05-29-2008, 10:52 PM | #1 |
Rep 7,246
help with my HP laptop failure. . . girl friend is very upset
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals Last edited by Neema; 12-17-2011 at 09:00 PM.. |
05-29-2008, 11:04 PM | #2 |
Rep 7,246
bump for help
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
05-29-2008, 11:07 PM | #3 |
Rep 40
Buy one of these or similar product. http://www.newegg.com/Product/Produc...82E16812156102
Take out the hard drive from the laptop. Attach the HDD to the adapter. Then plug it into your computer. Access the drive as a USB drive then copy whatever you need to backup from the laptop HDD to your computer. Once, the backup is done. Put the HDD back into the laptop and restore it from the restore disc or read the instruction on how to restore to Manufacture Default. This only work if the HDD is still good.
Car:
2006 E90Computer: Intel Quad Core Q6600 G0 : Over clocked 400 x 8. |
05-29-2008, 11:14 PM | #4 | |
Rep 7,246
05-29-2008, 11:15 PM | #5 |
Rep 526
Somebody needs to get some handy man skills
05-29-2008, 11:23 PM | #6 |
Rep 7,246
05-29-2008, 11:27 PM | #7 |
Rep 526
If you can figure out how to take out the battery the HDD is gonna come out like that or like how you could get in the ram. Most you would need is a phillips head
05-29-2008, 11:39 PM | #10 | |
Rep 1,153
Sorry that had to come out. BUt yeah, it's pretty easy to remove it from the laptop. There should be a little plastic cover on the bottom. You use a screw driver to remove the screw, lift up that plastic and just disconnect and take out the HDD. |
05-29-2008, 11:45 PM | #11 | |
Rep 12,445
Also +1 to the Macbook suggestion. I was never really a fan of Mac's previously, but they're incredibly enticing nowadays, and I'm positive I'll be gunning for a Macbook Pro as my next laptop.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
05-29-2008, 11:47 PM | #12 |
career student
11
Rep 204
Are you able to connect an external monitor to the laptop?? That way you could at least connect an external HD to the laptop and copy the 'media'.
my $.02 |
05-29-2008, 11:50 PM | #13 |
Rep 1,118
Drives: 2009 E89 Z4
External monitor would work, if it's not the video card that's messed up. if so, it won't be able to power another display either.
+1 on the product from newegg. It's called a sled and it makes reading HDs a breeze. Haven't toyed with HPs in a long time, as I use a Mac now, but there should be two covers on the bottom of the laptop, one screw would undo the battery and the other would undo the HD. Just slide/pop the HD out and connect it to the sled. Connect the USB end to another computer and it should come up as an ejectable drive, where you can access it as if it were an external HD.
Z4 sdrive30i | Deep Sea Blue | Ivory White Nappa Extended Leather | ZSP |
05-30-2008, 12:04 AM | #14 |
GSS CORP.
75
Rep 1,598
it might just be a video card problem so you can hook it up to another monitor
... i am just guessing... not a computer tech. here lol
Don't teach a pig how to read, it's a waste of time and it annoys the pig. |
05-30-2008, 12:19 AM | #15 | |
Rep 1,009
A quick visual check would be to see if the power & hard drive LEDs are illuminated when you power on the laptop (if the hard drive light is intermittently flashing during the boot process, the data should be fine). Most likely, her data on the hard drive is safe. The hard drive can be pulled, put in an external enclosure and the data retrieved from another PC. This is my preferred method. Another one would be to hookup an external monitor to the laptop (her Pavillion should have a VGA port) and copy the data off that way. Depending on what she has on her laptop, it's her call to get it fixed by a computer shop. I've seen instances where the tech working on the laptop "helps" themselves to the data on the laptop before giving it back to the customer. Good luck. |
05-30-2008, 12:58 AM | #16 |
Rep 2,816
If you're not really good with computers, best to take it to a computer shop and get the pros to do it.
If you're going to do it yourself, I would recommend getting a 2.5" notebook harddrive to 3.5" desktop harddrive adapter. Then you can hook it up to a desktop computer and copy all the files. If you just get a USB external drive enclosure (as suggested earlier) then you may only see/have access to one partition as Windows can only support read/write access to the primary partition over USB. Plus USB is SLOW. If you don't understand any of that...take it to a computer expert. Seriously...shouldn't play around/risk someone else's data. |
05-30-2008, 01:06 AM | #17 |
Rep 1,411
I would contact HP and ask them if they can back up the memory and fix the computer. I've done it before. So, it is very possible story.
if they say NO, then you have to take out the HDD and back it up by yourself. GL
2006 BSM 325i / ZPP / ZSP / Adaptive Xenon / BLK leather interior / Steptronic Eisenmann racing / K&N Ram charger / M5 rep. wheels / D1S 6000k / Brex white ring / OEM style rear trunk spoiler / M steering / OEM strut bar / Blk line tail light Future Mod Hamann lip spolier / Mtech rear bumper |
05-30-2008, 01:07 AM | #18 |
Rep 1,411
BTW, HP sucks.
buy Macbook lol
05-30-2008, 01:07 AM | #19 | |
Rep 1,009
USB 1.0 is slow (11mbs) but if the laptop has USB 2.0 ports (480mbs), the transfer speed would be fast. Windows (on the host computer) would be able to see all the laptop partitions and would need to only "read" the laptop hard drive to copy the data over. Also, would need to know if the partitions were FAT/FAT32/NTFS - if NTFS, is the partition encrypted or protected somehow? |
05-30-2008, 01:42 AM | #20 | |
Rep 2,816
There is apparently a registry hack to get around this...but I haven't figured that out yet. So unless I'm totally missing out on something (that I would love to find out because my search on ol' Google turned up with nothing) he won't be able to just connect his laptop harddrive via USB and have full access to all partitions on the drive. He would in Linux of course...but not in Windows...unless he hacks the registry. That's why I suggested he directly connect the drive to his computer instead of using USB. |
05-30-2008, 05:30 AM | #21 |
Ski bum
321
Rep 6,198
The proposed solution is exactly what I would have said. It's not hard to open the laptop and extract the hard drive. There is probably a bay on the bottom of the laptop where you can get the HDD out. Can you post a good pic of the bottom of the laptop?
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
05-30-2008, 06:58 AM | #22 |
Rep 420
This can be a couple of things.
1. If the laptop is not giving any signs of life, then it can be the motherboard. 2. If you dropped the laptop then it can be the memory bank that got loose, add some pressure on your memory and try if it turns on. I had this happen on my vaio and my HP. If it still doesn't turn on, then just remove the HD, it should be 2 little screws on the bottom of your computer, and then another 2 screws holding the HD to the motherboard. After you HD is out, just plug it in to this http://www.newegg.com/Product/Produc...82E16812156102 like another member here suggested. Give all these a try. And let us know the outcome. thanx Ricardo |
