03-08-2017, 10:25 AM | #45 | |
Rep 3,241
http://www.analysis-plus.com/home-audio/#bulk |
P111573.50 |
03-08-2017, 10:32 AM | #46 | |
Rep 8,942
2 in dining room 2 in master bath 2 in bedroom 2 in living room 2 in deck (not ceiling but whatever) They are all home run to that single location? You then have freestanding speakers B&W that you want to use those 3 + sub + the 2 living room ceiling speakers for a theater? Once we figure that out I can start giving you some opinions. BTW you shouldn't run all that gear all at once plugged in with splices. I don't understand all the electrical engineering stuff (my buddy takes care of that for me) but I think you could melt your receiver. |
03-08-2017, 10:37 AM | #47 | |
Rep 8,942
I would definitely check out GIK they have some nice not too expensive options and just released some new "designer series" stuff that's prettier. PM me your email address I will send you some pics. You can also just get the supplies and make panels with whatever fabric you want. I have a combo of premade stuff and DIY. |
03-08-2017, 10:44 AM | #48 | |
Rep 11,139
The Sony STR-DA5300ES can power the 5.1 system. But I'd like to use my Sonos Connect with a separate amp to power the eight in ceiling speakers. I need suggestions on which amp. A 9.1 receiver? An 8 channel amp? Two 4 channel amps? |
03-08-2017, 10:51 AM | #49 | |
Rep 8,942
What do you actually want to be able to do with all of this stuff? Do you want to be able to play music in the theater room just like everyplace else? And how idiot proof / easy to use do you want all of this to be? Do you want to be able to easily play music in room 1,2,3 and not in 4,5 that sort of thing? Do you want to be able to listen to different music in different rooms? Is that Sony receiver 2 zone? Reason I ask is you could possibly get away with what you have and a Niles speaker switch if you wanted to add some in wall volume controls. More flexibility you want = more gear you need to add. BTW for bathroom and outside don't go crazy on speakers both horrible sound environments. Boston makes some nice outdoor speakers so does Bose. Bathroom honestly doesn't matter much it's all going to sound like crap you just want noise in there. Check with a pro though you may need to get something marine rated for a moist environment or something. I know Sonance makes marine stuff not sure on others. |
03-08-2017, 10:54 AM | #50 | |
Rep 3,241
Not sure what your budget is, but here is an Internet only outfit that has garnered a decent following. Emotiva http://emotiva.com/products/emotiva/amplifiers-0 I have two of their XPA-2 amps. One is driving the rear surrounds in my dedicated sound room and the other is part of my 2 channel system. The XPA-2 is no joke of an amp. Very beefy unit that weighs in at about 80lbs. |
03-08-2017, 11:00 AM | #51 |
Rep 8,942
I guess one other question do you want to be able to control all of this via phone or tablet? Sonos where you started is super easy for this other solutions some yes some no.
Hell for the bathroom you could get away with a single Play 1 for $200 and call it a day truth be told.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
03-08-2017, 11:12 AM | #52 | |
Rep 3,241
But what I'm thinking you have pictured is to have all the speakers running off the same amp output. That of course is a no no if it's wired in what's called parallel. Electrical 101. Wiring loads in parallel reduces the impedence of the overall load. With all things being equal, this requires a requisite increase in the amount of current needed to drive the load. If you look at amp specs, you'll see them listed for 8 Ohms and 4 Ohms typically. Even though the impedence of the system is dropped in half, you would think most amps would be able to double their power output...say 100W at 8 Ohms to 200W at 4 Ohms. This isn't the case as the current demand on the amplifier causes the power output to be less than double. You'll see typically a rating of maybe 125W into 4 Ohms up to 150W into 4 Ohms. I'm just making general numbers here. But you get the idea. A class A amp doesn't have this limitation and can double its output with each halving of the impedence load. So a class A amp running at 100W into 8 Ohms will do 200W into 4, 400W into 2 Ohms, and gasp....800W into 1 Ohm. These are RMS numbers and not dynamic peak power. This is why class A amps are more expensive than other amp types like AB, H, etc. An example of class A amps are from Classe Audio and Krell. Too Long Did Not Read is having speakers wired in parallel to an amp can be very detrimental as the current demands goes up which can drive the amp into protection mode at best and at worst break something in the amp. Those speaker switch panels you see at various audio shops and home installations have internal resisters to balance out the loading presented to the amp. |
03-08-2017, 11:28 AM | #53 | ||
Rep 8,942
2022 Macan S
03-08-2017, 12:04 PM | #54 | |
Rep 3,241
I already have panels through out the front and side walls of my room...also the ceiling too. I don't have carpeting in this room which seems counter intuitive to many people. I consulted a company out of Richmond, VA called Acoustical Solutions. In fact, they have my room featured on their website. The owner said he was concerned about making the room too dead as that's not what you want for musical reproduction. He advised the use of acoustical panels along with rugs and other things to do spot treatment of any sound issues. I'm glad I followed his advise as he has been spot on. I have no desire to change anything in my system...even though B&W has come out with the Nautilus S series and now the D (diamond) series even though I have the original Nautilus speakers. |
03-08-2017, 12:35 PM | #55 | ||
Rep 1,014
Some points of consideration as I have similar setup but have used diff solutions you may want to consider. I have a 7.1 for my home theater and then use sonos for everything else. I wouldn't suggest 8 speakers on a sonos connect as the power would not be there. What you want to also consider is how you are going to use the system,meaning do u want discreet control by room which is what I did. I have 7 sonos zones for separate controls that make things very easy. For outside I use a sonos attached to an Episode amp to drive 4 outdoor speakers, and use a niles controller to split them and allow control of the two pairs separately.
'22 X4 ///M Competition…Carbon Black Metallic/Sakhir Orange...pure driving excitement!!! ‘22 X3 Jetblack + some other stuff not from Munich
Dearly departed...'19 X2 M35i Past lives ‘16 M3…'13 640i GC...'13 335i...'08 M6 ...'05 645Ci...'00 323i...'85 735i...'77 630CSi...'86 325es ...'01 740iL...'09 X3 |
03-08-2017, 01:58 PM | #57 |
Rep 8,942
Just make sure your ceiling speaker "rears" are in the right spot or everything will get muddled if too close to front. If your joists are running perpendicular to your TV wall you can move them back very easily if needed. Parallel your ceiling is in for a world of hurt.
03-08-2017, 02:13 PM | #58 | |
Rep 11,139
03-08-2017, 03:06 PM | #59 | ||
Rep 8,942
Snap AV makes some decent in wall speakers for your other rooms. Think eclipse is the brand they sell under. While you're poking around give those a look.
2022 Macan S
03-08-2017, 03:52 PM | #60 |
Big Beaver Smile
2101
Rep 3,791
Reading this thread made my head spin. I love music but I am not a true audiophile that can hear slight variations in pitch. I also live in a small town with houses that are close together so you really can't blast your music too loud. Last year I decided to ditch all my fussy components, wires, remotes and tweaking for 1 or 2 Sonos 1,3 or 5 in each room, each bathroom and covered porch, 5:1's for our 2 bigger TV sets and now have really easy to use decent music throughout the house without a hassle and I can't be happier.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
03-08-2017, 05:04 PM | #61 | |
Rep 8,942
2022 Macan S
03-08-2017, 05:36 PM | #62 | ||
Big Beaver Smile
2101
Rep 3,791
03-09-2017, 01:52 AM | #63 | |
Rep 11,139
wrickem2101.00 |
03-09-2017, 02:01 AM | #64 | |
Rep 11,139
03-09-2017, 07:42 AM | #65 |
Rep 1,014
I mean that the power is not there to drive 8 speakers effectively from a sonos connect amp, but yes if you are using the sonos module connected to a power amp, that works,,though you will only have one input source for all speakers. I have mine set up so that each room can have its own sound/source or all can be used to play the same source. So if you have a party, maybe you have the game on and want to hear it in a few zones, you can do that,then up the kitchen or dining areas, you can play other music, the in bathroom maybe something different, and then outside you may choose somethings different still. I enjoy the flexibility and always have sound on throughout the house
03-09-2017, 09:02 AM | #66 | |
Rep 11,139
