      01-13-2017, 04:46 PM   #23
WDE82
Drives: 2018 440iGC F36
I GOT IT on my 128i no nav! It's quite simple. Everyone always only mentions FA_write to the CAS. But you must also go to FRM and NFRM to remove $2VB from the VO. I pressed delete 3 total times in the VO menus. Once in CAS, once in FRM, once in NFRM. Then you do FA_write.
Remove fuse 27 (TPMS fuse)
Using E89 chassis in NCS.
You must remove $2VB from CAS, FRM, and NFRM using NCSExpert under the FA/VO menu. Then you must FA_write to CAS and NFRM. This is the key part nobody mentions. You have to change the VO in all locations that exist.
Then sg_codieren to DSC and KOMBI. May have to add CAPPL/CIC for Nav but I don't have it so I'm not sure.
My light is gone. Next I will try to activate the Euro style FTM.
Note: you will lose your time and date settings and your ABS/DSC error warning will appear for a moment. Don't panic.
Dackelone10588.50
      01-13-2017, 04:51 PM   #24
ianc
Ex '87 Carrera
ianc's Avatar
Drives: '10 TiAg 6MT 135i
Great news!
So your car is just a 135i without idrive? What year? I also don't have idrive...
Will be interested to see what it takes to get the FTM to show up and calibrate correctly for a non idrive car.
The other X3 post I found is here: http://www.bimmerfest.com/forums/sho...d.php?t=856574
ianc
Edited to say: Looks like RDC is actually the German abbr. for TPMS now that I take another look at that last link? Reifen Druck somethingorother?
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA
      01-13-2017, 04:55 PM   #25
WDE82
Originally Posted by ianc View Post
Great news!
ianc
I have a '13 128i without Nav. It should be almost identical for you.
I forgot to mention that I used the E89 chassis in NCS Expert.
I am following some guy who had success on the E84 to see if I can activate the euro style FTM. I think it'll probably work. He used E89 chassis for the coding and was successful but he had nav. Seems to me that just makes less work since it's one less module to code.
edit: I clicked the link. Yeah that's the guy I am looking at. Looks fairly simple tbh.
      01-13-2017, 04:59 PM   #26
ianc
Ex '87 Carrera
ianc's Avatar
As a hypothetical question, if you removed $2VB and added $265 to the VO, then set NCSExpert to 'process whole car', wouldn't it make all the necessary changes to the various modules that required it?
ianc
      01-13-2017, 05:09 PM   #27
WDE82
I am not sure. I am still a novice NCS Expert user. I would probably stay away from such functions and individually code the bare minimum modules. Who knows what messing with ALL of them under the E89 chassis could do. I've no idea.
      01-16-2017, 07:55 PM   #28
ianc
Ex '87 Carrera
ianc's Avatar
Any updates? Very interested in your results...
ianc
      01-18-2017, 08:50 AM   #29
WDE82
ianc
I haven't gotten around to trying it yet. I'm a little confused by some phrasing in the X1 instructions so I've asked another user who had success to clarify. I will probably have it done this week. I will certainly come back and post here to let you know!
      03-06-2017, 12:25 PM   #30
geeyore
geeyore's Avatar
Drives: 2011 135i 6MT
Cheapskate solution: ignore it.
2011 135i 6MT, Cobb FMIC, Stoptech ST-60, Pagid RS-29, Castrol SRF, Goodridge G-Stop, Apex EC-7, Dinan Front Sway, Ohlins R&T, Swift 400/500, Vorshlag Camber, M3 lowers & bits, Diffsonline 3.08 3-clutch, Sparco Ergo/Evo, Schroth Hybrid, RRT welded 4-point hoop
DD: BMW 328xiT Prior: 2000 323iT 5MT, 2000 Z3 2.3 5MT, 2001 325iT 5MT, 2009 128i 6MT
      03-19-2017, 07:48 PM   #31
ianc
Ex '87 Carrera
ianc's Avatar
Had a fellow who runs a small coding business for BMW's locally (sf bmw coding . com) use his hardware ICOM B interface to code my MOST radio yesterday. He said just physically unplug the TPMS module, remove $2VB from the VO, and default code DSC, KOMBI, and NFRM to disable TPMS and enable FTM. Haven't tried it yet but will soon...
ianc
Dackelone10588.50
      03-21-2017, 01:03 PM   #32
optigrab
More Boost?
optigrab's Avatar
Drives: 08 135i MSport 6AT
Good to know! may choose to code mine off when they die
      03-31-2017, 10:30 AM   #33
blisstik
blisstik's Avatar
Drives: E92
This is gold! Thank you!
The fuse for my E92 335i non-iDrive was 13 and 28. I pulled both and my Homelink stopped working since 28 was shared with it. I put fuse 28 back in and left 13 out. And it worked!
While in there, I also pulled 25 to disable to Seatbelt Arm.
      03-31-2017, 10:42 AM   #34
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
RDC is the German abbreviation for the Flat Tire Monitor (the TPMS alternative).
Reifen something something or other?
ianc
Yeah... RDC = Reifendruckkontrolle
reifen = tire
druck = pressure
Kontrolle = control
IDK why the Germans don't say RDK. lol
The EU RDC uses the car's ABS sensors to detect a flat tire. It works very well in real life conditions. We got stuck with the TPMS crap bc of Firestone/Explorer controversy & Congress.
Dack
      03-31-2017, 10:54 AM   #35
ianc
Ex '87 Carrera
ianc's Avatar
Interesting. My 2010 US 135 does not have FRM, only NFRM, so the VO is stored in two places for me.
I think instead of pulling fuses, I would prefer to actually remove the TPMS module itself; simplify things and perhaps save a pound or two of weight. It's in the trunk on the right hand side under the trim piece to the right of the batt (which is a PITA to remove and reinstall; part of the reason why I haven't gotten to this yet).
Will be interested to see any screen shots you might want to post of the calibration, etc. of the system for a no nav car?
Congrats and thanks for posting,
ianc
      03-31-2017, 01:54 PM   #36
WDE82
ianc
No reason to go through all the trouble of digging the TPMS module out when a fuse pull takes 2 seconds. I'm not sure how pulling the box simplifies anything. It also makes it extremely fast to reconnect. Minimal car modification. The box weight I bet is under a lb. That's negligible.
I have no screen shots. Once you're in NCS Expert, it's fairly obvious how it goes just from my text.
      03-31-2017, 02:18 PM   #37
ianc
Ex '87 Carrera
ianc's Avatar
Of the car, not NCS...
ianc
      03-31-2017, 02:33 PM   #38
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Originally Posted by Stohlen View Post
I'd code it out if I knew how. Stupid system if you ask me.
Fuck, I wish my car had it. Then you can have the car coded so you can see tire temp and pressure on the display.
      03-31-2017, 04:51 PM   #39
WDE82
ianc
What do you want to see? It's just a dash without errors and the TPMS check is no longer available.
      03-31-2017, 04:53 PM   #40
ianc
Ex '87 Carrera
ianc's Avatar
Did you follow the procedure in the owner's manual for setting it up? All OK? Were you able to test it yet by letting some air out of one of the tires?
      03-31-2017, 06:10 PM   #41
WDE82
I removed TPMS but did not recode RDC. There's nothing to test for me. My wheels don't have TPMS sensors in them so no error means that part worked.
      04-19-2017, 08:14 PM   #42
Mr Rooty Von Tooty
Mr Rooty Von Tooty's Avatar
Drives: 2013 BMW 135i M-Sport
Buy a set of TPMS for a couple of hundred bucks and forget about all this screwing around.
      09-10-2018, 06:43 AM   #43
crowtrobot
Drives: 2008 M3
Dredging up this thread, but just wanted to say thanks for starting it, got my TPMS coded out this weekend. Tried to code in the EU RDC, haven't tested if it worked, but didn't run into any errors either.
The link: http://www.bimmerfest.com/forums/sho...d.php?t=856574 was quite useful.
My car has no iDrive, so I did not have any CIC parameters to code.
      01-18-2021, 11:21 AM   #44
blacksh33p
Drives: 2018 M2 LCI
Adding this for others who stumble here
I have a 2013 e82 135is with CCC (not CIC) and for this year the TPM system consists of the 5 components which are the tire monitors and the RDC/Antenna combo module.
The location for me of the combo box was attached to the forward of the wheel well (gas tank?) underneath the rear of the car. It is literally reachable by hand and about center. For others it seems to be under the driver side seat between front/rear wheel and you have to drop the under guard panels to access it.
I was able to successfully code out TPM system and enable FTM system with ProTool even though I am CCC and not CIC. I didn't feel like replacing the stupid RDC at a cost of $300 new or risk it with a used one.
Here is what I did....
Make backups before performing, not responsible if you brick your ride, do at your own risk.
1) Disable/disconnect physical TPMS RDC module. You must do this first.
2) Code OUT $2VB and ADD IN $265 in the Vehicle Order. In ProTool I did this by editing the string directly in the Vehicle Order editing option.
3) Change the following codes in MASK/CCC, KOMBI, and DSC:
KOMBI: RDC_ALIVE
Disable
KOMBI: MMI_ENA_RPA_RDC
Enable
KOMBI: RDC_VERBAUT
Disable
KOMBI: DSC_MIT_RPA_CC
Enable
KOMBI: RDC_DISP_SWITCH
Disable
Mask/CCC: RPA_CIC or RPA_CCC (If this exists, I can't recall)
Enable
Mask/CCC: RDC_CCC or RDC_SAFETY (I forget the name, but anything related to RDC in this module disable)
Disable
DSC: AUSSTATTUNG_RPA (it may be another name, but anything related to RPA here you enable)
Enable
Basically for this chassis with CCC you are disabling anything RDC related and enabling anything RPA related on those 3 modules.
Note that I directly edited these options for each ECU rather than allowing ProTool to overwrite the ecu's once I changed the vehicle order. You may have success there too as the idea is that when you change the VO, it will adjust the respective module options by coding them to default based on the VO edit. I chose not to do this as I had other coding options I did not want to have to go back and redo.
1addicts
