06-08-2009, 01:09 PM | #1 |
Rep 1,217
Air France
Is anyone else concerned that a very modern, fly by wire, double aisle jetliner seemingly fell out of the sky over the ocean after encountering routine weather and turbulence?
We all know that air is the safest way to travel. But I really hope they find the black box and data recorder so steps can be taken to prevent this tragedy again. Last edited by DenverJayhawk; 06-08-2009 at 05:12 PM.. |
06-08-2009, 01:22 PM | #4 |
ahat
1036
Rep 2,592
As with most circumstances with airflights that go down, it is likely a combination of events that were not likely to be seen in any testing (let alone system design) scenario. They will find what were those series of events and implement a combination of technology and procedural changes to account for it.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
06-08-2009, 01:22 PM | #5 |
I am Gundam
186
Rep 1,211
06-08-2009, 01:24 PM | #6 |
Rep 4,649
http://m3post.com/forums/showthread.php?t=268494
from my background where studying aviation accidents was part of the curriculum, this is a very puzzling accident. what is clear is the plane did suffer a mid-air breakup, but there are several things that could have led to that. weather, electrical, the pitot tubes, pilot error, or possibly a combination of several things. the black boxes will be need to be found to come up with an explanation, but i'm having severe doubts that they will be found at this point just due to their difficult geographic location on the sea floor. |
06-08-2009, 01:24 PM | #7 |
Rep 1,217
A jet like the A330 is absolutely state of the art. Everything is double and triple redundant, especially the flight control systems. It's scary to think an electrical gremiln can bring down a fully modern jet, even in bad weather.
Thank god airliners don't have HPFP problems. |
06-08-2009, 01:27 PM | #9 |
エアーマンが倒せない
271
Rep 2,041
Could it have been an external attack?
06-08-2009, 01:27 PM | #10 |
Rep 1,217
Lightning strikes occur ALL the time. It NEVER brings down a jet, especially one cruising at 35k feet.
06-08-2009, 01:28 PM | #11 |
Rep 4,649
06-08-2009, 01:35 PM | #12 |
Rep 17,316
Drives: E92 M3, E30 325i
i have a fear of flying and a couple months ago i flew out to kansas to see my gf but only after watching the fear of flying video online. One portion of the video explained how sturdy the plane was and how the wing couldnt just snap etc... and now after hearing that this plane broke apart midflight makes me pretty damn nervous again..esp with it happening to a modern jet. it took me so long to take a step forward in flying and it took reading about this crash to take a big step backwards. sucks
06-08-2009, 01:38 PM | #13 | |
Rep 4,649
you tell me if that's strong enough or not. although that is not an A330, i wouldn't be surprised if you saw similar results out of the A330. an A330 is the airbus equivalent of the 772/767, although the french made the A330. case in point, airplanes are very strong and capable of great loads. a 777 being able to carry 154% of it's designed maximum load is a staggering number. Last edited by Blake; 06-08-2009 at 02:13 PM.. |
06-08-2009, 03:02 PM | #14 | |
Rep 17,316
06-08-2009, 03:21 PM | #15 |
Rep 2,324
in one of the reports I read they said the plane suffered from a massive depressurization....so something would have had to comprimise the integrity of the fuselage...which would have led to a mid-air breakup which most suspect. Are they for certain the plane broke up in mid-air?
"You will get there, but it is up to you and you alone. It is what you are willing to do, and how you are willing to get there. You must be relentless, you must be tireless, you must pursue at all costs, so that you are ready, when the time is right." -Dad
06-08-2009, 03:39 PM | #16 | |
Supreme Allied Commander
1963
Rep 61,781
Drives: A BBS WHORE
not 100% conclusive...but it will give you some sort of idea.....
06-08-2009, 04:05 PM | #17 |
Trance Life
315
Rep 4,706
gahh.....this is just so terrible....i can't even imagine the pain the families are going through.....
not only do they not know what happened to their loved ones, but the reality of it is it's something horrible... |
06-08-2009, 04:26 PM | #18 | |
Rep 4,649
one theory involves the questionable pitot tubes and their susceptibility to icing in high altitude storms. (a pitot tube measures ram air pressure which is then interpreted to airspeed) when your pitot tube ices over, you lose accurate airspeed indications, if you even get a reading at all. it is plausible that the pitot iced over and the pilots sped up to counteract the erroneous readings. overspeed at high altitude can be a critical situation which could lead to breakup, exacerbated by turbulence inside a storm. at this point, the only thing we can do is guess. there are dozens of scenarios that are being played out, but no one will ever know without getting the onboard data. |
06-08-2009, 04:38 PM | #19 | |
1963
Rep 61,781
Drives: A BBS WHORE
or they can prove if the plane stalled or overspeed-stall (not sure the correct term)....something that cause the air flow to detach from the wing.....
06-08-2009, 04:42 PM | #20 | |
Rep 4,649
conversely, a person dies from a motor vehicle related accident every 13 minutes, 24/7, 365 days a year. kinda makes you want an airplane now, doesn't it? the biggest reason people fear flying is because of the accidents and the associated anxiety of "it's going to happen to me!" but you have greater odds of getting hit by lightening TWICE than dying in an aircraft accident. flying is totally safe, but having said that, accidents do happen in any facet of life. yes, more people can die at once in plane accidents than cars, but the numbers are measly compared to, say, cars. Last edited by Blake; 06-08-2009 at 05:00 PM.. |
06-08-2009, 04:47 PM | #21 | |
Rep 4,649
06-08-2009, 05:07 PM | #22 | |
1963
Rep 61,781
Drives: A BBS WHORE
example....Air France A340 that skid off runway in Toronto....
