04-06-2021, 12:30 AM | #23 |
Rep 868
To access the Junction Box/Front Fuse panel (Z7)? Need to drop the passenger side bottom panel, which also has the knee airbag, and to the right of the glovebox, you will see the fuse panel...see picture below...
If on the other hand you are trying to get to the lighter harness in the center console, you may be able to quickly access it on the passenger side center console, after removing the lower carpet panel...else you will need to remove the top two center console pieces (two piece design - rear portion is the shifter, the front portion is the ash tray) Last edited by M_Bimmer; 04-06-2021 at 12:47 AM.. |
04-06-2021, 12:46 AM | #24 |
Rep 96
Should I put wires under the fuse ? Or have to connect into the empty spots ?
04-06-2021, 01:15 AM | #26 |
Rep 96
04-06-2021, 06:57 AM | #30 |
Rep 96
This is the one right ? Just upside down.. or no ? It is the evo id4 and no any black / white wire .. empty slot
04-06-2021, 07:54 AM | #31 |
Rep 96
Ok now I know the nbt evo has no pin for "Radio on" signal.. still in hope that I will be able to connect it somehow the way , when speaker goes up if a HU is on and down when off
04-06-2021, 02:37 PM | #32 |
Rep 868
Sorry....catching up...can you re-ask the question that is still relevant?
Radio_On Signal: NBT EVO + Active Sound: A42.1B Pin 13 Black Wire to Active Sound A233.1B Pin 10 NBT EVO + HiFi: A42.1B Pin 13 Black Wire to A37 Amp A37.1B Pin 10 Last edited by M_Bimmer; 04-07-2021 at 12:54 AM.. |
x5wntd55.50 |
04-06-2021, 04:11 PM | #33 |
Rep 96
Do you have a pic of it? Bc the one you mentioned before is for NBT old one, the evo has different pinout. And yes , since the fuse box is way too far , gonna catch a lighter! Still in process. Thanks again for ur help!
04-06-2021, 09:32 PM | #34 |
Rep 868
I am looking up the wiring on TIS for you...and on my last post provided what TIS states is the Radio_On signal connector/pin assignment per the NBT EVO....so if you can't find it on the radio unit, then I know it's available on the AMP in the left rear of your luggage compartment....
My F85 already has B&O so taking a picture of mine probably won't help.... Let me know how else I can assist.... |
04-07-2021, 12:12 AM | #35 |
Rep 96
Bang and Oufson top speaker dash removal?
04-07-2021, 01:11 AM | #36 |
Rep 868
Based on the wiring on your A42.1B connector, it neither has HiFi nor Active Sound.....since your pin 13 isn't populated.
Maybe you could check to see if your radio still produces the "Radio_On" signal and you could populate a wire in slot 13..... Also, this thread is on the F10 M5 forum and you're asking about the F15 X5...so I had to go back to all the previous posts and update to reflect the F15 and not the F10...similar systems, but their connectors references and wiring colors are slightly different.... Last edited by M_Bimmer; 04-07-2021 at 01:16 AM.. |
x5wntd55.50 |
04-07-2021, 02:08 AM | #37 | |
Rep 96
04-07-2021, 09:57 AM | #38 |
Rep 146
How do you fix that buzzing sound from the front center speaker? Sometimes on acceleration at a certain RPM. Didn't the TIS document say put some extra tape somewhere underneath?
2014 Frozen Silver M5, CP, B&O, 601s
1995 Mustang Cobra - 347 stroker |
04-07-2021, 04:55 PM | #39 | |
Rep 96
UPD actually it has power , but not the "Radio_on" one. Goes up when I unlock the car and down 2 mins after lock. Gonna try to find a pin connected with the screen. I want it goes up when the screen turning on (ignition switched on) and down when the screen turning off. Wish it's possible |
04-07-2021, 08:02 PM | #40 | |
Rep 868
You have obviously the NBT EVO system, but your radio is the basic? Speakers driven directly from the radio, no amp? Let me look at the schematic again to see if there is another signal to tap. [EDIT: So if you have a basic radio, no speaker amp, then there is no signal to tap....you'll have to get creative] Last edited by M_Bimmer; 04-07-2021 at 09:41 PM.. |
04-07-2021, 11:44 PM | #41 | |
Rep 96
04-09-2021, 09:29 AM | #42 |
Rep 96
04-09-2021, 04:16 PM | #43 | |
Rep 868
Went out to check, but I don't have a lighter element in my lighter sockets.... I'd look at VO enabling the HK speaker system to see if your speaker basics still work AND Pin 13 Radio_ON becomes active...(note PIN 13 is used by the external Amplifier for the HK and B&O systems)...but this is just a thought. You can actually power on/off the radio w/o hitting the start/stop button....and it too shuts off in 12-min if no other actions are taken within the vehicle (need to look in the User's Manual to verify) |
04-13-2021, 11:57 AM | #44 |
Rep 96
