT guys here.
If there is no elemental damage to the actual disks which there shouldn't be (flood, fire, magnets) then a full recovery should be possible. I have heard of cases where computers get flood damage and a good amount of data is recovered by professionals. This sounds like a typical computer failure, might be the HDD, might be the bios/motherboard. I wouldnt consider your data lost so dont stress.
135i M Sport DCT. BSM/Oyster/GP trim. FBO Cobb, Bilstein EDC coilovers, M3 bushings, PSS.
Knowledge of the Tapa Tapa Tapa street race start. |
08-26-2011, 10:39 AM | #17 | |
d[-_-]b
484
Rep 968
08-26-2011, 06:48 PM | #18 |
Rep 161
08-26-2011, 07:13 PM | #19 | ||
Crazy Russian Bastard
30
Rep 819
B
M W |
08-26-2011, 09:38 PM | #20 |
d[-_-]b
484
Rep 968
A lot of money can vary from person to person, a good friend of mine does forensic IT work for the govt and his last on the side job was 600$ for 400gigs of data off of a crashed drive for a mutual friend. Ive never personally had a drive crash on me so I don't know other prices but that's more than I would want to spend.
08-26-2011, 09:41 PM | #21 |
d[-_-]b
484
Rep 968
08-26-2011, 11:08 PM | #22 |
30
Rep 819
Thanks for sharing.
B
M W |
