07-18-2020, 06:14 PM | #1 |
I'll get back to you
7556
Rep 2,132
Clothes dryer vent falling off
I have tried regular caulk from a caulk gun as well as that yellow stuff in a can.None of it holds up. Anyone have any suggestions?
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
07-18-2020, 06:34 PM | #2 |
Rep 4,107
Ever tried the famous Flex Seal stuff? I have used in on smaller things and worked well for me... Full disclosure, I've never made a boat out of it!
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
07-18-2020, 06:51 PM | #3 |
Rep 287
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
How about construction adhesive?
Murf99314114.00 |
07-18-2020, 10:34 PM | #5 |
Rep 217
Is that brick veneer or an actual masonry wall?
1) You want to mortar the vent pipe perimeter to the bricks/hole ID. 2) Embed the pipe OD @the flange in poly sealant...Quad4, Sikaflex, etc. 3) Once everything is set up, run a bead of the same type sealant (matched to brick mortar/tuckpointing) around the flange edge. -Mark in St. Louis |
07-19-2020, 03:14 AM | #6 |
2JZ-GTE
3005
Rep 3,986
ThinSet
07-19-2020, 09:00 AM | #8 | |
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
Seriously though, get a lot of steel wool stuffed in the gap before you seal the edges. That thing is a rodent highway straight into your laundry room if you don't plug it solid with something that they don't find pleasant to chew.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
2000cs3495.00 upstatedoc7555.50 |
07-19-2020, 12:30 PM | #10 |
Rep 3,308
Silicone. If you really want to do a pro job find an area of your house where you can scrape away some of the concrete between the bricks. Mix it with clear silicon and apply it. It will blend in perfect. This trick also works to hide cables (I.e. speak cables etc) on a brick wall.
07-19-2020, 01:27 PM | #13 |
Rep 5,577
Home Depot or Lowe’s for newer vent. Better to have a new pipe through the wall piece and new duct from dryer to pipe. Proper screws for mortar or brick,
If I could do this anyone can do it. Last edited by overcoil; 07-19-2020 at 02:41 PM.. |
upstatedoc7555.50 vreihen1615137.50 |
07-19-2020, 02:15 PM | #14 |
Rep 7,484
You're right a new vent makes sense. I was thinking he could use the space in the corners to drill holes and screw.
07-19-2020, 02:32 PM | #15 |
Rep 398
Yep as others have said, get a new vent. I did with proper screws into concrete and also needed a 4” extension piece to make it back into the basement. Wasn’t a big deal. Good luck.
2016 M4 MW/SS 6mt
07-19-2020, 03:14 PM | #16 |
Rep 1,004
While you’re doing this, I highly recommend getting the dryer vent clean kit at Lowes or HD. It is cheap, attaches to a drill and will clean out the pipe all the way back (better if you have a vacuum attached to it). I pulled out over a cubic foot of lint when we moved into the house (no warm air had been going out), and that was a real fire hazard. I try to do it about once a year now, because our vent has several bends/elbows in it (stupidly).
07-20-2020, 12:24 PM | #17 |
17963
Rep 9,377
Oh, I thought you were going to ask how to connect the damn flex-hose to the back of the dryer and the external vent
07-21-2020, 08:39 PM | #18 |
Rep 2,304
Drives: 9Y0 Cayenne S
I used something like this. 4 Tap Con screws plus exterior silicone sealant. Done.
https://www.amazon.com/Deflecto-Supu...language=en_US |
07-21-2020, 09:40 PM | #19 |
Rep 1,907
Fuck it
07-21-2020, 09:46 PM | #20 | |
Rep 826
