BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions replace engine air filter g30 m550ix
      06-19-2023, 01:35 PM   #1
bryansna
Drives: 2020 bmw m550ix
Howdy all. Ordered new engine air filters and when I got started to try and remove the current, I couldn't get the air box off. Looks like a brace is right at the attachment for the air box and hose assembly. Do I need to remove the brace to get the filter out? Thanks in advance
      06-19-2023, 03:48 PM   #2
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
2018 BMW M550i  [0.00]
You don’t have to, you can loosen it and cover will lift enough to slide new filters in. You can remove it to make it easier I suppose. Just a standard hose clamp.
      06-19-2023, 10:15 PM   #3
WretchedRefuse
Drives: 2020 BMW M550i
Assuming here we're talking about a 2020+ engine. You can change the filter without removing the air box, but if you don't remove it you won't be able to vacuum out any debris trapped in the box.
      10-12-2023, 10:37 AM   #4
oldtexasdog
Drives: 2020 M550I X Drive
So on the 2020 M550 you will need to remove the brace if you want to remove the air box for vacuumed cleaning? Can you re-use the plastic trim buttons or should I get some new ones or can I get that bolt out on the front of the brace by just lifting the trim cover slightly?
      10-12-2023, 10:41 AM   #5
bryansna
Yeah, I found out that you have to remove the braces and then it is free to replace. I didn't have to replace any clips or anything
      10-12-2023, 10:44 AM   #6
oldtexasdog
So it is necessary to remove the brace over the top of the air box if you want to vacuum out any debris? Can I just lift the trim flap that covers the bolt on the front of the braces or will I need to remove and replace the trim buttons that holds it down? Looks like I am going to have to get a Torx socket for the back bolt on the brace?
Thanx!!
