01-25-2020, 09:41 AM | #156 |
Rep 3,729
Looks like Pennzoil just released a new formulation of their LL-01 approved 5w-40. Apparently this meets SN+ spec. No wonder they were getting rid of their old stock at $5/quart some time ago.
Pennzoil 550051120-6PK Platinum Euro Full Synthetic 5W-40 Motor Oil, 1 Quart, 6 Pack https://www.amazon.com/dp/B07TXFCC3Q..._1eglEbNB243S8
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
01-25-2020, 09:41 AM | #157 |
Rep 3
BMW recommend shell oil. Recently spoke to our local BMW dealership who confirmed this, and lots of indies are following suit. Interesting article on it here
https://absolutebm.co.uk/approved-sh...ier-worcester/ |
01-25-2020, 05:01 PM | #158 |
Rep 1,564
Liqui Moly Leichtlauf High Tech Engine Oil 5w40 with 1.5 Cans Liqui Moly Mos2 additive every 7-10K.
150,000 Miles on this N63 in a X5 that is driven hard in the Arizona heat. I have taken it down to due the valve guide seals and clean the carbon buildup on everything from the notorious leaking valve guide seals the N63 suffers from. Cam journals and cylinder walls look excellent. IMHO BMW turbo engines need 5-40 due to the high operating temps, I noticed immediate smoother running when I switched to it. Last edited by Sophisticated Redneck; 01-25-2020 at 05:07 PM.. |
sspade2467.00 |
11-06-2020, 05:37 AM | #160 |
Rep 133
Does anybody know if BMW's own branded BMW LL-01 FE 0W-30 (part number 83-21-2-450-384) is synthetic or not, or some kind of blend?
2015 BMW X1 sDrive28i M Sport / 2019 Mercedes E450 Wagon / 2015 Porsche Boxster GTS
Favorite Former Rides: 11 Ford F-150 Limited | 09 A4 S-Line Avant / 08 Audi TT S-Line / 03 Ford SVT Lightning / 01 Ford SVT Lightning / 93 BMW 740iL / 90 BMW 535iM / 86 Porsche 944 Turbo / 83 Porsche 944 |
11-06-2020, 12:23 PM | #161 |
Rep 2,956
11-06-2020, 01:34 PM | #162 |
Rep 133
Good to know, thank you!
11-06-2020, 05:14 PM | #164 |
Rep 70
01-05-2021, 12:18 PM | #165 | |
Rep 357
- FUCHS DEU 0W-40 and 30 - Liqui Molly Leightlauf High Tech Liqui Molly 5W-40, DEU made - Approved Motul DEU Take Molygem says BMW LL-01 on it. is it so? no.. December 2020 discovered that that it is NOT approved nor certified by BMW, and it is a bit of a ..marketing thing? became aware vis communication with Liqui Molly DEU and North America after a 20,000 kms experiment with two Molygen batches, and a broader 80,000 km trial of several oils in my cars, and the occasional BMW lower shipped with DEU factory oil. Molygen is piss poor for a BMW. Safe, yes, but a performance edge killer, sedating the top 10-15% of any inline six. You may get to the eventual Pmax output, but how you get there, the engine's torque along the RPM powerband per gear, is a different story. My mechanic, a V12 BMW rebuilder, also cautioned me that North American oils and most variation are different than the EU versions. An oil may be Made in Germany but with NA additives, thus altering its properties ever so slightly. "If you can tell, you will find the DEU version far smoother" he told me... In the two Molygen batches I ran, the engine felt sedated when cold, and iffyiish when warmed up. Course esp when cold. Had to push the throttle on the highway. 10-15% hesitant at the very top of the power band per gear? And esp when 5C, 0C -10C cold really sedated and slightly hesitant, fighting internal resistance. It was ok when warmed, but it felt leagues below when new, and less than in 2017 when i ran Liqui Molly Showing Leichtlauf. Dec 2020, I had my Molygen observations memorized, Blackstone results to confirm no issues, and switched to DEU Fuchs. It was like getting a new engine, a refined smoothness, feather like pedal responsiveness that I had only felt with DEU stock oil (2014), Leightlauff in 2017, and now, Dec 2020. Although 111,000 kms, my car responded as I knew it at its best. Each gear change smoother. Cold, all the way to -20C, smooth! No hesitancy, no resistance, no pressure. Turbos? Whiirrrr responsive. No, not all oils are created equals. I would not trust Castrol for performance. I am sure it protects but not necessarily deliver the goodies in torque.. |
01-05-2021, 02:02 PM | #166 |
Rep 3,731
Not that I’m trying to disprove your results…….but I honestly think a lot of times people suffer from the placebo effect. I have yet to see any dyno charts, or hard data proof that shows that a certain brand of engine oil will give you a smoother running engine, more throttle response, a “feather like pedal responsiveness”, etc, etc…..than another quality brand (assuming the weight is the same).
It’s engine oil…..there is only so much it can do. As far as Blacktone Labs results…yes, that’s what it’s all about. How well the oil is lubricating, trace amounts of chemicals and metals in the oil, etc, etc…..
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
01-05-2021, 02:30 PM | #167 |
Rep 2,665
I have never seen independent tests on different brands of oil to show that one is better than another. I think the Blackstone lab results are somewhat useful but they are difficult to use to prove that one brand is better than another as the variables are hard to control and even then it shows that for one engine, one oil seems to have better results than another oil.
I also think the BMW "recommended brand" doesn't mean much as it keeps changing over time and believe it has more to do with a payment than BMW going with the best. I think when my car was built it was Castrol now it is now Penzoil? I will say that my car runs much better after a complete wash/wax/detail.
chris7197353.00 |
01-07-2021, 06:45 PM | #168 | |
Rep 7,310
01-07-2021, 06:48 PM | #169 |
Rep 7,310
The lines have been blurred with GTL base stocks. There is no real difference anyway; people should be looking at the complete product and how it performs, not selecting oil based on mythical properties of a base stock and whether or not it is "100% synthetic".
F32Fleet3606.00 |
01-08-2021, 07:18 AM | #170 | |
Rep 10,368
Wear was more dependant on engine type, time in sump and application. This what makes shopping by certification so easy (ex, All LL01(2018) will perform essentially the same). Certs run about $4k for an oil company. IIRC Warren Oil Company sells LL01 under Walmart Super Tech, Costco, Amazon labels.
"Drive more, worry less. "
01-08-2021, 07:28 AM | #171 | |
Rep 6,196
01-08-2021, 07:33 AM | #172 |
Rep 6,196
Good to know.
Anybody know the difference between the regular MANN filter for our cars and the M version of the filter? There is a specific M branded filter that is used in the M2 N55 that looks identical to the regular filter. |
01-08-2021, 07:54 AM | #173 |
Rep 2,665
"That’s why Pennzoil is the recommended supplier of genuine BMW Engine Oil in North America. "
https://www.pennzoil.com/en_us/perfo...akers/bmw.html
01-08-2021, 08:09 AM | #174 | |
Rep 3,731
But if you can get several reports done over a period of time in order to establish a baseline, if your "normal" readings start trending out of range, their reports will let you know that you are getting more fuel than normal in your oil (leaky injector), you are getting coolant or combustion gas particles in your oil (head gasket issue), you have abnormal amounts of lead/tin/brass in your oil (bearing issues), etc, etc, etc.....and then you can address the issue before it destroys the motor. But I agree....one single test sample doesn't tell you much....you need several to establish a baseline for your motor. |
David701567.00 |
01-08-2021, 09:22 AM | #175 | |
Rep 3,548
Although dimension C is not listed on the HU8011 M2 Filter (MANN HU 8011) E90 Filter (MANN HU 816) Unless quality of the filtration medium is different i don't see a difference. Last edited by Wolf 335; 01-08-2021 at 11:00 AM.. |
MightyMouseTech4337.50 |
01-08-2021, 09:56 AM | #176 | |
Rep 6,196
