E91 Leonia
03-10-2024, 06:25 PM | #200 |
Rep 263
Transfer Case work
I haven't posted in some time. I lost a bit of love for the car over the winter as the ATC motor died... and then so did the battery.
I went ahead and picked up a new battery as a part of the Optima warranty as well as a new ATC motor. I also took the time to replace the Transfer case mount. One modification made was to create a polyurethane insert for the transfer case mount. I think it's the only one that I've seen actually installed on the chassis. (let me know if I'm wrong) Another Porsche user created a bushing and is selling them but I decided to make my own. I'm hoping it will sharpen shifting and reduce drivetrain movement. Pushing in the bushing didn't work so well the first time but it worked out the 2nd after some beefier wooden blocks Pictures of the insert & ATC motor
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam |
04-11-2024, 12:22 PM | #201 |
Rep 263
The majority of the posts in this thread have all been smaller items, a replacement here, an upgrade there. It seems like there is no overall strategy to getting the car up to the quality that is... potentiallly on par with new? maybe better? oem+ they say.
That being said.... Here is a Major change in that status haha.
William Mackenzie
04-11-2024, 09:57 PM | #202 |
Rep 157
Thanks for experimenting with a more solid transfer case bushing, my car too has that bouncy feeling when using 1st gear.
Did you drive it yet? How did it feel? I remember reading someone killed a TC with a urethane bushing previously. Maybe it’s worth starting a new post on your rough running issue. I would have told you not to bother with the throttle body becuase it’s always fully open, unless your valvetronic malfunctions. Do you have any oil inside your Essentric shaft sensor connection? Change the valvetronic solenoids or fuel injectors? Look forward to how the refreshed read end feels |
04-15-2024, 01:00 PM | #203 | |
Rep 263
It may have to do with a battery issue. TBD.
William Mackenzie
