Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      12-06-2023, 07:41 PM   #1893
godunovs65
Drives: Wilier Triestina Rosso Corsa
Originally Posted by ramparts View Post
There is another refresh coming in July 2024 , when they also get drive 8.5
That's for M3. M4 gets a refresh in March of 2024. Non-laser headlights, different taillights, and iDrive 8.5 as it seems. To be honest, I can't find any difference in the shape of the headlights, but the taillights do look different.
      12-06-2023, 08:37 PM   #1894
Game
Game's Avatar
8129
Drives: G80 LCI, G87 (sold)
Careful what you wish for though. I drive 8.5 isn’t all that great, in some ways it’s a step backwards!
I love 8.5 personally. Haven't found any faults with it.
      12-07-2023, 03:41 AM   #1895
ramparts
ramparts's Avatar
1174
Drives: M40i
Well the Home Screen is less customisable and where’s the weather widget gone ?
      12-08-2023, 01:20 PM   #1896
oakmaru
Drives: M240
Originally Posted by ynguldyn View Post
Can now confirm - 6MT is still there.
M3 as well?
      12-08-2023, 03:22 PM   #1897
Westside Guy
Westside Guy's Avatar
7242
Drives: 22 Z4 M40i, 21 228i Retired
Originally Posted by adc View Post
Any hint at all about a Z4 Coupe?
Dream on.
Originally Posted by NGT2 View Post
Would be pretty redundant with the 2 series. Wouldn’t think there’s market share for both.
I was under the impression that when BMW partnered with Toyota to share the assembly line at the Magna Steyr plant where they produce the Z4 and the Supra the deal was that BMW would make the ragtop and Toyota would make the hardtop and therefore they would avoid competing against each other.
      12-08-2023, 07:20 PM   #1898
Tag
this is the way
Tag's Avatar
19970
Drives: N-1 starfighter
Originally Posted by bayarea328xit View Post
It is quite frustrating that it is hard to know what HW versions are in each of the products - how can we tell which HW version is in production now?
iDrive 8.5 / 9 Head Unit Identification
      12-12-2023, 03:23 AM   #1899
azuki
Drives: 2024 i5 M60
do we know which future models will have digital key plus? it appears to be limited to the ones with the different keyfob (ie new x1, 5, 7). *looks at the m2
      12-12-2023, 11:34 AM   #1900
godunovs65
Looks like they did.
https://www.autoblog.com/2023/12/11/...ototype-drive/
      12-12-2023, 01:03 PM   #1901
ynguldyn
Drives: battery powered tv on wheels
Originally Posted by godunovs65 View Post
Does anyone know why M2 is $15,000 cheaper than M4 with the same engine and transmission? Next MY M2 will have the same amount of power as M4 today with probably a very reasonable model year price increase. But still not $15,000 more. Do they use lower grade steel, aluminum, and other materials to justify the lower price (vernasca vs. merino leather)? Or is it because assembly in Mexico is so much cheaper? Or is it because M2 is 21cm shorter?
I test drove both and they both are amazing. Is it possible that in 10 years M4 will be in a much better condition than M2 if driven in the same fashion?
Wrong place to ask this question.
Ibiza3728.50
      12-12-2023, 05:30 PM   #1902
godunovs65
Indeed. Moving to the G87 general topics
      12-13-2023, 11:50 AM   #1903
hooked
hooked's Avatar
Drives: 2022 M240i xDrive
G87 M2
In production until 07/29
08/24: engine power increases to 475hp; cosmetic changes including new wheel options. This is not the "CS" or "Competition". Skyscraper Gray, Mineral Red, Portimao Blue, and Sao Paulo Yellow could be the new colors.
G29 Z4
In production until 03/26
Manual M40i starts production in 03/24
Any inside word on the manual used in the M2/M3/M4 getting re-worked like the one in the forthcoming Z4 did? Hopefully they will keep the manual option AND make it better in the future/LCI. I was leaning towards the automatic based on several reviews that reported the manual in the M2/3/4 was not up to the level of the rest of the drivetrain. I've only driven the automatic so far.
This is an interesting quote from Motor Trend:
“The shifter itself is a big step up from the same mechanical ZF unit found in the Toyota Supra. Indeed, BMW says the Z4 manual’s shift linkage is physically different than the Supra’s, and it sure feels that way. The shifts are crisper, more mechanical, less rubbery, more satisfying. You know what else? The Z4's transmission feels better than the M2's six-speed. Same for the row-your-own M3. Along with the other changes BMW implemented, the sporty factor has increased noticeably. As athletic as a Porsche Boxster? No, but name a competitor’s car that is. The 2024 BMW Z4 is in a much better place performance-wise than it was. That’s a good thing.”
Game8129.00
      12-16-2023, 02:37 PM   #1904
weingarm
weingarm's Avatar
907
Drives: M3
I would hope you'd be right in that BMW would adopt the re-worked manual transmission from the 2024 Z4 into the 2025 M2/M3/M4. However we all know that would entail significant engineering/testing (not to mention cost) that BMW would likely NOT want to do.
I would guess the current 6MT (same shifter/bushings, etc) that we have in the M2/M3/M4 will transfer verbatim into the 2025 models. Too bad they couldn't have done this manual trans engineering work BEFORE the G80/G82/G87 came to market.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue
chris7197592.00
      12-18-2023, 02:28 PM   #1905
12nine
Question. Is it safe to assume that the S58 engine build in Austria is identical to that that had been previously built in Germany?
Why should they be different? They just moved the whole production and did not design new engines.
      12-20-2023, 08:10 AM   #1906
azuki
Drives: 2024 i5 M60
will G87 get LCI on 4/25 same date as G42?
      12-22-2023, 08:21 AM   #1907
E46forthewin01
Drives: BMW 330i E46
G2x 07/24 phev will get a bigger battery, i hope.
      12-22-2023, 11:31 AM   #1908
hooked
hooked's Avatar
You are probably right, but if the Z4 got one for its LCI, I'm hopeful they will see that success (fingers crossed the manual Z4 sells better) and take a harder look at their other manuals. Feel like BMW has been "mailing them in" reluctantly and it took Toyota (of all companies) to get their attention! My son's 30K Honda Civic Si has a better stick than most BMWs and it shouldn't be that way.
      12-26-2023, 12:18 AM   #1909
godunovs65
What year is his Civic Si? I had a 2000 Acura Integra which is the same as Civic Si for over a decade. I was also considering a BMW 323, but ended up with the Integra because it was more affordable at the time. 323 had a more refined manual transmission. After that decade, I got an Infiniti G37 with manual, which I chose over 335 AWD with manual, also because of affordability, but they had pretty similar stick feeling. I drove the new Integra with manual and the new M2, 3, and 4 6MT. No comparison. M wins.
      12-27-2023, 06:03 PM   #1910
hooked
hooked's Avatar
His car is a 2022 I think. Latest gen. Great car for 30K although FWD is a deal breaker for me. I have not driven the Integra version to compare but I drive his car 2-3 times a week to keep it running while he's away at college.
I test drove a 335 AWD stick when they came out and although the stick was pretty good, the AWD felt clunky to me compared to the RWD version. The xDrive has gotten so much more "out of the way" than the original version they grafted into the 3er.
      01-04-2024, 05:01 PM   #1911
sharpmoney
Drives: NA
if so then 8/24 to 4/25 is a really short model year for '25 the G87, can anyone confirm? update with power and "cosmetic" options just to LCI it 8 months later.
      01-06-2024, 09:59 AM   #1912
godunovs65
Question: Does LCI always start with a new Model Year or can it be introduced in the middle of a MY? Basically, will this M4 LCI be the beginning of MY25?
      01-06-2024, 03:51 PM   #1913
ynguldyn
You must be new to the brand.
      01-06-2024, 06:46 PM   #1914
Game
Game's Avatar
8129
Sure will. MY25 begins production in March.
Tags
future bmw, release date, upcoming bmw
