03-18-2020, 09:00 AM | #1 |
Rep 6,030
Thermostat recommendations?
So this thermostat has been giving me some issues since I don't have a c wire. Thought I'd upgrade a couple years ago but knew there might be some caveats vs just sticking with a dumb thermostat. About to switch back but won't be going back to the old mercury thermostat something a little newer maybe but not necessarily with any smart features or WiFi. Any recommendations?
03-18-2020, 09:04 AM | #2 |
Rep 885
I used some of these tutorials and found them helpful.
https://www.youtube.com/watch?time_c...ature=emb_logo |
03-18-2020, 10:21 AM | #3 |
Rep 3,033
I am looking for a dumb thermostat too because i think having google spying in your house is insane. Looking for one with a nice big screen but they all seem to be smart ones which is annoying.
03-18-2020, 11:01 AM | #5 | |
Rep 2,250
I changed mine awhile back.
Everybody has a gameplan....until they get punched in the mouth.
03-18-2020, 12:28 PM | #6 | |
Rep 242
Or you can simply replace the Nest. They have super super slick software, but as an actual thermostat they don't regulate temperature as good as a honeywell (or even carrier). Unless you are married to the nest ecosystem there are better thermostats (ecobee comes to mind). Seth Last edited by sethwas; 03-18-2020 at 03:40 PM.. |
03-20-2020, 02:17 AM | #7 |
Rep 2,243
Drives: 2007 328i / 2014 M235i
Return it and buy an ecobee, it takes power from the furnace so no battery to worry about
vreihen1615402.50 MaC-N54-E82473.00 |
03-20-2020, 08:15 AM | #9 |
Rep 1,419
I can attest, the Ecobee is pretty awesome.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
vreihen1615402.50 |
03-20-2020, 08:35 AM | #10 |
Rep 6,030
I was told if you don't have a c wire the eco bee won't work though there is an ac adapter for it to plug into a wall outlet. The nest gets around this by attempting to get power from one of the other wires. I was able to charge up my nest using a cell phone charger as it has a USB port in the back. If they had a way to route the cable to plug it into an AC outlet while montes to the wall that would work too. Maybe the dial could be narrower to allow a space to run the USB cable. After charging it it's made it through the night so the micro charge it gets from the rh wire should sustain it for a few months hopefully before needing another charge.
03-21-2020, 07:00 AM | #11 |
Rep 1,004
We have Honeywell thermostats but they are both smart. I like being able to control them from the couch or out of town (if I ever go out of town again). What I learned putting them in two houses over time is that the type of system you have might not be compatible with all t-stats. A geothermal heat pump has fewer t-stat options than a regular gas furnace, for example. So be sure to either get a truly universal t-stat (esp if you’re likely to replace the equipment soon), or one that you’re sure works with your equipment.
03-21-2020, 10:04 AM | #12 |
dances with roads
4737
Rep 4,099
I have a "sorta smart" thermostat. It's programmable but not connected to teh interwebz. Does everything I need done and nothing that I don't.
03-21-2020, 10:22 AM | #13 |
Rep 1,555
for 24v thermostat I've tested few. My 3 first pick 1- Venstar T8000 series 2- Ecobee 3 3- Nest last gen I really like venstar because of the 'unlimited', option. For more advanced user. Ecobee is a great balance. Nest just dont et enough setting for my taste, its a dummy user thermostat. It was perfect for my gran ma tho. |
03-21-2020, 10:34 AM | #14 |
Rep 3,241
Another Honeywell user/owner here. So far it does everything I need and has worked reliably. I have it in my vacation home and use it to pre-condition the house before I get there. It also saved my bacon a couple of times when the furnace malfunctioned during a winter where we were having long record cold temps. I got alerts that the interior temp was way below the set temp on the thermostat.
It also helped me get some money back from my ISP as I had records that there were extended outages that were on their end because I was getting email notifications the cloud server was not getting any communications from the thermostat. |
03-23-2020, 11:16 AM | #15 | |
Rep 170
03-29-2020, 05:08 PM | #16 |
Rep 5,538
Nest has been Ok, had to pay extra for remote temp sensors. I'd try Ecobee (comes with free remote sensors) but it's not 100% compatible with my system.
I really like when I walk close to thermostat it automatically displays current temp and gives hourly changes, very useful. Dont know if Ecobee does that |
03-29-2020, 06:15 PM | #17 | |
Rep 6,030
