      09-24-2019, 06:17 AM   #1
bmwfreek
Drives: BMW 530i
Smile BMW 530i E60 problems - shaking and smoking
Hi All,
I hope someone can help. First I like to say sorry for my bad english, but I hope you can understand.
I have following problem with my BMW 530i E60.
- The car shakes ia lot
- The car smoke a lot (white smoke)
- The car smells of gasoline from the exhaust
- If car idling and push the gas there become black smoke from the exhaust.
- Use 1 liter oil on 1000 km.
The car mechanic all tell me different. The following is what they tell me.
- Injector
- Valve stem seal
- Cylinder head
- Catalyst
- Lambda Sensor
Carly tester shows following:
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 2F0D:Kuehlerjalousie, triggering, (GLF) ***
*** 2AAF:Fuel pump, plausibility ***
*** 2CAA:Lambda probe upstream of the catalyst, temperature ***
*** 2CA6:Heating lambda probe upstream of the catalyst, function ***
*** 2C77:Lambda probe on the catalyst, signal ***
*** 2A2C:Mixture control 2 ***
*** 29CD:Misfiring, Cylinder 1 ***
*** 29CE:Misfiring, Cylinder 2 ***
*** 29CC:Misfiring, several cylinders ***
*** 29CF:Misfiring, Cylinder 3 ***
*** 29F1:Fuel pressure plausibility ***
*** 2C7C:Lambda probe downstream of the catalyst 2, Signal ***
*** 2CA8:Heating lambda probe on the catalyst, function ***
Tags
bmw 530i e60
