03-19-2007, 06:57 PM | #1 |
Rep 605
site for oem Honda parts?
I'm looking for a good site that sells honda parts. I need to replace the brakes of a '02 Accord. Also how hard is it to replace the brakes yourself? Is this something that could be figured out by reverse engineering? Are there any special tools I'll need? Will I have to bleed the brake lines?
There are two things wrong with the car at the moment and I'm not sure if they're inter-related: 1) The brakes squeal when I brake... I assume the pad is just worn out. 2) Sometimes in cold weather, the brake light (the one that indicates the parking brake is set) remains on even after I released the parking brake. It'll remain on for a few minutes/miles then go off by itself. Any advice would be appreciated.
Mods: blacklines, sunglass tray holder w/ led mod, clear bra, 30% tint, rear outlet plugs, LUX 3.0, McCulloch 6000k HIDs
03-19-2007, 07:05 PM | #2 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
03-22-2007, 03:46 PM | #4 |
Rep 319
https://www.hondaautomotiveparts.com or
http://www.slhondaparts.com/ Changing brakes is a easy job. I'm not good at describing steps so i'll just refer you to http://www.v6performance.net Its a large honda accord forum. |
03-22-2007, 03:58 PM | #5 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
I've used hondaautomotiveparts.com on 3 ocassions, I don't have a problem with them although shipping could be cheaper.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
03-22-2007, 03:58 PM | #6 |
Rep 163
Are you replacing the pads or the calipers?
You don't really need any special tools. There is one to press out the pistons on the caliper but you can just use a rubber mallet or a c-clamp (what I did) instead. Pretty simple job. You'll have to bleed them if you remove the brake lines which will make pushing the pistons out a lot easier.
"You're going to have your heart broken, and you're gonna repair it with zipties." |
