04-29-2007, 10:19 PM | #1 |
Rep 2,576
Computer help....
Ok, im a MAC guy and my cousin was about to throw away an old (last year) laptop because it keeps shutting off. So I said hey wtf can i have it. Long story short he gave it to me, i reformatted installed XP and everything, and thought it was running fine, but bam, shut down. It was very hot so maybe that had something to do with it but does anyone know what could be the problem? It shuts down randomly not only when its hot. Im thinking about bringing it to Geek Squad and seeing if they can fix it. Even if it costs me 100 bucks its still more then worth it. If anyone knows anything that can help, please tell. Im pretty good with computers, built one of my own but that was about 4 years ago and forgot most everything with PC's now.
04-30-2007, 01:04 AM | #2 |
Rep 1,760
u did a full reformat (not just a "fix") and its still doing it? blue-screening ? just powering off?
start by installing a temp monitor, i forget but i think cpu id has one, or a program called everest is better could be anything, thats the trouble with saying "hey my PC is shutting off" and leaving it at that |
04-30-2007, 01:29 AM | #4 |
United States Marine
327
Rep 2,748
Definitely sounds like a CPU overtemp. I had the same thing happening to my desktop because my case didn't have efficient airflow for cooling. Totally smoked the processor after it happened a few times.
You should check and see if your fans are running (and smoothly), and be sure never to leave the laptop sitting on carpet or fabric, only smooth hard surfaces. |
04-30-2007, 05:48 AM | #5 |
Rep 2,576
Ya, im almost 100% sure its the CPU. I had that problem on my desktop before but fixed it. If it turns on later today ill install a temp monitor, but lets say thats the problem.....whats the fix?
04-30-2007, 07:20 AM | #6 |
Rep 1,281
Drives: E93 M3
sounds like it's overheating. you could try reseating it with new thermal paste
E93 M3 | Azurite Black | Extended Bamboo Leather | Piano Black Trim | 19" 220M Wheels | Shadowline Trim | Edition Grills M DCT | HDD iDrive | EDC | Bluetooth | Front & Rear PDC | Heated Seats | DAB Radio | Hi-Fi Speakers | USB Audio | SmartTOP |
04-30-2007, 07:34 AM | #7 |
***** noob
1402
Rep 10,477
Drives: 325xi>M235i>428GCx Mspor
sounds like a hardware issue if you reformatted the drive....
how old is this laptop??? Specs???
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
04-30-2007, 10:16 AM | #8 |
Rep 2,576
2 years old. 1.73 ghz processor (not sure which type) 768 ram, 80gb hd. hp model dv1000. I'm beginning to think it could be the ram. Maybe one stick is bad and its the reason it keeps turning off?
04-30-2007, 10:33 AM | #9 |
Rep 7,308
Drives: see above.
try this to test your ram
http://www.memtest.org/
04-30-2007, 11:34 AM | #10 |
Rep 5,842
Drives: 2006 325xi
Is the fan on the CPU running when its hot? the fan could have just died
04-30-2007, 05:13 PM | #11 |
18326
Rep 9,410
Dell laptops a few years ago had problems with the fan not coming on soon enough. Check with the BIOS manufacturer for an update.
If the RAM were failing, you should at least see a little something in the system log (right click My computer, manage, Event viewer, system log) other than "the shutdown at 1:30 was unexpected." |
04-30-2007, 05:23 PM | #12 |
Rep 2,576
Im running a RAM test now, but i dont know if thats the problem. Im using the program that was referred to in the earlier post. Lets hope that its this easy and thats the problem (praying)
04-30-2007, 05:32 PM | #13 |
Rep 2,385
Try getting a cheap laptop fan try. I have one and keeps my laptop super cool. I hardly ever hear my laptops actual fans turn on. They range in pricing heavily for what they are so buy a $10 cheap one just to try it out.
http://www.dealtime.com/xGS-laptop_fan_tray This is the tray I have. I bought the cheap one cuz I wasn't sure if I'd like it or if it would actually work. I'll prolly buy a better one soon.
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
04-30-2007, 05:45 PM | #14 |
Rep 2,576
I cant even get the computer to stay on to do the memory test...
04-30-2007, 07:58 PM | #15 | |
***** noob
1402
Rep 10,477
This sucks cuz is a laptop and not a desktop where it'll be easier to find parts to test
2006 325xi (Sold)
04-30-2007, 09:39 PM | #16 |
Rep 2,576
It appears (knock on wood) that it was the 512 stick that has gone bad. So im running on 256 ram til i go tomarrow to either buy a 1gb or another 512
04-30-2007, 10:26 PM | #17 |
Rep 3,200
Sounds like a slowish machine. Ditch XP and install Feisty Fawn.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
05-01-2007, 03:06 PM | #18 | |
\oo==0|0==oo/
9
Rep 103
You said you could not even run memtest because the thing would shut off by itself. Now memtest is designed NOT to be affected by faulty memory, but to find and report it (not a trivial task). If it did not even stay on for memtest to complete, it's not the memory. I'd say it's the processor (going out or overheating) or something power-related. If removing some RAM got it working, then I would bet on something along the power supply chain. More RAM, more load on that particular line, Bang! If you are handy at it, maybe you can open it and check for obvious signs of overheating in the area where the RAM PS regulators are located. Maybe change or at least test and reseat some larger capacitors in there. Another (or a bigger) RAM module probably won't help or even make it worse. Good luck and do post if you get it sorted.
"...ssssix blade knife, do anything fo' ya'..."
05-01-2007, 03:32 PM | #19 |
Rep 158
using the keyboard arrows press "up up down down left right left right" then click on "B" "A" Select Start
2006 325i Jet Black (5-21-06)
05-01-2007, 03:39 PM | #20 |
Rep 3,200
There is no select in the code. Noob.
05-01-2007, 04:42 PM | #21 |
Rep 2,576
well it got it working with 1, 256 stick. I dont know why i would spend any money on the computer when its working fine. I plan on buying myself an Alienware lightweight laptop this summer so this is just for the end of the school year (4 weeks)
05-01-2007, 06:37 PM | #22 |
Rep 2,576
Well i spoke to soon. The computer doenst seem to want to turn on now! grr
