Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board
      01-31-2017, 12:42 PM   #1
ScottSinger
Drives: M235i 6spd
Tile and grout sealant ?
Which product (who makes) the best sealant for bathroom grout and tile ?
      01-31-2017, 12:56 PM   #2
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
Aqua mix is good stuff.
But remember this is similar to waxing a car. It wears off and you will have to continually re-seal it to get continued protection.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      01-31-2017, 12:59 PM   #3
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [2.63]
We used Mapei.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
Mr Tonka5846.00
Aatish3332.00
      01-31-2017, 01:03 PM   #4
Needbmwpartzz
Needbmwpartzz's Avatar
780
Drives: 2009 bmw 328i x-drive
Originally Posted by KingOfJericho View Post
We used Mapei.
Mr Tonka5846.00
      01-31-2017, 03:49 PM   #5
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Agree on both using Aqua Mix and having to continue to redo it occasionally, for our shower area I do it every couple of years.
For porcelain tile the sealer won't make much of any difference and you can stick to the grout.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
Mr Tonka5846.00
      01-31-2017, 03:54 PM   #6
IndotagSwizz
IndotagSwizz's Avatar
404
Drives: F30 320i
Try 511 impregnator sealer, I own a Marble & Granite shop and have worked on all kinds of styles of tiles and stones, in my opinion nothing comes close, this is an impregnator sealer meaning its very thin and penetrates the surface by getting inside instead of being a surface sealer, this means you will not have to constantly re-seal because it will not wear out, good luck
Mr Tonka5846.00
      01-31-2017, 04:22 PM   #7
Mr Tonka
Mr Tonka's Avatar
Correct, it is useless to seal any glazed floor tile.
If the tile is unglazed porcelain or ceramic, a sealer will do some work. But an impregnator as mentioned above is best for tile applications.
I've heard from suppliers that it's best to just use a grout sealer for sanded grout because it's so porous. The impregnator is much smaller on a molecular level which allows it to impregnate even granite. Because the grout is so porous and impregnators are such a fine liquid, it doesn't seal the grout enough to keep the dirt out.
Best way to keep standard grout looking clean is to not mop the floor. Mopping just pushes the dirt around on the floors and guess where the dirty water settles, the low spots. Guess where the low spots are, the grout lines.
Best performance, upgrade your grout to a urethane based grout. Urethane is non-porous and won't allow dirt to get in the grout. Or you can just put down normal sanded grout and paint it with epoxy grout paint. The application of epoxy grout paint and grout sealer is the same, but the epoxy paint application will last much, much longer.
-Resident BP flooring store owner, 25yrs in. lol
Edit: Mapei makes good products as well.
RickFLM43929.00
wrickem1229.50
      01-31-2017, 04:49 PM   #8
ScottSinger
Drives: M235i 6spd
Wow, thanks all for the great info.
This is for verticle shower walls and will only do the grout itself, my tiles are smooth and seem impenetrable.
      01-31-2017, 05:00 PM   #9
Patrick303
Patrick303's Avatar
Drives: you crazy
Send a message via MSN to Patrick303
+1 I use this to clean/protect my granite counters and to seal the grout on my tile floors.
2017 440i xDrive Gran Coupe M Sport
2013 Audi A6 3.0T Prestige - stage II
2010 Range Rover Sport Autobiography - sold
2008 335xi Coupe - sold
      01-31-2017, 05:16 PM   #10
Mr Tonka
Mr Tonka's Avatar
Pretty much like this?
If so, i'm assuming you're using unsanded grout. If not, you need to. Any grout sealer will do fine. You have little to worry about with that application.
Best practice for a shower like that is to leave it open so it can air out as best as possible after each use. If i don't leave my shower door open after each shower, the mildew will creep in quick. Pain in the ass to get rid of. But as long as i keep the door open, it dries out too quickly for the mildew to catch hold.
      01-31-2017, 05:18 PM   #11
ScottSinger
Drives: M235i 6spd
Actually I used sanded grout - I just did the bottom perimeter between the bottom tile and shower pan - the gap was more then 1/8 inch.
You might be able to see what I'm describing in this picture below
      01-31-2017, 11:10 PM   #12
Mr Tonka
Mr Tonka's Avatar
So the walls are prefabbed panels butting up to a prefabbed shower pan and you just filled in the gap between them, where they butt together?
      01-31-2017, 11:15 PM   #13
roastbeef
roastbeef's Avatar
Drives: E92 M3
get a self-sealing grout. 100% worth it.
Instagram; @roastbeefmike
      02-01-2017, 04:56 AM   #14
ScottSinger
Drives: M235i 6spd
No the walls are real tile grouted have the orange Schluter system for moisture barrier behind the tile - just that with usage the acrylic pan settled a little leaving a cracking or gap in a few places of the grout. So I cleaned with a grout knife just the juncture on the three walls and shower pan - tonight will be 72 hours since completed the grout and want to add the sealant.
      02-01-2017, 08:59 AM   #15
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Regardless of sealant you use you have to clean and seal every year
      02-01-2017, 12:45 PM   #16
Mr Tonka
Mr Tonka's Avatar
Ok, any of the mentioned sealers will do fine for that application. I'm sure Aqua Mix and Mapei both have youtube channels should you want some more in-depth instruction on how to apply.
      02-01-2017, 12:57 PM   #17
ScottSinger
Drives: M235i 6spd
Thanks all, will seal it this evening.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
