BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    G-Power V2 downpipes and tune
      02-17-2019, 10:48 PM   #1
Bman14665
Drives: 2018 F90 M5
I installed G-Power's V2 "750hp" tune and downpipes (with a single sports catalyst on each downpipe) on my 2018 M5. I also installed an Eventuri intake and Eisenmann standard exhaust with their non resonated center section. Here are my results (same dyno, stock vs after all mods, 5th gear, ECM Dynocom Dyno).
Stock:
569 wheel hp
544 wheel ft/lbs
80 db peak sound idle reving
After Mods:
671 wheel hp
674 wheel ft/lbs
84 db peak sound idle reving
Drivability is great, outside the increased exhaust noise you can't tell it isn't stock until you go deep into the throttle. Car is much louder now with much more turbo noise coming from both front and rear. Idle reving does it no justice, the car needs to be under some load to understand how it sounds. I haven't seen much posted on G-Power so I thought I'd share my results.
If you are interested talk to Edmond at EasyB Car Solutions in Katy Texas. He is an authorized US G-Power dealer and can upload the tune remotely. I did mine from Florida remotely with him. Great customer service, I highly recommend him if you want to go with G-Power.
      02-18-2019, 01:37 AM   #2
Pimpsy
Drives: 2019 M5C
Sick numbers
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      02-18-2019, 06:29 AM   #3
MCOMP
MCOMP's Avatar
200
Drives: 19' M5 Comp.
Welcome to the forum, thanks for the info, Great numbers, about how much was the investment?
2019 MBB/Aragon M5C
M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp
      02-18-2019, 02:07 PM   #4
Bman14665
Drives: 2018 F90 M5
Was about 8k for catted downpipes and tune but G-Power was running a 35% off sale on the tune when I bought. EasyB's prices are totally reasonable. If u check out G-Power's website and change the euro sign to dollars that is about what u will pay.
      02-18-2019, 02:35 PM   #5
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
Stock:
569 wheel hp
544 wheel ft/lbs
After Mods:
671 wheel hp
674 wheel ft/lbs
Excellent numbers... and thanks for posting the before+after--that really helps determine the legitimacy of the tune!
I only wish we could see the incremental gains at each step. I don't suppose you have that do you?
      02-18-2019, 06:52 PM   #6
Bman14665
Drives: 2018 F90 M5
Sorry, I don't have incremental dyno numbers. The dyno is about 50 miles from my house plus I suspect the Eisenmann exhaust and Eventuri intake are mostly a sound upgrade. I'm sure most all of the gains are from the downpipe and tune.
      02-21-2019, 10:36 AM   #7
M5speed
Drives: 2020 BMW M5
Why not go for the turbos also with all this?
I assume then this replaced the upper and lower downpipes both?
Also was there any thought as to going with sport cats vs no cats? I guess it should pass emissions then and reduce the chances of the fumes, right?
      02-21-2019, 08:11 PM   #8
Bman14665
Drives: 2018 F90 M5
I just didn't want to drop the money on the new turbos. The car sounds right and is silly fast, couldn't justify the big extra cost for 50ish more hp.
I thought about going catless but I was concerned it might be too loud and I wanted to give it a chance at passing emissions without throwing the stock hardware back on.
It does replace the upper and lower downpipes with a single piece. It has a single high flow cat where the stock upper sits. No lower cat. Fit was perfect. I was able to swap them out myself in about 6-7 hours.
      02-21-2019, 10:38 PM   #9
Rennology
Rennology's Avatar
Drives: IG @rennology
So you did Eisenmann performance? Any videos?
      02-28-2019, 08:39 PM   #10
TrevorM3
Drives: 6.3 AMG
where in florida are you?
      03-01-2019, 09:02 PM   #11
Bman14665
Drives: 2018 F90 M5
Beck, working on getting the right permissions to upload some exhaust vids.
TrevorM3, near Pensacola
      03-08-2019, 08:39 PM   #12
Austin_2019_X5_50i
Austin_2019_X5_50i's Avatar
10
Drives: 2019 BMW X5 50i G05
I just did a Velostune stage 2 and got 545WHP from the dyno. I need to get these downpipes but they are about $2700-$5K. How much more WHP do you think I will get if I install these downpipes?
      03-08-2019, 08:42 PM   #13
Austin_2019_X5_50i
10
Stock:
569 wheel hp
544 wheel ft/lbs
After Mods:
671 wheel hp
674 wheel ft/lbs
The 2018 M5 has 600HP (crank). How can it have 569 WHP stock? You lose 15%.
      03-08-2019, 08:46 PM   #14
Bman14665
Drives: 2018 F90 M5
Crank numbers will vary Dyno to Dyno
      03-08-2019, 08:49 PM   #15
Bman14665
Drives: 2018 F90 M5
I'm not sure exactly how much you will pick up by installing downpipes with a proper tune. I'd guess about 50 more than a tune alone.
      03-08-2019, 09:06 PM   #16
Austin_2019_X5_50i
10
Dynos don’t provide crank numbers. They provide HP/TQ at the wheels.
      03-08-2019, 09:07 PM   #17
Austin_2019_X5_50i
10
I got about 150 WHP with the tune. So you think I can expect 50 more WHP?
      03-09-2019, 10:35 AM   #18
Austin_2019_X5_50i
10
Hello......
      03-09-2019, 11:23 AM   #19
onfireX5
Drives: F90M5,F85X5M
Hello......
Highly doubt it. Hard to find M5 before and after cat delete dyno's, but on the C7 Z06 with 650 HP there
is 15-20rwhp max. M5 will spool the turbos quicker without cats, but the DME targets total airflow so the gain up top will be limited. If I were in Vegas, the F90 bet would be 15 rwhp maximun due to the DME.
      03-09-2019, 03:58 PM   #20
Austin_2019_X5_50i
10
So you think I’m only going to get 15 more WHP? It’s awd so should I expect 15 in the front and 15 in the back? Everyone thinks I will gain about 40-50whp but you think bc of the DME noticing airflow it will react and adjust so I’m not getting as much airflow as I could be? I want to get DP’s that let maximum air but just a little noise from exhaust and turbos. Basically sound stock until I step on it. I was planning on getting catalysts downpipes not catless. Your thoughts??
Thanks!
      03-09-2019, 07:44 PM   #21
onfireX5
Thanks!
Thanks to Miko, I've had both sets of stock cats on my flowbench. They flow better than a 2.50" open pipe but less than a 3.00" open pipe. My guess is 15rwhp total. I'd stay stock or open pipe for additional spool. Not much to gain by adding an aftermarket cat.
Miko M6655.50
      03-09-2019, 08:24 PM   #22
Austin_2019_X5_50i
10
I have two turbos in my X5 that have been tuned and your recommendation is to stay with stock pipes? The airflow is being restricted with these stock dp’s And exhaust. All I ever hear is “get your car tuned with downpipes”... You’re the first person to advise this. Anyone else want to chime in??
Tags
eisenmann, eventuri, f90, g-power, tune
m5post
