      07-17-2013, 03:08 PM   #1
flzrider
Drives: AW 1M
TPMS: Code it out or suck it up and buy sensors?
Bought a spare set of wheels and tires without TPMS sensors and of course the warning light turned on the dash. These kind of small things annoy me so I definitely want to deal with it. The 2 basic options are:
-Have it coded out and let the car default to the wheel speed method of calculating a flat tire. Cost: $50 from a local coding guy or find a buddy who knows how to do it for free.
OR
-Suck it up and buy the sensors. Cost: $230 for the set from board vendors, or a used craigslist find for about $100.
What's everyone's thoughts? How have you guys been handling the TPMS dilemma?
      07-17-2013, 07:22 PM   #2
Stohlen
Drives: AW 135i
2008 BMW 135i  [5.66]
I'd code it out if I knew how. Stupid system if you ask me.
      07-18-2013, 01:44 AM   #3
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
disconnect TPMS module code it out, and you will still get euro RDC system which calculates through ABS
      07-18-2013, 07:11 AM   #4
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
code it out
      07-18-2013, 07:36 AM   #5
Stohlen
Drives: AW 135i
got a picture of where said module is located?
I assume that disconnecting the module doesn't trip a light? I know there would be some CAN Bus codes and a missing label code with the module being down, but usually those don't trip lights.
      07-18-2013, 01:30 PM   #6
flzrider
Drives: AW 1M
Did you code yours out too? Where is was your TPMS module?
You can't JUST unplug the module, you also have to code it out.
      07-18-2013, 08:27 PM   #7
Stohlen
Drives: AW 135i
If you were going to code it out... why would you need to unplug the module??? The module would no longer be reporting to the BCM so who cares if its plugged in or not?
      07-18-2013, 09:04 PM   #8
zoomnad
zoomnad's Avatar
11
Drives: 2008 BMW Z4si "M" suspension
So why don't you use the TPMS in you other wheels? That is what I did and I'll be damn if get a flat in the right rear tire so I knew and did NOT trash a tire.
If you want to be happy for a day, drink. If you want to be happy for a year, marry. If you want to be happy for a lifetime, drive a BMW Z4!
      07-19-2013, 10:59 AM   #9
flzrider
Drives: AW 1M
That is how the instructions read. No idea why it needs to be that way.
Link: http://www.bmw$$$coding$$$.com/showthread.php?46-Disable-TPMS
Take out the $$$ from the above to get a working link. Apparently we're not allowed to link to other BMW sites, hahah
Because I'd like to be able to switch back and forth between sets. Swapping sensors would involve having to remove the tires from my other set of wheels which would then require having to re-balance them.
Also, when you disable TPMS, you still get the non-US version of TPMS called RDC which uses wheel speed to calculate a low tire.
      07-21-2013, 09:53 AM   #10
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
You will not be able to code it out when it is connected.
      07-21-2013, 11:10 AM   #11
I35it
all day
I35it's Avatar
Drives: 2012 135i
2004 Toyota Tacoma  [0.00]
2009 VW GTI  [0.00]
2012 135i  [10.00]
I have been looking at that stupid !! thing all the time. I am debating on just switching on my TPMS to my daily tires. But in reality its not all that bad to deal.
      07-21-2013, 05:31 PM   #12
Stohlen
Drives: AW 135i
Yes but after you could reconnect it and it would be fine, is my point.
      07-22-2013, 01:33 AM   #13
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
No same as with other like AIR BAG's it will give a signal and car will get back to default VO
      07-23-2013, 08:17 AM   #14
uwood
Drives: 2009 135i
Wouldnt mind knowing how to code it out. But I am not going to register to another site to read about it.
      07-23-2013, 02:04 PM   #15
flzrider
Drives: AW 1M
I had a link to the instructions but it was deleted by one of the board moderators
      01-12-2017, 11:03 AM   #16
WDE82
Drives: 2018 440iGC F36
Can anyone assist on this issue? My TPMS light still comes on after coding today.
I did the following:
- Remove 2VB from VO and remove TPMS fuse (fuse 27 in my car)
- Code CAS with VO (FA_write)
- Recoded DSC and Kombi for the new VO with SG_coden (or however it's spelled)
Now I don't have CAPPL/CIC in the ECU list, so I wasn't able to do that as several instructions said to do. Am I missing something? CAPPL/CIC is the nav module right? I don't have nav.
      01-12-2017, 07:29 PM   #17
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Would love to know exactly how to do this. TPMS went down on mine. Been using the JB4 to override, but tired of it.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      01-12-2017, 08:42 PM   #18
ianc
Ex '87 Carrera
ianc's Avatar
Drives: '10 TiAg 6MT 135i
WDE90, I've not tried this myself, but have looked into it and from what I've read, you don't want to pull the fuse (other things use it as well), but rather unplug the main TPMS module before recording the VO...
ianc
      01-13-2017, 02:29 PM   #19
WDE82
I'm going to try some more things. Apparently the VO is in FRM and NFRM so the redundant info may be getting rewritten into the CAS after I do the FA write.
I will try unplugging the module last. I don't have iDrive so the fuse is the best option for me. From what I've read, it HAS been accomplished with just a fuse pull.
      01-13-2017, 02:40 PM   #20
ianc
Ex '87 Carrera
ianc's Avatar
Keep us posted. I scoured the internet (ha!) looking for a how to for the 135, but didn't come up with anything. I found one success story for an X3 owner, but I believe that was it.
If you accomplish it successfully, a DIY would sure be appreciated! (hint hint...)
ianc
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA
      01-13-2017, 03:07 PM   #21
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Yes absolutely, please write a DIY in the DIY section if you succeed and lets get it stickied for you!!
By main module, are you guys referring to RDC?
      01-13-2017, 03:22 PM   #22
ianc
Ex '87 Carrera
ianc's Avatar
RDC is the German abbreviation for the Flat Tire Monitor (the TPMS alternative).
Reifen something something or other?
ianc
1addicts
