E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > FS: PAC RP4.2-BM21 Wiring Interface
      06-23-2022, 09:42 PM   #1
K9Leader
K9Leader's Avatar
1055
Drives: 2010 328ix E91, 2011 128i E82
2011 BMW 128i  [10.00]
2010 BMW 328i  [10.00]
Sold
Shipping Costs Included
Connect a new car stereo and retain steering wheel controls and warning chimes in select 2006-2015 BMW vehicles
Radio Replacement Interface (for BMW): The PAC RP4.2-BM21 interface allows the replacement of a factory radio in select BMW vehicles. Using this interface will retain factory features such as: steering wheel controls (SWC), iDrive controls and warning chimes (including rear park assist and front collision detection). The RP4.2-BM21 also provides data bus driven outputs such as data driven accessory power, vehicle speed signal (VSS), illumination, reverse, and parking brake.
Compatible with:
  • 1 Series - 2011-2013
  • 3 Series - 2006-2015 (except 2006 coupe)
  • 5 Series/M5 - 2010-2014
  • 6 Series - 2011-2014
Notes:
  • Incompatible with vehicles equipped with the upper display screen above radio (CCC or CIC systems). This screen is not retained if the factory radio is removed, and you will lose the ability to adjust some vehicle settings. Radio replacement is not recommended for those applications.
  • Does not retain factory amplifiers equipped with Fiber-optic input.
  • BMW 1 Series vehicles equipped with navigation are not compatible.
  • 2006 BMW 3 Series coupe is not compatible.
  • Hardwired +12V Constant Lead: BMW's power management system causes the constant power wire behind the radio to drop out after the key has been removed for 30 minutes. It may be necessary to run a new 12v constant wire from the battery (located in the trunk) to the aftermarket radio.
Used for eight months for a JVC aftermarket head unit in a 2011 128i. I have now installed an Android head unit so no longer need this. Worked great - simple plug and play and maintained all steering wheel controls.
Included in this sale:
  • PAC RP4.2-BM21 Wiring Interface and wiring harness
  • Auxiliary speaker (mounts in lower dash driver side kick panel - used for warning chimes)
  • Printed installation/owner's manual (also widely available online as a .pdf)
Does not include the 12v power wire so you will need to obtain about 15 feet of power wire. I will include an inline fuse holder. (The one that came with kit is still installed in vehicle - using it for power for the new unit.)
Also, there was a small mounting bracket for the auxiliary speaker but I didn't use it and now cannot find it. There is a spot in the lower knee panel specifically for mounting this speaker.
K9Leader
2010 328i x-Drive, E91 - Space Gray/Black
2011 128i E82 6MT - Crimson Red/Black
      10-16-2023, 05:15 PM   #2
Sivy75
Drives: 2009 BWM 328i / 1978 VW Westy
Is there any chance you still have this?
      11-25-2023, 01:43 PM   #3
andydeuninck
andydeuninck's Avatar
Drives: BMW 330i
Do you have this unit for sale today
PAC Audio BMW RadioPro Replacement Interface - RP4-2BM21
Looking for this unit to install on Sun Dec 3rd.
Please contact andydeuninck@gmail.com
e90post
