05-31-2022, 11:41 AM | #1 |
Rep 21,325
BMW Model Update Measures as of Summer 2022 (Global)
BIMMERPOST NEWS BMW model update measures as of summer 2022 May 31, 2022 Munich. Raised efficiency, an even higher level of individuality and further digitalisation will make the numerous current BMW brand models even more attractive as of summer 2022. The model range of the new BMW 2 Series Active Tourer is being expanded by two plug-in hybrid variants and a diesel model with intelligent all-wheel BMW xDrive. Two additional drive variants each will be offered for the new BMW 2 Series Coupé and the new BMW 4 Series Gran Coupé from July 2022. Newly designed equipment packages make it easier to select options for enhancing driving pleasure and comfort in numerous model series. The BMW Curved Display will be added to the standard equipment of the new BMW 2 Series Coupé and the new BMW M3 Sedan in summer 2022. This means that the latest generation of the BMW iDrive multi-sensory vehicle experience based on the BMW Operating System 8 has also found its way into both model series. Further progress in the field of digitalisation is provided by additional functions for the My BMW App, the BMW Maps navigation system and the BMW Intelligent Personal Assistant. BMW 2 Series Active Tourer: Premiere for two plug-in hybrid models and a new diesel engine with 48-volt mild hybrid technology. The new BMW 2 Series Active Tourer has already been available with a wide range of drives since it was first launched on the market equipped combustion engines from the current BMW Group Efficient Dynamics generation and the latest version of 48-volt mild hybrid technology. In future, two plug-in hybrid variants of the compact all-rounder will deliver additional efficiency and driving pleasure. The hybrid systems of both models combine a 3-cylinder petrol engine with BMW TwinPower Turbo technology which drives the front wheels with an electric motor acting on the rear wheels. Like the high-voltage battery located deep in the vehicle floor, this electric motor originates from the fifth generation of BMW eDrive technology. The resulting hybrid-specific all-wheel drive delivers a very high level of sportiness, driving stability and traction in all driving situations. The drive of the new BMW 230e xDrive Active Tourer (fuel consumption combined: 0.8 – 0.6/100 km; combined power consumption: 15.9 – 14.4 kWh/100 km; combined CO2 emissions: 18 - 14 g/km according to WLTP; data according to NEDC: - ) generates an output of up to 240 kW/326 hp (jointly generated by the combustion engine with up to 110 kW/150 hp and the electric drive with up to 130 kW/177 hp). This means that the more powerful of the two plug-in hybrid models sprints from a standstill to 100 km/h in 5.5 seconds. Its electric range is 82 to 93 kilometres according to WLTP. With a maximum output of up to 180 kW/245 hp (jointly generated by the combustion engine with up to 100 kW/136 hp and the electric drive with up to 80 kW/109 hp), the plug-in hybrid system of the new BMW 225e xDrive Active Tourer (fuel consumption combined: 0.8 – 0.6/100 km; combined power consumption: 15.8 – 14.2 kWh/100 km; combined CO2 emissions: 18 - 14 g/km according to WLTP; data according to NEDC: - ) accelerates from zero to 100 km/h in 6.7 seconds. With values between 83 and 92 kilometres according to WLTP, it also has a significantly increased electric range compared to the previous model generation. In addition, the maximum charging capacity has been doubled when using a wallbox or public charging station. It is now 7.4 kWh. This allows the high-voltage batteries of the two plug-in hybrid models to be charged from zero to 100 percent of their capacity within 2.5 hours. The third new addition to the drive portfolio is a 2.0-litre 4-cylinder diesel engine combined with 48-volt mild hybrid technology. The new BMW 223d xDrive Active Tourer (fuel consumption combined: 5.1 – 4.6 kWh/100 km; combined CO2 emissions: 133 - 121 g/km according to WLTP; data according to NEDC: - ), delivers a maximum output of 155 kW/211 hp (generated jointly by the combustion engine with up to 145 kW/197 hp and the electric drive with up to 14 kW/19 hp) as well as a maximum torque of 400 Nm (generated jointly by the combustion engine with up to 400 Nm and the electric drive with up to 55 Nm). The electric motor of the mild hybrid system is integrated into the 7-speed Steptronic transmission with double clutch and functions as a crankshaft starter generator. The power of the drive system is transmitted to the road via BMW xDrive intelligent all-wheel drive. The BMW 223d xDrive Active Tourer takes 7.3 seconds to accelerate from zero to 100 km/h. BMW 2 Series Coupé: Two new drive variants, BMW Curved Display and shifter paddles on the steering wheel now standard. A new entry-level engine and another BMW Performance automobile from BMW M GmbH enrich the model range for the new BMW 2 Series Coupé. A particularly economical way to experience the distinct driving pleasure of the compact two-door is offered by the new BMW 218 Coupé (fuel consumption combined: 7.1 – 6.5 litres/100 km; combined CO2 emissions: 160 - 146 g/km according to WLTP; data according to NEDC: - ), which is powered by a 2.0-litre 4-cylinder petrol engine generating a peak output of 115 kW/156 hp and a maximum torque of 250 Nm. The power is transmitted to the rear wheels via an 8-speed Steptronic transmission. The new BMW 218i Coupé accelerates from zero to 100 km/h in 8.7 seconds. The second new model ranges at the highest level of the performance spectrum. The BMW M240i Coupé (fuel consumption combined: 8.5 – 7.8 litres/100 km; combined CO2 emissions: 192 - 177 g/km according to WLTP; data according to NEDC: - ) embodies the purist form of driving dynamics typical of the brand in a model of the premium compact segment. A 275 kW/374 hp inline 6-cylinder petrol engine is now also combined with classic rear-wheel drive in this model series. An 8-speed Steptronic Sport transmission and an M Sport differential in the final drive are also involved in transferring power to the road. This means that the new BMW M240i Coupé reaches the 100 km/h mark from a standstill in 4.7 seconds. For spontaneous manual intervention in gear selection, the new BMW M automobile features shift paddles on the steering wheel. From summer 2022, these paddles will also be part of the equipment package of the 8-speed Steptronic transmission, which is standard on all 4-cylinder models of the BMW 2 Series Coupé. The range's powertrain portfolio now includes three 4-cylinder petrol engines and one 4-cylinder diesel engine, as well as the 3.0-litre inline 6-cylinder power unit, which now delivers fascinating performance in conjunction with both all-wheel and rear-wheel drive. Hallmark BMW driver orientation in the cockpit of the BMW 2 Series Coupé has also been rethought. All model variants of the two-door model will be equipped with a BMW Curved Display as standard from July 2022. It consists of a 12.3-inch Information Display and a Control Display with touch function and a screen diagonal of 14.9 inches. This provides a fully digital and high-resolution display network behind a common glass surface curved towards the driver. With the BMW Curved Display and the enhanced capabilities of the BMW Intelligent Personal Assistant, the user experience in the BMW 2 Series Coupé is now also consistently oriented towards touch and voice control. BMW 4 Series Gran Coupé: Sales launch for two more models with inline 6-cylinder engine. A new BMW M automobile with traditional performance characteristics will also join the model range in the BMW 4 Series in summer 2022. The BMW M440i Gran Coupé (fuel consumption combined: 8.2 – 7.6 litres/100 km; combined CO2 emissions: 185 - 172 g/km according to WLTP; data according to NEDC: - ) will thrill drivers with its combination of an inline 6-cylinder petrol engine with 275 kW/374 hp and mild hybrid technology, an 8-speed Steptronic Sport transmission, classic rear-wheel drive and an M Sport differential. The extremely sporty version of the four-door coupé in the premium mid-size class sprints from zero to 100 km/h in 5.0 seconds. In addition, an inline 6-cylinder diesel engine will also be available for the BMW 4 Series Gran Coupé in future. The 3.0 litre drive unit for the new BMW 430d xDrive Gran Coupé (combined fuel consumption: 6.0 – 5.5 litres/100 km; combined CO2 emissions: 158 - 145 g/km according to WLTP; data according to NEDC: - ) generates a maximum output of 210 kW/286 hp and a maximum torque of 650 Nm. In this model, too, 48-volt mild hybrid technology enhances both efficiency and spontaneous power delivery. The impressive pulling power of the drive, the 8-speed Steptronic transmission and the intelligent all-wheel drive together enable acceleration from zero to 100 km/h in 5.3 seconds. For all BMW M automobiles of the BMW 4 Series as well as for the all-electric BMW i4 M50 (power consumption combined: 22.5 kWh– 18.0 kWh/100 km according to WLTP; CO2 emissions: 0 g/km; data according to NEDC: - ), an M Sport Package Pro is available from July 2022, including an extended M High Gloss Shadow Line, M Shadow Line lights, an M sports brake system with red brake callipers and M seat belts. In addition, the range of paint finishes for the BMW 4 Series Coupé and BMW 4 Series Convertible is supplemented by the Skyscraper Grey metallic variant. Specific customisation thanks to new equipment packages. High-quality options from the range of special equipment available ex works for numerous model series will be combined in new, model-specific configured packages for summer 2022. They enable customers to individualise their cars in specific focus areas. For example, a Travel Package and a Comfort Package are available for the BMW 2 Series Active Tourer. An Innovation Package and a Comfort Package are offered for the BMW 2 Series Coupé. The choice will be particularly varied for the BMW 1 Series and for the BMW 2 Series Gran Coupé, which will be rolling off the production line from July 2022 with a Premium Package, a Travel Package, an Innovation Package, a Comfort Package and a Comfort Package Professional, as well as an M Sport Pro model. New options for BMW 5 Series, BMW 6 Series Gran Turismo, BMW X5 and BMW X6, BMW Z4 with extended standard equipment. An M Sport Package Pro will also be available in future for the BMW 5 Series Sedan, BMW 5 Series Touring and BMW 6 Series Gran Turismo. It is offered as a supplement to the respective model-specific M sports package and includes paddle shifters on the steering wheel for the entry-level models of the BMW 5 Series and an 8-speed Steptronic Sport transmission for all other models, as well as an extended M high-gloss Shadow Line, an M sports brake system with red brake callipers and M seat belts. The BMW 5 Series models also receive the M Shadow Line lights, while the BMW 5 Series Sedan also features a black M rear spoiler. New to the range of paint finishes is the Skyscraper Grey metallic variant, while the new Arctic Race Blue metallic paint finish is also available for the BMW 5 Series. The models in the BMW X5 and BMW X6 series will feature Sensafin decor-quilted interior trim as standard from summer 2022. The newly developed surfaces are available in five colour variants and have leather-like properties as well as a further refined look and feel. Extended standard equipment makes the BMW Z4 even more appealing. The Roadster now already features the BMW Live Cockpit Professional as standard. It includes a fully digital instrument cluster and a Control Display with a screen diagonal of 10.25 inches each, as well as the Connected Package Professional. BMW Curved Display and Innovation Package for the BMW M3 Sedan, M Graphics for the BMW M4 Coupé. BMW Operating System 8 and the latest generation of BMW iDrive, including BMW Curved Display, will also be standard equipment for BMW M3 Sedan models from July 2022. The four-door high-performance sports car can also be optionally equipped with an Innovation Package, a Wireless Charging Tray for suitable smartphones, a Personal eSim, an instrument panel in Sensatec finish and M interior trims in Aluminium Rhombicle Anthracite. The BMW Individual paint finish Frozen Pure Grey metallic is also available as a new colour. A further way of highlighting the performance character of the BMW M4 Coupé models even more intensively is provided by the new M graphics for the engine compartment and luggage compartment lides. The contour lines in high-gloss black and the BMW M GmbH brand logo on the engine compartment give the exterior of the vehicles a particularly expressive touch. My BMW App, BMW Maps navigation system and BMW Intelligent Personal Assistant with extended functions. Driving pleasure and comfort are enhanced in all models already equipped with BMW Operating System 8 thanks to new digital services. As of summer 2022, both the BMW Maps navigation system and the BMW Intelligent Personal Assistant will feature new functions and enhanced capabilities. In addition to new map displays, the navigation system offers proactive traffic information on frequently used routes even when the route guidance is not activated. Calculating a charging-optimised route for all-electric models is now around four times faster than before. The driver receives more detailed information about the route and the planned charging stops, and can also specify the desired state of charge when reaching the destination. In order to make charging the high-voltage battery more convenient at public charging stations, the functions of the BMW Charging App will also be integrated into the My BMW App in future. In addition to logging the vehicle in at the charging station, this also allows the charging cable to be unlocked via the My BMW app, among other things. In future,a further developed charging software for purely electrically driven models will enable the storage of charging profiles for frequently used power sources. In order to increase efficiency when charging, your high-voltage battery can be preheated to an optimal temperature for fast charging with direct current while still on the road. Up to now, this preconditioning has been carried out automatically if the route planned by the navigation system includes a stopover at a fast-charging station. In future, preheating of the battery can be activated manually by the driver even when the navigation system has not been programmed with a route. The registration process for the ConnectedDrive Account will be simplified from July 2022. In conjunction with BMW Operating System 8, it is no longer necessary to manually enter the 17-digit vehicle identification number to register a new vehicle. In the cockpit of BMW M cars, the BMW Operating System 8 will feature an M specific user interface in future. In the BMW iX and the BMW i4, the additional Augmented View display, which can be used with BMW Live Cockpit Professional, is also shown in the Information Display. The BMW Intelligent Personal Assistant, in conjunction with the BMW Operating System 8, will feature even more advanced capabilities as of summer 2022. The digital companion and vehicle expert can proactively make contextual suggestions to the driver on how to use functions. In future, these will also relate to Active Cruise Control with Stop & Go function, Parking Assistant, the eDrive Zone service and the option to test additional functions from the BMW ConnectedDrive Store. In addition, the BMW Intelligent Personal Assistant provides the driver with explanations of numerous other functions of his vehicle that he has not used so far.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
05-31-2022, 12:01 PM | #2 |
Rep 91
Will the m4 also have the curved display? The wording is confusing
Limegrntaln14219.50 Jaron ///M41.00 |
05-31-2022, 12:05 PM | #3 | |
Rep 1,682
I'm planning on ordering the last of the outgoing before it gets the huge screen, I'm not a fan.
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place. Wheel horsepower is just crank horsepower after taxes. IG: EmFore_650 |
05-31-2022, 12:18 PM | #4 | |
Rep 1,364
I'm curious whether the M Graphics on the M4 are optional. It doesn't read like they are.
05-31-2022, 12:20 PM | #5 |
Rep 2,889
Would be nice for pictures of the BMW Operating System 8 will feature an M specific user interface graphics.
I'll be dealing with iDrive 8 in 18 months when it's time to replace the X5M comp. Not looking forward to.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
05-31-2022, 12:26 PM | #6 | ||
Rep 91
05-31-2022, 12:34 PM | #7 |
this is the way
20001
Rep 8,947
05-31-2022, 12:35 PM | #8 |
Rep 923
Everything BMW is doing, is catering to the YouTube digital generation of people. The problem here is that they are behind… other car manufacturers are moving away from full touch screens because they are a nuisance and they just don't look good. If you look at what Porsche is doing they give you a nice balance blend of digital and analog. I don't know why Bmw feels the need to tack on a curved screen on a dashboard it just looks hideous.
I feel like they are being cheap they don't want to produce a proper in laid integrated LED screen's so now what they're trying to do is basically use the same part across all their models. At some point there won't be anything special about buying a full BMW M car besides the horsepower engine transmission differences. |
05-31-2022, 12:45 PM | #9 | |
Rep 55
Do you know if there will be any updates to the 1 series. I've currently got a 128ti on order with a build date of week 29 2022. I'd be really upset if I bought the current model then changes were introduced. |
05-31-2022, 12:51 PM | #10 | |
Moserkm
165
Rep 170
Swappy545.00 |
05-31-2022, 01:05 PM | #11 |
Rep 543
So many words to actually say so little. Quite a skill that is.
Current BMW: i4M50 (G26, 2023)
Previous BMWs: 330e Touring xDrive (G21, 2021), 330e (G20, 2019), 530e (G30, 2018). |
05-31-2022, 01:43 PM | #12 |
Rep 81
As of a couple of years ago, BMW considers the Mxxx models to be "M" models along with the traditional M series. You can see it by how they group them together in the online configurators.
05-31-2022, 01:49 PM | #13 | |
this is the way
20001
Rep 8,947
05-31-2022, 02:04 PM | #14 | |
Rep 126
Drives: 2020 BMW X5
05-31-2022, 02:48 PM | #15 |
Rep 2,818
Raised efficiency? BMW has been anything but efficient the last year and a half. They should start worrying about getting more cars produced with all the normal options before this other crap.
2025 X7 40i, 2024 I7 60i, 2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
05-31-2022, 04:01 PM | #16 | |
Rep 911
05-31-2022, 05:54 PM | #19 |
Rep 1,944
Like Jerome Powell.
2024 M8C; 2024 X6MC; 2021 G80 M3C; 2022 P992140
RETIRED: 2021 F93, 2021 F96,2019 F82 M4C, 2018 F80 M3C, 2018 F86 X6M- black fire, 2015 F13 M6, 2015 F10 M5, 2012 F10 550i M-Sport, 2012 F13 650i X-Drive, 2009 E60 535i M-Sport, 2007 E60 530i |
NGT26648.00 |
05-31-2022, 08:08 PM | #20 | ||
Luxury at the redline :)
9131
Rep 7,563
Quadruple VANOS1391.50 NorCalAthlete3291.50 |
05-31-2022, 10:33 PM | #22 |
Rep 3,274
When I was in high school I wrote essays like this. Where I took about a dozen ho hum bullet points and tried to hit a word count using superfluous language, that essentially added nothing to the core of the content.
I’m genuinely impressed by this press release. Game recognizes game. |
Rux719.00 |
