07-07-2009, 11:41 PM | #89 |
E30 Addict
38
Rep 590
Wheels: VMR V713
Front: 19x8.5 +45 Spacer: none Rear: 19x9.5 +45 Spacer: none Tires: Front Nitto NT555 Extreme 225/35/19 Rear Nitton NT555 Extreme 245/35/19 Suspension/Fender Mods/Camber: -H&R Coilovers. Front all the way high, rear all the way low -No Roll Front -Had to cut some of the plastic out from the inner fender well in the rear -Rear fenders are trimmed.
07-08-2009, 12:49 AM | #90 |
sport pilot
Rep 65
Please, if you can follow this model, better. Thanks.
Wheels: D-Force EmPower Front: 18x8.5 +40 Spacer: none Rear: 18x9.5 +43 Spacer: none Tires: Front Yokohama Advan Neova 255/40/18 Rear Hankook RS2 Z212 265/35/18 Suspension/Fender Mods/Camber: -KW V3 lowered ~1.5" front, ~1" rear -Vorshlag front camber plates (brings the tires "in" more, away from the fender lip), ~2 deg neg camber front & rear -slight roll front & rear -had to cut some of the plastic out from the inner fender well Notes: Rubbed front fender where fender meets bumper (...) |
07-08-2009, 01:49 AM | #91 |
Rep 4,070
Wheels:
Vorsteiner V-302 Front 19x8.5 offset uknown Spacer: none Rear 19x9.5 offset uknown Spacer: none Tires: Goodyear Eagle F1 Asymmetric 225/35/19 and 255/30/19 Suspension: KW V1 Stock ride height due to rubbing issues in the rear Slight roll on rear Notes: Rubs bad over big dips and potholes. Slight rub during hard cornering. Considering scrapping the rear wheels and going with different sizes because it is becoming expensive to get the current tires to stop damn rubbing...not to mention in this doggone area of the country every body shop or so-called tuning shop is scared to roll a damn fender..."we dont want to crack your paint and be held liable" GRRRRRRRRR!!!.......sigh. |
07-08-2009, 01:50 PM | #92 | |
E30 Addict
38
Rep 590
Wow that really sucks. Those wheels are supposed to be custom made. Hell, I could make some wheels with the right offsets to fit. I would make them fix that for the ammount of money you spent. You may want to cut your fenders and go 245/35 for the rear tires.
07-08-2009, 03:06 PM | #93 | |
Rep 1,329
Dam that is hot I want thoes wheels.
07-09-2009, 09:53 PM | #94 | |
Rep 4,070
I have already had them sent back once due to centercaps not fitting. So 8 weeks for them to be manufactured, 6 months for me to get back from Iraq, another 3 weeks for them to look at the wheels and make sure that they have some centercaps for me....and now the rubbing issue (and one other semi-related issue...PM if you want to know about that). My small consolation is Nick and Ali@Jlevi have brainstormed with me about what I could do to fix the rubbing issue as well as given me an assurance discount on the soon to be released Vorsteiner Hood.... I want to cut the fenders but the shops around here a scared to do anything. I have to take an hour drive up to Charleston just to get someone that works "High-End" (Audi, BMW, Mercedes....LOL...makes me laugh cause in Germany, where I lived most of the last two decades, these are everyday cars) can LOOK at it...then make an appointment....and then drive up there AGAIN to hopefully get it fixed...and THEN do a complete alignment...sigh....LOL |
07-25-2009, 02:57 PM | #95 |
Auto X'er
Rep 157
TT/Autocross set up
Wheels: Breyton GTS-R
Front: 18x8.5 +48 Spacer: 10mm Rear: 18x8.5 +48 Spacer: none Tires: Front Dunlop Star Specs 255/35/18 Rear Dunlop Star Specs 255/35/18 Suspension/Fender Mods/Camber: -H&R Pro coil and springs- all the way up in front and lowered 1/2 in the rear -Vorshlag front camber plates (brings the tires "in" more, away from the fender lip), 2.6 degrees in front (max) -BMW strut brace -Custom rear strut brace -Dinan Stage 2 tune -Injen Intake -G-Force harnesses -BMP Tow hooks (for track racing) Notes: Front rubs a little bit over bumps. Front tires are really wide, if you were to turn and go up a big bump...bye, bye fender. Set up is unbelievable for racing, not what I use on the street (that is what stock tires are for). Unbelievable amounts of grip and very little understeer, even with over 400 hp! |
07-25-2009, 04:44 PM | #96 | |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
07-27-2009, 09:02 AM | #97 |
Auto X'er
Rep 157
It rubs just a little bit...it is certainly not ideal. I would like more camber, but with the sways and the coilover set up that is max camber. I am looking for more grip and to loose the understeer. The tracks in Colorado are quite smooth, so no worries about damaging the fenders as long as you stay on the black stuff...
08-08-2009, 03:53 AM | #98 |
Rep 1
Hello,
Here are photos of my current one Wheels: BMW performance Front: 18x7.5 Rear: 18x8.5 Tires: Front: Bridgeston potenza runflat 215/40/18 Rear: Bridgeston potenza runflat 245/35/18 And my ancient Wheels: Répliques bmw style M6 Front: 19x8.5 Rear: 19x8.5 Tires: Front: Dunlop sp sport maxx 225/35R19 Rear: Dunlop sp sport maxx 225/35R19 |
08-14-2009, 05:34 PM | #99 |
Rep 2
what offset were you running on your M6 reps? I'm new to 1series and have a good deal on a set of M6 reps in 18x8 ET35, I know the offset is quite low... just want to make sure it is doable before i pull the trigger. let me know, thanks! |
08-18-2009, 01:46 PM | #100 |
Rep 3
09-02-2009, 05:13 PM | #101 |
Lack of charisma can be fatal
Rep 1
my new wheels!
Hey Guys, first post! I'd like to thank you all for the information on here that helped me buy my wheels (hope pic has uploaded correctly).
they are 18x8 with an offset of 38, tyres are 225/40 all round and as yet have had no rubbing. sorry pic isnt great car needs a clean and it was taken on my phone! car is sydney blue 120i SE everything standard bar wheels! |
09-18-2009, 10:49 PM | #102 |
Rep 354
I bought Potenza RE 11 225/45 , tomorrow i will track the car, do you think im going to rub on the front?
Stock rims and stock suspension Tnx!
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC |
09-22-2009, 02:13 AM | #103 |
sport pilot
Rep 65
Du you are in 17 inches?
The RE11 225 R18 no rub front/rear. I think in 17 no rub... Y have RE11 225 front with Bilstein PSS10 + camber plates Vorshlag: NO rub. |
09-25-2009, 03:12 PM | #104 |
Rep 98
Drives: X6 XDrive35D
Summer rims
18x8 et40 front (225x40) 18x9 et42 rear (235x40) The fronts rub the wheel arch liner joint on full bump, suspect some minor trimming will solve it. |
10-01-2009, 11:17 AM | #105 |
445
Rep 1,658
The following is results of prototype wheel test fitments. I'll be trying many different configurations so I'll post those up as well.
Wheels: APEX ARC-8 Front: 18x9" et42 Spacer: none Rear: 18x9.5" et62 Spacer: none Tires: Front Nitto NT-05 245/40/18 Rear Nitto NT-05 265/35/18 Suspension/Fender Mods/Camber: 100% stock 135i Notes: zero issues in the back. the tire is close to the inner noise dampening mat, but not touching. looks like there is room for a 275/35/18. I will test that out, and on a lowered car as well. This is the only wheel that allows for this much rubber in the rear, and it weights in around 18lbs~. The front was purely an experiment to provide the forum data. the tire is 0.5-1mm away from the strut tube. This would need a 3mm spacer for me to feel comfortable when actually driving around. rubbing did not need to be tested as it was clear on a stock car this would not work. with camber plates and around 3 degrees negative camber this wheel would work. The intended wheel for the front is an 18x8.5" et38, which will be tested this week. |
10-12-2009, 10:12 PM | #106 | |||
Rep 727
Drives: 2010 E91 328i xDrive 6MT
hi, not a user of 1addicts...
looking for some help. will any of these fit a '09 128i? TIA Quote:
10-13-2009, 11:19 AM | #107 | |
Rep 372
On another note, BBS CH pics would be nice!
Georgie Vazquez Mayaguez, PR R.I.P. 335i, 010 135i here! |
10-30-2009, 03:19 AM | #108 |
Rep 143
Looks fantastic. What brand tires are you running? Did you have to roll the fenders?
10-30-2009, 12:03 PM | #109 |
Rep 18,823
We are using 255/225 Dunlop Direzza Star Spec in that photo, a minimal amount of fender rolling was needed in the back due to the KWs.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
