06-05-2013, 08:19 PM | #1 |
Rep 243
How to keep tools from rusting
I dont turn wrenches anymore so my tools and box are in the garage and ive noticed some surface rust on some of them. I have thousands of dollars in tools and hate to see them get rusty. Does anyone know of any tricks to keep rust from forming. I know people say just use them or WD 40 but i dont want my tools being greasy.
06-05-2013, 08:32 PM | #3 |
is probably out riding.
6058
Rep 2,292
keep a bag of desiccant in the drawers.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
06-10-2013, 03:21 PM | #5 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
you can use lemon juice to remove most rust
I did that on the tool set in my E30, they look brand new I soak them for 1-2 hours, depending on how rusty they are and before I take them out I heat up the toaster I take them out, wash them with soap and water then put them in the pre-heated toaster that way any remaining moisture evaporates.
06-10-2013, 03:53 PM | #6 |
Rep 1,268
All I can say is cheap tools,
My tools are over 20 yrs older they been in my garage the entire time and non of them have rust on them, but all my tools are either Craftsman or Snap-on. My garage is not climate controlled either so it open to the all the weather changes and I live in a humid area as well. |
06-10-2013, 04:03 PM | #7 |
Rep 715
I wouldn't exactly say cheap tools, as much as normal tear-and-wear and the layer of paint, plastic (or whatever depending on your tool) that is used to prevent rusting has worn out due to prolonged usage.
Example, my jack stands. They are subject to friction from the car and the concrete (since I just leave them on the ground and they sometimes get dragged around), removing the paint on them. Add in water, and they will rust. |
06-10-2013, 04:26 PM | #8 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Buy a dehumidifier. It is what people use to store firearms in safes and such for prolonged periods of time. Pretty much anything that soaks up moisture should work.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
06-10-2013, 05:11 PM | #10 | |
6058
Rep 2,292
06-10-2013, 05:32 PM | #11 |
Knower of all Things Useless
29
Rep 254
As do I, much of it has to do with the amount of use as well as how they were used.
I actually have used plastidip for what it was originally intended for and dipped most of the socket wrenches and other things like that to help, but there is surface rust on a lot of my more commonly used sockets. |
06-10-2013, 07:36 PM | #12 | |
Rep 243
06-11-2013, 11:14 AM | #16 |
Rep 1,268
Do you clean your tools with any solvents, that is my other guess, again i use mine lots over the 20 yrs and do not have what you are showing. however, I do not clean my tools with solvents, I just wipe them with a rag. Old time mechanic told me once never clean tools with solvents, the oil you get on them from working on cars protects them, solvents removed all the oils from the steel which allows it to rust.
The same is true for good Knives and Fry Pan, never clean them with soap and water, Wiping them with hot water and scrubby and towel them off is the best you can do so the oils stay in the metal. I know it drives my wife nuts when I refuse to clean my knives and pans in dishwasher or soapy water. Last edited by Maestro; 06-11-2013 at 04:37 PM.. |
06-11-2013, 12:25 PM | #17 |
Rep 700
I have 99% MAC tools. I've beat the heck out of some of my wrenches and ratchets trying to break stubborn hardware loose ruining the finish of the tools in the process.. Anyway I've had these tools for about 7yrs and and have gone months without cleaning them etc and none of them show rust.
On the other hand I have a "metrinch" tool set I've had since I was in high school that is pretty rusty; they still work well they are just ugly. |
06-11-2013, 04:29 PM | #18 | |
AC
95
Rep 2,387
oil is your friend. you can't have the cake and eat it too, the oil will protect your tools from oxidizing.
Your Supreme Leader
06-11-2013, 07:31 PM | #19 |
6058
Rep 2,292
Desiccant comes in different size bags. It's reusable by setting it in the oven to dry it out again. The different size bags are good for different size spaces.
Get a small bag for each drawer, recharge every 2 to 3 months. Remove the rust first and this should keep the moisture causing rust out of the box. The other method requiring less effort is to give your tools a light spray of WD40 before putting them away. "Water Displacement 40th formula". No water, no rust.
06-11-2013, 09:10 PM | #20 | |
Rep 243
06-11-2013, 09:11 PM | #21 | |
Rep 243
Thanks for all of the input guys |
06-12-2013, 07:59 AM | #22 |
Rep 1,268
Are you near the ocean, it could be the salt air, when I lived in CA I had friend near the ocean and he was mechanic it was next to impossible to keep tools from rusting, like like yours looks, they had this brownish white sheen over them.
