      03-14-2016, 12:14 PM   #1
Axius
Seychelles
4202
Drives: 612 Scaglietti
Help me purchase a wheel lock key adapter
I lost my wheel key when I drove away for a test drive. Shut up. Don't want to hear it.
So the box to my normal studs has the numbers "36 13 6 764 057". This leads me to believe that I have a 36 series 17mm stud, can someone confirm this for me?
I attached a snapshot from realoem listing all the adapter codes and I don't see how it could be anything other than 36 since none of the other numbers match up.
Thanks for any assistance!
      03-14-2016, 12:15 PM   #2
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
This one should keep it safe.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      03-14-2016, 12:19 PM   #3
Axius
Seychelles
4202
You're not helping you dinkus!
      03-14-2016, 12:51 PM   #4
jwzimm
jwzimm's Avatar
Drives: '16 M3
Note that ALL of the P/N's you can see in your realoem snap start with "36". That is the base part number for the wheel locks. It is not the code.
Edit: I just searched on Google for your P/N (36 13 6 764 057). You have the old style wheel locks. You will need to look through the documents in the box the locks came from to find the code card.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      03-14-2016, 12:55 PM   #5
Axius
Seychelles
4202
Originally Posted by jwzimm View Post
Note that ALL of the P/N's you can see in your realoem snap start with "36". That is the base part number for the wheel locks. It is not the code. Which type of wheel lock do you have? Is it the McGard type with a squiggle in the center of the bolt or is it the old BMW style with a kind of star pattern with a center pin? If it is the old BMW style there is only one key. If it the McGard one you will need to find the correct code.
Thanks, definitely didn't notice that.
It basically looks like a spline gear. The center of the stud is has a 20 some tooth fine-ish spline, and the adapter has the matching spline teeth. BMW stealership said I should have a card somewhere that denotes the code, but I'll have to check manuals and stuff to find the card.
      03-14-2016, 02:27 PM   #6
Mr Tonka
Mr Tonka's Avatar
What's the code?
      03-14-2016, 03:05 PM   #7
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Honestly wheel locks don't work.
Hammer a slightly smaller sized socket onto the lock and use an impact driver. Lock defeated.
Trust me, I know.
      03-14-2016, 03:09 PM   #8
overcoil
Drives: M235i 6spd
Not that I would bang a socket on to a mounted lug, but either Jalopnik or Autoblog in the past few weeks had a video entry on how to socket the lock of the stud.
http://thegarage.jalopnik.com/how-to...key-1759207243
      03-14-2016, 03:42 PM   #9
Axius
Seychelles
4202
Originally Posted by Mr Tonka View Post
What's the code?
37 is mine. Card inside the stud box.
Trust me, I know.
I'm just going to buy a new lock key and swap them out with regular lugs that are in the trunk. Should have done it before, but hindsight is 75/75.
      03-14-2016, 04:08 PM   #10
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Put it on cinder blocks at night. Confuse em.
      03-14-2016, 04:18 PM   #11
Axius
Seychelles
4202
Found one online, $16 shipped from ECS. Should be here in 3 days.
Now just wait for another thread when I do it all over again.
      03-14-2016, 04:30 PM   #12
Mr Tonka
Mr Tonka's Avatar
Sweet, they said mine would be here in 2 days. One day to drive up there... gonna be tight.
      03-14-2016, 04:31 PM   #13
Mywifes335
Mywifes335's Avatar
Increases property value too!
      03-14-2016, 04:32 PM   #14
Mywifes335
Mywifes335's Avatar
Cool, in the meantime gonna jack your wheels. Lol!
      03-14-2016, 04:33 PM   #15
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
So, why did you lose it when you went for a test drive?
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      03-14-2016, 04:36 PM   #16
Mr Tonka
Mr Tonka's Avatar
THIS is a good question. Ask him how he lost the first one too.
      03-14-2016, 04:40 PM   #17
Axius
Seychelles
4202
Pretty sure if someone steals my wheels, my insurance company is going to drop me when I make a claim.
Do it pussy! I dare ya!
First one I left on the stud after tightening down and drove off. This time, my neighbor commented on me leaving it on there and how it'd suck, so I know for a fact that I took it off, I just have no idea where I put the damn thing.
      03-14-2016, 05:58 PM   #18
1LRM3
1LRM3's Avatar
Drives: LRP M3 E92, MR M3 E93
2013 BMW M3  [8.00]
Not permitted to repeat without unsolicited flaming. Glad you finally found one. Keep it in plastic like your other socket.
ENDLESS DETAILS, CT
EPIC MOTORSPORTS, FL
Custom Auto Designs Protection Films, CT
F.T.B.R. Garage, CT
      03-14-2016, 06:00 PM   #19
1LRM3
1LRM3's Avatar
2013 BMW M3  [8.00]
So..... Seems to be a common theme. :
ENDLESS DETAILS, CT
F.T.B.R. Garage, CT
      03-14-2016, 06:38 PM   #20
atinybug
Drives: 07 e92 335i 6mt
I lost my wheel lock a while back and I ended up going to the dealer to get it replaced. They have this little box with all the different wheel locks that ever came on any BMW built to see which one would fit. They didn't have an extra of mine in stock so I had to order it. Ended up costing me $15 and it arrived 2 days later.
      03-14-2016, 07:57 PM   #21
Axius
Seychelles
4202
Poor life choices equal poor memory function.
      03-14-2016, 08:57 PM   #22
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3583
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Did you find your answer OP?
My delivery experience and beach photoshoot here.
