Best Scanning Diagnostic Tool
05-22-2016, 04:22 PM | #1 |
Rep 14
Hi guys,
Newbie to forum. Was wondering what is a good scanning tool to get? I know there are some out there and can read 'shadow codes' not sure if this is really neccesary unless your a mechanic of course? Not sure which one you guys recommend for home use? Cheers. |
05-22-2016, 07:37 PM | #2 |
Rep 1,693
I use the Bavarian Technic cable and software and it's excellent. It reads both current and shadow codes, as well as states at what time the code came up. Obviously much more (eg individual adaptation resets, logging etc) There is also an ECS Tuning diagnostic tool which is meant to be great and gaining popularity.
05-23-2016, 05:23 AM | #4 | |
Rep 14
Thanks guys, much appreciate your thoughts on this subject. I guess if ur a bit of a hardcore Bimmer nut who likes modding then the Bavarian Tech is prob the way to go. vtl, which INPA cable (brand) do u recommend? Is eBay the way to go? |
05-23-2016, 05:53 AM | #5 | |
Rep 3,148
http://www.ebay.com.au/itm/271621954...%3AMEBIDX%3AIT INPA is the software from BMW you can use to diagnose your vehicle. Much more capable than the BAV cable. Reads everything and you can go into the detail of an error code. A lot of times the error code is pretty vauge but will have more data ascociated with it that pinpoints the fault. Cable is much cheaper and the software can be downloaded off the forums. Its a bit tricky to setup but now there are idiot proof guides in in the coding section of this forum. Alternatively if you want a more user friendly setup, you can use the same cable but use an android app called BMW Carly. Never used it cos I use INPA but seems to be an alternative that is easy to use and recommended by a lot of members here.
05-23-2016, 07:44 AM | #7 | |
Rep 577
It also works with iOS but may require purchasing of their proprietary cable. I found the app worked with newer cars using a generic Bluetooth OBD dongle, but not on my older '07 320i. I did use my laptop and code with BMW software in the past, but I found this to be a lot of effort at times. I guess I got lazy
SGM E92 335i FBO [COLOR="Indigo"]/ MHD Stage 2 Plus / CP-E FMIC / DCI / VRSF DP / VRSF CP / Turbosmart Raceport BOV / BMW PE / H
05-23-2016, 09:05 PM | #8 |
Rep 3,189
Bt cables a bit old school and limited.
Inpa does everything but is a bit of a pain to use. A step up from bt cable is the schwaben scanner from ecs tuning. It does alot more then bt cable and is 299 plus shipping frin the us. It can code injectors for a start. Code batteries, auto bleeding brakes. Heaps of extra stuff They are currently working on updates at the moment. |
05-23-2016, 09:46 PM | #9 | |
Rep 3,131
Drives: 2011 335i e92 DCT
They don't tell you this in the app :/
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
Mr.TenEighteen6.00 |
05-26-2016, 05:40 PM | #11 | |
Rep 671
09-06-2016, 01:57 AM | #12 |
Rep 219
doh! just found this thread after purchasing one with the white pcb. having no luck with getting it to connect with INPA so far.
the most popular seller on ebay australia sells a white pcb, so do avoid: http://rover.ebay.com/rover/0/e11400...&sojTags=bu=bu This thread and vtl's link should be a sticky for the unsuspecting bmw coding noobs. |
09-06-2016, 02:39 AM | #14 |
Rep 1,382
09-06-2016, 03:12 AM | #15 |
Rep 671
09-06-2016, 08:23 AM | #17 | |
Rep 671
Had a look on the website. Seems like it does. And that it's more suited to someone like me, with a nice and easy GUI to use!! also will it code injectors and allow a transmission fluid change? |
09-06-2016, 09:50 PM | #18 | |
Rep 91
However, you don't need anything to do a transmission fluid change as I've recently done this myself without any issues. |
09-07-2016, 12:11 AM | #19 | |
Rep 671
only thing I don't get is, do you need to pay a nominal fee to register a battery, and reset service intervals? that's what I thought I read.......cant be right though after buying the adaptor and software can it? |
09-07-2016, 12:31 AM | #20 | |
Rep 6,285
I know workshops who have tools such as an autologic etc perform this type of servicing. |
09-07-2016, 02:51 AM | #21 | ||
Rep 91
09-08-2016, 08:52 PM | #22 |
Rep 671
can you do logs with carly?
and if I use the pro app on my car, can I use it on my mums 335i as well? also as a FYI, I ordered the wifi obd thing direct from carly in EU, cost $100AUD including postage. they emailed me saying I could have it quicker if I cancel the order and buy through carly AUS, but it costs $150AUD including postage for JUST the adaptor. why would there be a $50 difference in price? I don't get it!! not in a real hurry for it, so ill just get it in a few weeks. |
