2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Cts turbo f-series bmw n55 boss turbo upgrade
      09-07-2023, 10:09 AM   #89
cesar_m2_Brazil
cesar_m2_Brazil's Avatar
Brazil
Drives: BMW M2 F87 2017
Originally Posted by TheSandman_M2 View Post
Hey Cesar, I had my turbo installed at a friend's shop. They've had to pull it out twice now. Once for the oil line leak then again for the manifold. So if I were you I'd upgrade the oil line and I wouldn't install it unless you got the new manifold. Other than that I think running the lines can be a little tricky. Who's doing the tuning?
Hey friend Sandman, my manifold come with new realease one, my dad lives at California and he will bring for me at December, I’ll took to my tuner Neto Estrela owner of EurotuneBr at São Paulo Brazil, I’ll do what you say, not use the oil line of coming I’ll produce one very good one to change it and not have same issues of yours. So my question are;
Please ask for your friend if he had any problem for install all manifold and turbo, if he have some problem with space at M2 and if he make and adaptation? Pls ask and tell me.
And ask if he know max PSI the turbo support?
Thanks a lot for your help friend. Big hug
      09-07-2023, 01:14 PM   #90
TheSandman_M2
TheSandman_M2's Avatar
68
Drives: 2018 M2
He didn't have any problems installing it, didn't have to modify anything. No one knows the max psi, I don't think anyone's really pushed it yet. I'll start tuning mine again once I get back in town.
      09-07-2023, 01:49 PM   #91
cesar_m2_Brazil
Brazil
Thanks dear friend. You help me a lot, please share with us your project tuning upgrades. How much PSI you running right now and how much you pretend push it and did you reach more the 500whp at wheels?
Big hug friend
      09-07-2023, 07:52 PM   #92
TheSandman_M2
68
Drives: 2018 M2
I was running the BM3 STG 2+ e30 map. I'm sure I was pushing around 500whp with it at 20-21 psi. I started custom tuning with Bend Calibration when they found the crack, never got past the base tune.
      09-08-2023, 10:27 AM   #93
cesar_m2_Brazil
Brazil
Awesome friend, thanks for all support and answers, feedback us when you finish tuning. I hope getting everything ok for you. I’m very anxious. Big hug
      10-12-2023, 10:55 AM   #94
cesar_m2_Brazil
Brazil
Hello friend any update about your new tuning ? @Thesandman_m2
      10-12-2023, 05:59 PM   #95
TheSandman_M2
68
Drives: 2018 M2
Just got my 6th revision the other day. I'm not sure how much he has it turned up but it pulls. It's on e50, this update is for e60-65 so I need to get more e in the tank first. I think he's going up to e85 then back down to 93.
      10-15-2023, 02:49 PM   #96
kay_D
Drives: 2009 335i
Hey, can you and others with these tell me how the turbos are holding up? Time driven and mileage? I’m in the market for new turbos and this is the only thread with good information.
      10-15-2023, 05:12 PM   #97
TheSandman_M2
68
Drives: 2018 M2
I have about 3000 miles on mine. All good so far with the updated manifold.
      10-15-2023, 07:21 PM   #98
Smokey1975
Drives: Bmw 335i bmw 435i
Hi guys just a quick one if I change the cts turbo for say a vband pulsar gtx3584rs would it fit and could u run a external Westgate instead of using the original bmw std aastgate wanted the screamer pipe external waste gate noise/sounds if you know it can be done pulsar turbos are decent and not badly priced?any thoughts guys/girls
      10-18-2023, 01:39 PM   #99
cesar_m2_Brazil
Brazil
Nice friend, here I 'll do E25 we already have ethanol at our gasoline 25%. I;ll try to reach 550whp
      10-19-2023, 06:33 PM   #100
Dee235
Dee235's Avatar
Drives: Bmw M235i
Unsure about this. CTS didn’t release the specs on the turbo itself just states it’s a gtx3582r style turbo housing
      10-19-2023, 06:35 PM   #101
Dee235
Dee235's Avatar
Drives: Bmw M235i
Agreed. All good here. Have about the Same mileage with new manifold putting about 22lbs at peak.
Cts just updated the website saying 20lbs max for this turbo…. Don’t know how if it’s just them being conservative due to all the flack they’ve been getting with the cracked manifolds.
      10-20-2023, 07:02 AM   #102
TheSandman_M2
68
Drives: 2018 M2
Mine hits 22psi then goes down to 17-18psi on the top end. Ya, I'm not to worried about going over 20psi. Looks like we maxed out my Stg 2 hpfp or my lpfp isn't kicking on. Ordeed the Fuel It FF kit with a fuel pressure sensor. Need it see that's going on. I plan on getting the lift kit also, didn't think it would max out my fuel setup. Crazy.
      10-20-2023, 07:09 AM   #103
Dee235
Dee235's Avatar
Drives: Bmw M235i
I’m having the same issue it’s usually the lpfp starving the hpfp. I’m getting the pr 2.5 with the single walbro 535. I don’t plan on running any E blends so I should be good with that.
      10-20-2023, 04:41 PM   #104
Smokey1975
Thanks pal 👍
      10-20-2023, 04:53 PM   #105
Smokey1975
Was going to fit hpfp b58 tu pump and wanted to know which lpfp upgrade to buy also heard read loads of n55 peeps running this b58 tu hpfp I know there is some trimming and stuff to do but is a bit of budget way to upgrade any advise on lpfp and hpfp greatly appreciated I won't be running any e blends also maybe octane booster here or there also did hear once u upgrade lpfp there is a module or something that overheats?
      10-20-2023, 05:17 PM   #106
Dee235
Dee235's Avatar
Drives: Bmw M235i
So if I was you I would just skip the b58tu pump as you will just have to replace it eventually with a bigger turbo, anyone who tells you different isn’t being honest it just doesn’t have the fuel rate to push enough fuel for a bigger turbo. As for the lpfp if you run a single bucketed walbro 535 it won’t burn up the ekpm module. The walbro 525 and the 450 do. Fuel it has a stage 3 kit that comes with a stock fuel pump and a secondary bucketless 525 pump that operates off a Hobbs switch that will prevent the module from over heating. I just opted with the precision raceworks 2.5 single 535 because it’s all I needed as it states it’s good for up to 675 whp and it’s a simple swap in and out no wiring up the Hobbs switch necessary.
      10-21-2023, 02:34 PM   #107
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
This CTS unit is a stock location turbo, meaning it fits stock downpipe, turbo inlet, and turbo outlet. CTS has custom turbine housing and compressor housing to make these connections fit - they're not using a standard Garret style turbine housing. Not sure if CTS is using the same v-band connection as a vband Garret/Pulsar, but even if they are a Pulsar won't fit because it won't have CTS's custom turbine or compressor housing. Plus the CTS manifold does not have a connection for an external wastegate.
Not to thread jack, but real quick - If you're set on a Pulsar gtx3584rs and external gate, you should look into a Speedtech kit set up for the Garret equivalent. Any questions about Speedtech, and a seperate thread would be a good idea since this one's for CTS
      11-09-2023, 07:00 PM   #108
Johann01
Drives: 2015 BMW M235i
Good day friends. I been through this whole form now and it is scary to see. I just bought this turbo with update manifold and has a lot of upgrade that you with it but seems like I will not be able to reach my 700whp with my build motor and everything. Shit. You think there is hope to see that power with this turbo?
      11-11-2023, 12:32 AM   #109
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
sub'd
      11-11-2023, 09:46 AM   #110
TheSandman_M2
68
Drives: 2018 M2
No one has pushed the CTS turbo yet. So we really don't know but I don't see it hitting 700whp. I'd go Speedtech
2addicts
