06-12-2019, 10:14 AM | #23 | |
Rep 3,241
Another option is Ecobee. Personally, I hate everything being cloud based for these smart devices. I can figure out how to set up my network to provide remote access. That's why I refuse to use any of the cloud based security cameras from Ring and the like. Very happy with my Hikvision equipment and soon will be buying some LTS equipment. |
lsturbointeg9151.00 |
06-12-2019, 10:16 AM | #24 |
Rep 3,241
The Honeywell thermostat I have does all that (current temp, set temp, and time) but will also show what the outside temperature is based on what you program in as your zip code.
06-12-2019, 05:26 PM | #25 | |
Rep 5,984
06-12-2019, 06:24 PM | #26 |
Rep 440
Drives: 2013 335i xDrive
"The right of the people to be secure in their persons, houses, papers, and effects, against unreasonable searches and seizures, shall not be violated, and no warrants shall issue, but upon probable cause, supported by oath or affirmation, and particularly describing the place to be searched, and the persons or things to be seized."
For a dang good reason - if the Government can spy/store/analyze, they will. And spy/store/analyze they do - https://en.wikipedia.org/wiki/Utah_Data_Center The 4th Amendment says the Government can't force you to give up your deep, dark secrets without a warrant, but if you voluntarily give the details of your private life to the Government in the name of convenience, well, allrighty then. Me? I personally don't do "cloud" anything. "Cloud" is just a fancy term for somebody else's computer. A "somebody else" you will never meet, you don't know and probably don't even know where they are. Having said that - I do have a smart home, well, sorta. I custom designed mine. I'm using an Allen-Bradley SLC500. My attic vents open/close with preset temp limits, same with my foundation vents. I water the lawn, clean the pool, drain the hot tub, all with the push of a button and no internet, no "cloud". Motion sensors inside the house keep track of me and if the outside sensors get tripped while I am inside, it tells me the pizza is here.
06-12-2019, 06:50 PM | #27 |
Rep 3,241
The Honeywell thermostat is much larger than the Nest thermostat. So based on screen real estate, the Honeywell can display more. And all that information is displayed regardless of whether the system is on cool or heat mode. I also see the strength of what the thermostat sees as the wireless signal strength from my wireless access point. That same information is also presented on the smart phone app sans the wireless signal strength. Not sure if the Nest app does this.
2000cs3495.00 |
06-12-2019, 08:59 PM | #28 | |
Rep 5,984
06-12-2019, 10:15 PM | #29 |
2006 TIME Person Of The Year
9720
Rep 6,445
First- I've been a sales executive in the consumer electronics (mostly specialty/limited-distribution AV brands) segment since 2002. Smart home technology has been my exclusive focus since late last year, as that's when I joined the North American team at Loxone. Call me biased, but I genuinely believe Loxone is providing an experience at least a generation ahead of every other smart home (aka: automation) system available. Life is literally easier when living in a Loxone Real Smart Home.
Let me know if I can help answer any questions. www.loxone.com
06-13-2019, 08:16 AM | #30 | |
Rep 513
06-13-2019, 08:19 AM | #31 |
Rep 975
IOT devices and the word "security" do not belong in the same sentence. If you really care about security, you wouldn't go down this path. If you are ok with sacrificing security for automation, then like others have said, ensure it works locally without internet and disable any remote management tools.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
06-13-2019, 08:41 AM | #32 |
Rep 2,385
I'd be interested too. I'm at this stage planning to put Savant into my home later this year but am open to better options.
06-13-2019, 08:57 AM | #33 | |
9720
Rep 6,445
06-13-2019, 09:22 AM | #35 | ||
Rep 513
06-13-2019, 10:00 AM | #36 | ||
9720
Rep 6,445
Loxone is completely different. Instead of being a control system, we are more accurately described as a true "automation system." The design goal for a Loxone Real Smart Home is to improve your life by autonomously handling ~50,000 tasks per year for you. Besides delivering a true improvement in your life, it also saves your most-valuable resource... Your time. For a moment, think about the automotive industry. in the 1990s, cars didn't leave the dealer with a lot of creature comforts. It was commonplace to bring your car to a shop to put in a third-party audio system, perhaps a third-party alarm with remote door unlocking/locking, and maybe remote starting. You manually turned on/off your headlights. You manually turned on/off your wipers. Even the aftermarket alarm system required you to take your keys out of your pocket to hit the fob to unlock your doors or open your trunk. You likely manually controlled your HVAC system too. This is the current state of the home building industry. Unless you have a custom home built for you, builders expect that you're going to add "aftermarket" smart home systems after the sale. We at Loxone are working to change this reality. At least 50% of my time is spent meeting with architects, builders, designers, etc., to get them to bring their homes into the 21st Century by incorporating smart technology in their designs. A Loxone Real Smart Home automates your lighting, HVAC, energy system (solar/wind generation, battery storage), is a much, much more advanced way than those control systems. This brings efficiency and higher performance. You can think of what we're doing is akin to adding automated systems to your home that you already take for granted in the automotive space. Let's talk a couple of specific examples of our unmatched system intelligence ... HVAC: A Loxone system doesn't use a conventional thermostat. We measure temperature and humidity at every control pad (light switch). We then use a relay in our MiniServer (main processor) to activate/deactivate the air handler. This forgoes a separate thermostat you have to buy and put someplace. Additionally, we use the occupancy sensors we already are using for lighting to tell us if we have to send HVAC to a particular room/zone. You may be thinking... ZONE? Yup! We offer motorized dampers that go on the HVAC ductwork that allows a single air handler to be divided up into multiple zones on HVAC. This provides a computer-controlled distribution of HVAC where it's needed and not where it isn't. Additionally, we often incorporate window/door sensors to prevent sending head/AC into a room with an open window. Window Shades: A Loxone system knows the longitude and latitude of the home, so it knows where it is on the globe. When we incorporate shades, we tell the system the direction the shade roller is facing in relation to North. This information can then be used to automate shades in relation to the position of the Sun. As the Sun moves across the horizon, shades can autonomously move to block the Sun. Additionally, the same occupency sensor mentioned above can keep the shades down if nobody is in a room. Electric Vehicle Charging: Loxone has an exclusive agreement with BMW that brings enhanced functionality when BMW's best charging station is used, but even if you own a Tesla or Leaf, we bring advanced capabilities. With BMW's charger, we know the specific EV user has arrived, so the home can tailor itself to that particular user. I think of this as the EV charging equivalent to driver profiles automatically selected by a particular keyfob. The difference being the home adapts to the specific user. With any EV charger, we can set rules around conditions. Perhaps you only want to charge your EV when generating power from your solar panels? Environmental Awareness: Want to automatically retract your motorized awning if the wind picks up? No problem! How about we lower some shades if it gets really hot outside? We can easily do that. This only scratches the surface. There is so much more, but I have to run to a meeting. I'll pick this up later.
06-13-2019, 10:00 AM | #37 |
Rep 5,984
For cloud devices which I think are where everything is headed you need to use a strong password and maybe 2factor authentication. This will help prevent anyone accessing your account.
06-13-2019, 10:18 AM | #38 |
9720
Rep 6,445
The flaw in this (beyond privacy) is you lose functionality when you lose communication with the cloud.
06-13-2019, 10:26 AM | #39 | |
Rep 5,984
06-13-2019, 10:38 AM | #40 | ||
9720
Rep 6,445
As for direction, I guess I have a different perspective. Loxone is the most-advanced system available and it doesn't rely on the Internet for anything other than off-site app control. We only even need a LAN for in-home app control. In other words- your entire LAN can go down and a Loxone Real Smart Home can still fully function. That is completely unique. The side benefit is you don't need to invest in better network components like you would with a system relying on the LAN for communication.
06-13-2019, 10:50 AM | #41 | |||
Rep 513
For instance, say you have a Jandy or Pentair pool controller. Can you natively control? Does Loxone make its own pool controller? Another example. Sure you can control your own lighting but i would be reluctant to use a relatively new company for such a vital system when Lutron had robust, reliable systems and its much more likely they will be around and support in 10-20 years. Really just trying to understand how this is any different or just marketing spin. No offense, honestly interested. Also, to address the post below none of the aforementioned automation systems require internet connection either. |
06-13-2019, 10:51 AM | #42 | |||
Rep 5,984
06-13-2019, 11:18 AM | #43 | |
Rep 1,268
There is already case law on companies trying to go after someone for sharing trade secrets. The court have said unless the company can show they taken every precaution to protect the information they can not go after someone for share information if the company did not have history of doing everything they could to protect it. You can see someone in government saying you have no reasonable expectation of privacy since Google knows, and Alexia knows, Nest Knows everything you are doing in your house and especially in the bedroom and you openly invited them in so why would you expect to have privacy. We already have the government fighting to gain access to your locked iPhone. and they want to see every bad thing you make have recorded on your iPhone. Last edited by Maestro; 06-13-2019 at 12:10 PM.. |
06-13-2019, 12:06 PM | #44 |
Rep 1,268
I have doing doing home automation since the 80's staring with X10 and I also did some playing around with industrial automation (control systems) PLC's. Today I only have a couple of items set up to automatically doing things in or around the house. Why and this is important for anyone who is married and your significant other has no tolerance for things not working all the time and are simply to use (does not require an engineering degree to understand). Because of this when I personally have done home automation the one thing I look at is does it pass the KISS wife test (Keep It Simple Stupid or alternation Keep It Stupid Simple) in either case you are the Stupid in those statements.
As one person said, you really want to have only one system from one company, when you trying to mix and match, things start coming apart. I personally been playing with Insteon, it is pretty good does lots of things and its has home kit compatibility and it has been around a long time so they solved lots of the problems, but it has it KISS issues. Here are some simple examples I have seen with many of these systems.
This list goes on and I tell anyone who is considering "automating" your house to keep this in mind. It will be fun for a while until the wife gets pissed off it does not work right today. I have my outside landscape light go on at sunset, and turn off at midnight, I have programable Thermostat that helps keep conditioning costs down and have a simple override when wife feels it is too hot or cold. My theater room is almost completely automated (controlled) with a hit of one button on the wall it turns on all the right equipment for what you want to do and dims the lighting accordingly. This also has an iPhone app which anyone in the house can easily control from their phone if they like but I have standard Harmony smart remote for people who do not wish to use an iPhone (easy enough for my 90 yr Old father-in-law to turn on the baseball game when he is over to visit. Beyond this I have nothing else, everything else works off the old fashion wall switches that any person knows how to use. I do have one IP camera looking at the outside of house, the wife want no cameras of any sort in the house, she does not want to worry that it recorded something she not interested in anyone every seeing. If you ever had to help someone clean out someone's home you do not want others seeing what you may not want them knowing about you. Yeah you may be dead but it may paint a picture in your kids mind you my not want them having. Last edited by Maestro; 06-14-2019 at 07:26 AM.. |
