Forum for the entire range of BMW electric vehicles
BMW iX Forums BMW iX Discussions
      06-18-2021, 10:09 AM   #133
ian_i3S_iX
ian_i3S_iX's Avatar
Drives: i3S, iX on order due Nov
Originally Posted by Ibiza View Post
Epic design failure!
Range is pitiful that a full charge will take 40 min when on a road trip and unable to trickle charge overnight.
EV still has a long way to go before mainstream acceptance.
Effective charge rate better the a TM3 it can hold 200kW longer
At least UK or EU models can trickle charge at 3.6kW to 11kW depending on your mains supply at home
Putting 600A into the car with that small connector a bit scary to say the least
When I get my Msport 50 in October with 370 mile range it will seldom see an ultra rapid charger
      06-21-2021, 07:41 AM   #134
nosnoop
Drives: 5 Series
Is trailer hitch not available as an option? Don't see it in the configurator.
There is no massage seats or rear heated seats either, at least in Canada.
ggalanis2446.50
      06-21-2021, 10:19 AM   #135
ggalanis
Drives: 2023 iX 50, 1989 325ic
The Canadian configurator doesn't seem to be complete right now.
You can't seem to pick the xdrive40 model at all, and a lot of the options in packages are not listing what they actually include.
The heated rear seats might be included in the 'Premium Enhanced Package' as part of the 'Heat Comfort Package' option. It is not directly mentioned on the site, but googling that name I found the following description:
"Heated rear seats are also available as an option. This function is part of the optional Heat Comfort package, which also brings heating on vertical surfaces such as the instrument panel, glove compartment, door panels, and contact surfaces like the centre armrest and steering wheel. All of this helps to warm the interior particularly efficiently. Spreading the heated areas around the surfaces of the interior in this way allows the occupants of the BMW iX to sense the change in temperature much more quickly than with a conventional distribution of warm air. And direct contact with the warmed surfaces fast-tracks the feel-good factor for those on board."
Similarly, massage seats are likely included as part of the mutli-function seats option that is part of the 'Premium Essential Package', but again not explicitly listed on the Canadian site.
No idea about the trailer hitch being available.
This is of course an educated guess at best since BMW Canada has made poor decisions in the past as to what to include... I'd either check-in with your dealership for them to confirm or wait a little longer for the site to be updated.
nosnoop837.50
      06-21-2021, 12:23 PM   #136
ggalanis
FYI This was the source I quoted above
https://www.press.bmwgroup.com/canad...50?language=en
      06-22-2021, 03:40 PM   #137
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
Drives: A Car
BMW Marketing the new iX on Tiktok
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
      06-22-2021, 06:00 PM   #138
soheil
Drives: 2018 i3 REX
[IMG]https://fiverr-res.cloudinary.com/im...documents.jpeg[/IMG]
bmw
