01-05-2012, 03:03 AM | #1 |
Rep 361
A/V System Cooling
I'm not sure if this is the best place for this question but I iwll give it a shot.
We did some remodeling and put all the A/V components in a buildt-in wooden cabinet. We also installed a small fan to help keep the heat down. It is not enough. The receiver is burning up. Does anyone have any suggestions on a better cooling system? As long as it is quiet and relatively easy to install I'm open to anything Thanks |
01-05-2012, 08:46 AM | #2 |
Rep 615
drill holes in the bottom and install a 12inch fan on the top.
Those 12 inch PC fans are quite nice.
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011 |
01-06-2012, 02:37 AM | #3 |
DT///M
151
Rep 1,374
Drives: 2014 F31 Touring
I cut a slot out of the back of the entertainment center and put a large 120mm right above the area where the receiver heat sinks expelled the hot air. The fan was 110v that I got at radio shack (I think) and would turn on when the receiver did. You couldnt hear the fan when the system was on and the receiver ran cooler than ever... I would leave the door panel cracked open enough to draw in cool air and the fan pulled it right over the receiver and spit out the uber hot. Worked great. Check the air flow, does it pull cool air, maybe the size of the fan. Bigger is better, quieter and pulls more CFMs. Here is a perfect example of what you can get:
http://www.amazon.com/Coolerguys-Cab...5839380&sr=1-7 it has three 120mm fans. That should be WAY more than enough. Good luck! Should take some pix so we can see the setup...
"With great power comes great responsibility." -El-Superbeasto
