M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Auto Solutions & UCP Review
      04-24-2020, 12:40 AM   #221
Thescout13
Thescout13's Avatar
Drives: '20 F80 M3CS, %E2%80%9818 GT3
Originally Posted by chris719 View Post
Originally Posted by Thescout13 View Post
Straight swap. Nothing else needed. Happy customer of an AS SSK + UCP + CDV Delete
Are there any differences other than the CDV? I'd be concerned the slave cylinder is different other than only the restrictor. I suppose if the pedal feels ok and the clutch disengages there's no issue, though.
No identical piece with a bigger hole where restrictor is. Go search my CDV delete thread. Lot of good info there.
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE
Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene)
Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017)
      04-24-2020, 07:43 AM   #222
DarthFader
Drives: M2, 135i, F23 M240i
Originally Posted by David.m View Post
Is this a straight swap, no mods required? Have seen where guys pull the restrictor out of the oem slave cylinder, just swapping would be easier.
If your doing the job yourself, then just pull clutch slave, take the restrictor out of the stock one and bolt it back up (it's super hard to get the restrictor out while the clutch slave is bolted to the car).
I took my car to an Indy to do the work so I just provided the clutch slave with no restrictor - straight swap. Figured it was an easy swap for the mechanic - wasn't going to ask him to modify the part.
I then pulled the restrictor out of the stock one and gave it a friend who is planning on doing the cdv delete.
David.m437.00
      04-25-2020, 05:18 PM   #223
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
I went for 20% reduction and -10mm height, initially with OE knob. This equated to about 23% reduction in throw.
Yes a most definite reduction in throw and increase in shift precision and weight.
Noise issue was a problem but the raceseng knob sorted that, now wonderful..
      04-30-2020, 10:03 AM   #224
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
Stock Shift Knob noise
Installed the Autosolutions Shifter with 20% reduction and stock height with Stock Shift Knob. In regards to noise, my experience is there is no noise coming through Stock Knob. It was the single best upgrade done on my M2. Well worth the money.
At a Point above 7,000 RPM.
      04-30-2020, 03:50 PM   #225
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
I talked to Ronald at length today and put in my order. 3.5-4 weeks to ship.
I went with a 20% reduction, stock height (w/ stock knob), and 80A+ bushings.
This is for a NON-track car.
I vacillated between 15-20% (and I'm still uncertain that I haven't screwed it up).
Ronald also has a new bushing choice-- a 70A. He hasn't used them on anyone's yet as he just got them in stock a few days ago. He says that these should stop any NVH complaints. I was very tempted, but didn't want to be the "test case".
For comparison purposes-- stock bushing are 40A.
Any feedback on 15% vs. 20% reduction?
And, is everyone more or less happy with the 80A+ bushings with the stock knob?
R.
      04-30-2020, 03:58 PM   #226
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
R.
Also emailing him today, I track my car so he recommended 22.5%. Sounds like 80A+ and 70A+ will be very similar. I'm tempted to go with 70A just to minimize any chance of NVH as I don't want to change shift knob.
      04-30-2020, 08:16 PM   #227
tropicatango
tropicatango's Avatar
Drives: Bmw f87 M2c hockenheim silver
80a+ bushing here and stock knob, zero noise, absolutely nothing to complain
      05-01-2020, 02:03 AM   #228
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
See YT clip in the link 3:30 in shows f series CDV removal with slave in situ and no drilling required !
Much less hassle/$$$ than buying another slave cyl.No brainer.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      05-01-2020, 10:09 AM   #229
Thescout13
Thescout13's Avatar
Go to the thread on the F3x forums and you'll see multiple people had leaking and clutch issues after doing this method. No issues reported like this for the full replacement. This looks like more of a hassle and headache than replacing it with an already perfect one that was manufactured that way.
      05-01-2020, 12:14 PM   #230
flybigjet
flybigjet's Avatar
Reading and reading and reading up on this and just confusing myself.
Query: What do the different durometer's of bushings DO?
i.e. three choices: 70, 80+, 95.
NVH goes up as the number goes up. Got that.
But, what's the DIFFERENCE between them? i.e. What do they do that you feel?
Most specifically, 70 vs. 80-- what difference will you feel?
TIA
      05-01-2020, 11:18 PM   #231
Thescout13
Thescout13's Avatar
TIA
Rubber notchiness vs mechanical clickiness is the best way I can put it. 80a are the perfect bushings IMO and I wouldn't change a thing about their NVH. Love the visceral almost race care feel and sound feedback.
      05-02-2020, 02:07 AM   #232
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Yes those same threads also flag what PITA to get slave cyl top bolt is to access to remove / refit.
I don't advocate CDV removal using a drill but using a dry wall / self tapping screw as a CDV extractor with slave cyl is FoC and successful. Fact.
From yr post, you spent the money on the slave cylinder before trying this 😂😂😂😂
      05-02-2020, 09:22 AM   #233
Montaver
Montaver's Avatar
R.
I just pulled the trigger on 20pc reduction, stock height, 70a bushings. 1-2 weeks. Can't wait!
      05-02-2020, 09:31 AM   #234
flybigjet
flybigjet's Avatar
What made you go with 70A instead of 80A+?
That's the one thing I'm still vacillating over.
      05-02-2020, 10:26 AM   #235
Montaver
Montaver's Avatar
Because I don't want any additional NVH. The reality is there probably isn't much difference between 70 and 80. If you check the power flex bushing scale 70 is a good spot for the street.
      05-02-2020, 11:09 AM   #236
gphung
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
I've been on 80a+, 20% reduction, stock height, CF M Perf knob for a couple of months now, and there is zero added noise as far as I can tell. The knob does vibrate more than before, but it doesn't bother me one bit. I don't rest my hand on the knob (and you shouldn't be), so it doesn't bother me at all. Also with the audio system muted, I still don't hear any additional noise. Zero regrets.
FWIW, if you're unhappy with your 80a+ purchase, you can always ask Ron to exchange it. He's an awesome guy, and I also read not too long ago on this thread (after I already got mine) that somebody on here was able to do that. Granted you'll need to visit your shop two more times and is a bit of a pain in that sense (and a bit costly), but at least the option is there. Don't think too much about it, IMO. You're not gonna really know until you try it out for yourself. 80a+ isn't like it's the 95a bushings.
      05-02-2020, 11:38 AM   #237
Thescout13
Thescout13's Avatar
I had a shop do it all at once when I was doing my short shift kit so paid nothing for the install and $70 for the part. Rather pay that and not have to worry about the headache if I messed it up myself. Always shocking to me how cheap people can be with modifying a $60k car.
Bet you're the type of guy who drills holes in his exhaust and intake to "get more sounds bruh" for an expensive car rather than doing it the right way or the clean way. If I've learned anything in my years of dealing with supply chain for components, is that a 1 for 1 replacement for a component to achieve a purpose is ALWAYS better/safer/more reliable compared to making any modification to the original component at home.
But given how butthurt you are about my post, seems like you like to half ass things and not do them right and clean.
      05-02-2020, 12:03 PM   #238
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
You've chosen to make this personal.
You clearly know FA about me so best wind your neck in, grow up and stop being a twunt.
      05-02-2020, 07:07 PM   #239
Thescout13
Thescout13's Avatar
ok Aitch. You do you.
      05-08-2020, 08:55 PM   #240
mzcp
Drives: BMW M
Received my AS SSK with 20% reduction, OEM shifter height and 70A bushings.
flybigjet6822.00
Kattanah137.50
      05-09-2020, 11:09 AM   #241
flybigjet
flybigjet's Avatar
When are you getting it installed? You're the first (as far as I know) to go with the 70A's, and I've been vacillating between the 70A's & 80A's (I'm "on order").
I'd really like to hear a "ride report" before Ron gets to my build!
R.
chris7197334.00
      05-09-2020, 11:22 AM   #242
mzcp
Drives: BMW M
R.
I'll get it installed on Monday. I won't have anything to compare it to. UCP is already installed and I like it.
m2
