BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      10-28-2008, 03:46 AM   #1
MDCTFTW
Drives: E92 DCT
When installing springs how tight do you tighten the top perch nut?
One thing I've always wondered when I install suspension is how tight should the top perch bolts be tightened? Since the strut tower is threaded, what if the two sides are uneven? Couldn't that make the ride height different on both sides?
I've attached a pic (thanks Speedtrap for the borrowed pic). Say for instance the top nut is tightened to 1 on one side and 2 on the other. Won't the ride height be different on both sides? Or is the general rule of thumb to make both sides about even?
Also ... if you tighten both sides to position 1 or both to position 2 won't that yield different ride heights? That's a good inch right there. I know those positions are extreme ends of the threads, but I'm just trying to make my point here.
Or am I just being overly anal? Haha.
MDCT ... so you can drive and eat a hamburger at the same time.
      10-28-2008, 08:51 AM   #2
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
The position of the nut has no affect on ride height. It just affects the maximum droop the suspension can acheive. Ride height is determined by the spring perch on the strut.
      10-28-2008, 11:31 AM   #3
MDCTFTW
Drives: E92 DCT
Is that true? Here's another picture that again shows the extreme cases. Would these two setups yield different ride heights? Or is it the spring rate that is determining the ride height?
      10-28-2008, 11:45 AM   #4
consolidated
consolidated's Avatar
205
Drives: F80 M3
Lower nut looks like more preload to me, car won't have much sag which could be undesirable.
      10-28-2008, 11:47 AM   #5
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
If everything in both illustrations are exactly the same except the nut position, once you lower the car the spring will compress to the same steady state height regardless of either setup.
The ride height will be determined by the spring itself and the shock/strut base position (the "sleeve" where the bottom of the strut is inserted) as previously explained.
      10-28-2008, 12:00 PM   #6
MDCTFTW
Drives: E92 DCT
Ok cool I guess that makes sense, but how about in the extreme case if the uninstalled strut has a top mount that is compressing the spring even more than the normal weight of the car would when it's installed? This would the car to be even lower right?
      10-28-2008, 12:47 PM   #7
Technic
Technic's Avatar
2288
... then we would not be talking about the same setup, as one strut will compress the spring more than the original strut, something like a coilover vs. standard strut.
      10-28-2008, 12:53 PM   #8
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
pm longtran
      10-28-2008, 01:23 PM   #9
Speedtrap
Drives: A very fast car :)
Thanks Did not even know that myself.
      10-28-2008, 03:28 PM   #10
MDCTFTW
Drives: E92 DCT
Originally Posted by ///Mantis View Post
pm longtran
I think I asked him in a thread before ... the one where he showed some pics after his drop and he didn't torque the bolts to any specific value.
      10-28-2008, 07:49 PM   #11
rzm3
rzm3's Avatar
673
Drives: E92 M3
so what's the official say on this?
      10-28-2008, 08:27 PM   #12
MDCTFTW
Drives: E92 DCT
I think as long as the uninstalled spring is not compressed more than it would be with the weight of the car then it should even out.
      10-29-2008, 12:15 AM   #13
JAJ
Drives: 2014 Shelby GT500
The top of the spring sits on a spring perch that's mounted to a bearing that's bolted (with three small bolts) upside-down inside the fender. The bottom of the spring sits on a perch that's clamped to the top of the damper body. The spring sits between these two perches.
The nut you are wondering about in the original post just keeps the damper rod in place - too loose and it will rattle, too tight and it will damage the threads and maybe the rubber bushing it sits in the middle of. Other than that, it has no effect on the ride height.
      10-29-2008, 12:49 AM   #14
MVEED3
Drives: '16 GT4
You'll feel when the nut makes contact, sandwiching the washer assembly. IIRC, a 10mm socket fits over the top of the shock shaft. I used a ratchet on that and an open-end box wrench on the nut and squeezed to an approximated 18-20ft-lb. RealOEM doesn't have torque specs so I assumed this based on previous M3 specs. You can always torque the nut down after the assemblies are installed on the car. This may even be easier since the shaft shouldn't spin with the car on the ground under the spring's tension.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      10-30-2008, 06:44 PM   #15
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Does this help? Taken from here.
      10-30-2008, 07:01 PM   #16
rzm3
rzm3's Avatar
673
Drives: E92 M3
this definitely helps. thanks.
      11-21-2008, 06:38 PM   #17
rzm3
rzm3's Avatar
673
Drives: E92 M3
UPDATE:
Tighten to 64Nm! The tightness of the nut WILL slightly affect the position of the guide support and therefore the ride height. This is torque spec from BMW.
      11-21-2008, 06:58 PM   #18
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
I tightened this up today being that I had that clunking sound. However, I did not tighten it with the torque measurer being that the dealer wanted me to leave the car there for the day for something that would take 5 minutes. So I took it to my mechaninc, he tightened it down with a wrench and the sound is gone. Didnt turn too much but there was deff some room.
      01-20-2015, 11:49 AM   #19
Atomicteal_M3
Atomicteal_M3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Great info
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
      01-23-2015, 04:22 PM   #20
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
Originally Posted by BLKLYZ View Post
Great info
Except the ride height argument is wrong...
The bearing rides on the shaft collar. The tightening of the nut serves to hold the strut in position in the collar. It does nothing to the ride height unless your car sits with the shocks fully extended, which it doesn't...
I'm not even sure the torque number is correct. I'll have to look at the manual to be sure.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      01-23-2015, 04:30 PM   #21
Atomicteal_M3
Drives: E90 M3 AW
2007 335i  [9.00]
I was just referring to tightening the nut to the shock. My friend and I installed my springs after removing my sleeve overs. The position of the nut sat at a different height when my s/o were installed. We did not tighten the nut that much once the springs were installed to mimic the look of the s/o. I received the clunking noise when driving as well but after reading this post, I just tightened the 2 strut nuts and the clunking went away. I guess it had to do with different spring rates. Either way, the car rides like a champ now!
      01-23-2015, 04:44 PM   #22
admranger
Retired Curmudgeon
admranger's Avatar
Great! You do have to tighten that nut down or the shaft will thunk around (up and down motion) in the strut bearing. I've had them loosen up before in my old race car (that's what I get for re-using nylock nuts).
If you ever have to do this again, make sure you don't spin the shaft of the strut when you are tightening the nut. In some shocks this can damage the valve body. Not saying you did this time, but sometimes people get carried away tightening things!
m3post
