03-07-2019, 12:27 PM | #507 | |
Rep 2,250
Let's take squats. I would basically do the same weights over an over. 135 x 8-10 (warm up) 185 x 6-8 (warm up) 225 x 8 275 x 8 315 x 6 365 x 6 The drop to 225 again and spend each workout just trying to beat the previous week's reps. Of course weight is relative, but when you can take 100lbs or more off the bar, you can rep out like crazy. Just get into a "grove" with a piston like movement....and grind them out. You will find that your endurance goes up a lot faster than continually pushing for heavier weights. Years ago I squatted much heavier with a belt and knee wraps. Never used knee wraps until I was using 4 plates. When I started using wraps, my weight that I was using exploded. Honestly....I found that they were more of a "Crutch" than anything, and inflating my lift as much as they were probably helping keep things safe. Figured that if I couldn't do that weight without the wraps, then I was using more weight than I really needed to and tempting fate. So for the last few years I had just stayed around 315 and just hitting reps. Not really trying to progress as I am built bottom heavy. My legs grow way faster than my upper body. Also I am short, so I don't have nowhere near the range of motion you guys have to go through to hit ATG. Couple that with being a natural low bar squat guy...I'm at the bottom while you guys are probably still about midway down. It's the only time I think where my height gives an advantage...oh and also when you are short...everything looks bigger!
Everybody has a gameplan....until they get punched in the mouth.
03-07-2019, 12:42 PM | #508 |
Rep 2,250
Sent you a PM.
03-07-2019, 02:06 PM | #510 | |
Rep 431
Now, I just do two warm up sets, and two working sets. For instance today I am doing back. So, my first exercise today will be wide-grip pullups (3x7-8). From there I go straight to deadlifts and do two warm up sets (2x10), and then will most likely jump to 255 lb for two sets of 10. From there I go to lat pulldowns (3x10x120 lb), and my last exercise will be cable rows (3x10 of 140 lb). Since it is a back day I throw in some bicep exercises for good measure. What do you think? |
03-07-2019, 02:24 PM | #511 | |
Rep 2,250
It's best to catch the morning part as that is the mandatory stuff. At night..... They get a little stupid as it's the free posing part and some people kind of take it to the extreme. |
03-07-2019, 02:31 PM | #512 | |
Rep 2,250
Just be careful with form on deadlift as your back is already pre-fatigued. I've done it both ways.....its good to switch things up now and then. Going into a meeting, but will reply to your PM soon! |
03-07-2019, 02:52 PM | #513 |
11817
Rep 23,187
Thanks man. Thought that would be hard number to hit but apparently not. First try did 2 sets of 20. Was surprised by the 17 on bench also. I'm going round about way to get 1rm but big numbers coming someday here. Dealing with my foot and working on revamping my setup.
harris6964.00 |
03-07-2019, 03:33 PM | #514 | |
Rep 2,250
03-07-2019, 04:45 PM | #516 | |
Rep 2,250
Bench and squat are great....but I don't hit a lot of higer rep deadlifts as I feel my form suffers too much as I fatigue. So I'm afraid of injury as that is the only exercise that I'm still a little uncomfortable with even after years of working it. I feel like there is always come way I can improve my technique. I like back-off sets as those weeks of hitting only 3 reps doesn't give you a lot of a pump feeling. I'm tired when I leave the gym, but I always try to finish a body part off with a pump set to get as much blood into the muscle. Mentally I feel better, and I think it helps with recovery flushing the muscle with blood. I've been toying around with the blood flow restriction bands as well over the last few months. I won't lie as it hurts, but it leaves your muscles so engorged and veins come out everywhere. I've used it quite a few times with arms, but only once with legs. My legs were sore for almost a week after. |
03-07-2019, 05:03 PM | #517 |
11817
Rep 23,187
Yeah I never do high reps on dead either. Did some 15 s today and even that fired up my back too much. I basically do pyramid and then make big jump and RIP off a single.
03-07-2019, 07:13 PM | #519 | |
Rep 1,149
2 set PR....455 for 3. Most I’ve done in working sets Very pleased, I think 500 is within reach. Possibly on my next retest. |
03-07-2019, 07:18 PM | #521 |
Rep 1,149
03-07-2019, 07:26 PM | #523 |
Rep 1,149
03-07-2019, 07:42 PM | #525 | |
Rep 1,149
#1200Club |
03-07-2019, 07:46 PM | #526 | |
Rep 431
03-07-2019, 07:50 PM | #528 |
Rep 1,149
