      09-19-2012, 05:03 PM   #67
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Originally Posted by Metralha View Post
btw how many km/miles did you run with PS3 30k-40K??
I think about 26K kms on my rears. The fronts seem to last twice as long as the rears do. But tires do not last long on a 135i. Especially a tuned one.
Btw... over here in Germany... its not just a huge fine like 250 euros(for you!) but the Polizei can also impound your car and let you walk home. Then you have to get a COMPLETE new TUV which is $$$! Plus (+6)points on your license. A German friend of mine had that happen to his German plated car. His wheels were 19's instead of 18's and stuck outside of the fenders by 10mm. It was a PITA.
      09-19-2012, 05:25 PM   #68
Metralha
Metralha's Avatar
Drives: BMW 120d E81 - 2007/09
correct...here is the same....
250 €
docs arrested
new inspection around 120 €
but they alow you to go home with your own car....LOL
      09-19-2012, 05:27 PM   #69
Metralha
Metralha's Avatar
26K....uiuiui.....
yes with 120d that should stand for a few more milles i hope.... mainly cause we dont have Auto B....lol.... and fuel is very expensive for our pocket
      09-22-2012, 03:48 PM   #70
Metralha
Metralha's Avatar
tires pre-ordered...
already saw the 225/35R18.... wwooooowwwww the got presence yes they do....
Next monday i will fit one front + one rear to check visually.
One thing it creaps me up is that the Michelin tires comparing to the rest of brandes, in the side they bend like no others....this is tipical from all michelin tires why??
I checked along with some S001 from bridgestone and theres no comparison
      09-22-2012, 05:19 PM   #71
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Congrats on the Michelin's! I am sure you will be happy with them. I still love mine!
One thing... my tires did rub a tiny bit when new. Only in the rear AND only when one of the rear wheels would go thru an entire suspension compression. It goes away though - I only heard that tiny bit of rubbing for the first 400kms. I think it was the "rubber strangs" from the tire mold rubbing on the inner fender liner. No big deal.
I am running the 225/255's on my factory wheels - they work just fine. So I don't see why you would need to test fit yours. ?
Dackel
      09-28-2012, 07:22 AM   #72
Metralha
Metralha's Avatar
Done: PS3
      09-28-2012, 09:15 AM   #73
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Done: PS3
Looking GOOD!
So... How do you like them?
      09-29-2012, 07:56 PM   #74
Adam135
Drives: 2014 435i
I just had Michelin PSS installed on my 135. The ride has definitely improved. I have a rubbing issue, starting another thread for that.
      09-30-2012, 08:30 AM   #75
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Mine rubbed just a tad and only when the left rear wheel went thru a full motion of travel. But this goes away after a few hundred kilometers. I think its just the "stringy things" that stick out from the tire when the tire mold is injected at the tire factory. Really this slight rubbing goes away after a few hundred kilometers. Nothing to worry about.
      10-03-2012, 05:06 AM   #76
Metralha
Metralha's Avatar
Hi there,
first impression.
Improved a lot regarding riding conform. mainly in bad roads.
I fell more suspension working. if you know what i mean.
The front axel seems to be more slipy (slip) but i just had 200km with them and i'm sure the gum from demoulding the tire is still there.
Need more 300-400km on highway to get a more real opinion.
      10-03-2012, 06:52 AM   #77
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Hi there,
first impression.
Yup, that is what I noticed too. The suspension feels like it now moved up and down more. As IF the tires are working WITH the suspension instead of just acting like hard stones. With RFT's you can really feel the tires hang up in the air when going over bad/rough pavement. With the PS3's the tires actually ABSORB some of the pavement imperfections.
Yes, you need at least 400 km's for the tires to have some stick. At first the tires have a lot of slip & squirm to them bc they are new.
I also run with max tire pressures to have decent feedback from the tire. I always drive fast (over 150 mph) and I like that hard solid sidewall "feeling/response' from my tires.
PS: Did you have any rubbing issues? Just curious. ?
      10-03-2012, 08:14 AM   #78
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Perhaps this cutaway of normal tires vs RFT will help people understand how much beefier runflat (RFT) tires are in the sidewall construction.
Run Flat tires vs Normal tires - dealer cut away carcus...
http://www.1addicts.com/forums/showthread.php?t=412903
      10-03-2012, 11:32 AM   #79
Metralha
Metralha's Avatar
Honnestly speaking i didnt understand clearly the meaning of rubbing!!
Even tried google translator...LOL
Can you explain in other words please...sorry!!
cheers,
regarding preasure they inflate with nitrogen i beleive (FR: 2.3 bar / Rear: 2.5) as indicated in the driver door stick.
      10-03-2012, 11:37 AM   #80
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
cheers,
Rubbing = contact
Webster's definition...
1. a : to move along the surface of a body with pressure : grate. b (1) : to fret or chafe with or as if with friction
Some members have reported a slight (small) rubbing or contact with the tire to the body of the car. I only noticed this for the first few hundred km's and did not even think to mention it in my original post. I don't think it effects many cars, since I have only seen three people talk about rubbing (contact issues) with the rear 255's tires to the inner body of the car.
      10-04-2012, 07:04 AM   #81
Metralha
Metralha's Avatar
Originally Posted by Dackelone View Post
Rubbing = contact
Rubbing = contact
Noted!! Sorry.
When I first look the tires on place I got scared because tyre was really close to the car body and one of the suspension arms.... but this was with car "on air", when I placed the car down all appears to be much more distant.
I went for a ride and made 3 slides to make sure no contact was felt.
I removed again the rear tire and apparently no contact at all.
Don’t forget I have an E81 that might be slightly different from E82.
Next week after 400km I will check again and remove the tire again to make sure no marks on the tyre/body work or suspension arm.
      10-20-2014, 06:08 PM   #82
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
A few months ago, I replaced my rear tires with new 255's PS3's. I was quite shocked in that the tire prices have fallen quite a bit. I think the tires were like 40% cheaper than two years ago.
      10-30-2014, 02:16 PM   #83
MaxVasc
Absorbing
MaxVasc's Avatar
Drives: BMW 135is | #98/586
Got the 225/255 setup in MPSS. I have some significant rubbing on left rear tire under compression. Can someone send me a picture of their inner fender on the left rear? My right rear seems to be somewhat more "rolled" than the left. May just have to get the left rolled somewhere, or do it myself. I just don't want to ruin my new tires or the body of my car. Regards.
/// Leonidas: 13' 135is #98/586, 6MT M-Sport, Space Gray, Terra Cotta, Harmon and Kardon, MPSS 225/255
      10-30-2014, 04:45 PM   #84
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
My PS3's only rubbed very mildly, for a few days. And only when one of the rear tires went thru a full compression(and hard corning in a turn). After about 400kms... all rubbing noises were gone. You might just drive the car some before "rolling" the sheet metal.
Dack
      10-30-2014, 08:26 PM   #85
MaxVasc
Absorbing
MaxVasc's Avatar
Thanks Dack. I have driven about 450 miles on them already, I'm gonna keep my eye on them. I can definitely tell where the fender is hitting the tire. I will post a picture tomorrow.
      10-31-2014, 05:32 AM   #86
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Does the car have the M Sport pack from new? I am running Yokohama Advan Sport 225/255 which are as square shouldered as the Michelin's ... But with no rubbing in 20k with all manner of roads. I discovered that the inside of my M Sport 123d rear fenders are indeed rolled.
Hence my question.
      10-31-2014, 06:35 AM   #87
MaxVasc
Absorbing
MaxVasc's Avatar
Hence my question.
Yes indeed, it is a 135is M-Sport. But the right rear seems to be much more rolled than the left.
      10-14-2015, 09:37 AM   #88
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
The correct tire sizes should read/be...
225/40ZR18 94Y
255/35ZR18 92Y
Btw... BMW themselves use this tire size on many new models now.
1addicts
