06-28-2021, 11:19 AM | #155 | |
Rep 57
The technicians that installed my midpipe put my car up on the lift twice after installation, and we all walked it together plus took photos. There was nothing rubbing or touching the midpipe, and I have the ~2k vibration issue. And it sucks. Can you please speak to the guys at AA and perhaps come up with a workaround, or have them diagram a specific point where we're supposed to look with regards to "rubbing" that fixes this issue? It is near the stock exhaust? Is there a photo installation guide so we can check to make sure it's done per their "spec"? It's certainly not an isolated issue, and appears to be the only negative on an otherwise great product. |
StephGOD218.50 |
06-28-2021, 12:20 PM | #156 | |
KYHOMPB
219
Rep 461
Drives: Only BMW's Ja
Also, in my case it's definitely not an install error as I've gone through and quadrupled checked all areas surrounding the exhaust from top to bottom. Nothing is rubbing or touching, I'm pretty much certain at this point. Last edited by StephGOD; 06-28-2021 at 12:36 PM.. |
06-28-2021, 12:34 PM | #157 | |
BimmerPost Supporting Vendor
24520
Rep 191,519
06-28-2021, 12:54 PM | #158 |
Rep 241
approx. `1 Week after EL install with MPE and not experiencing the bad vibrations called out by some. Are most of the folks having issues running the EL with stock exhaust ? looking to see if there is a common theme etc.
06-28-2021, 02:11 PM | #160 |
Rep 30
I too have the slight vibration. Non res, stock muffler and downpipe. As others have mentioned if you let car idle for 2+ mins it seems to have no issues. Usually by the time I plug my phone in and put a song on etc. which is why I didn't notice it too often. However, if you start car and instantly set off it is definitely noticeable. This isn't to big of an issue for me since I usually let car idle 1-2 mins anyway and am not in a rush. However, the real issue now for me is the melting diffuser which I seem to also have after another member posted about it yesterday. Has anyone else in this thread experienced it. Go check under your muffler as I had no idea until I just went out and checked.
StephGOD218.50 |
06-28-2021, 03:49 PM | #161 |
24520
Rep 191,519
i'll double-check with Active
06-28-2021, 06:20 PM | #162 | |
~Spyder
645
Rep 879
Drives: '19 M2C Hockenheim 6sp
To recap what has been posted in the last few weeks by numerous AA EL customers: the tinny-can bad noise < 2k RPM occurs: - primarily on cold engines - but also on warm engines (> 1 hr driving) - as evidenced by my own vids within the last week - primarily on stock downpipes, and stock back muffler - but also aftermarket mufflers (AA valved back box) - Sport+ or Sport modes (efficient doesn't seem affected) - BOTH under load (ie starting off from a red light) and stationary revs It is thus reasonable to conclude that the common denominator for this bad noise is the AA mid-pipe. Mike@x-ph - please update us with AA's recommendation(s) to remedy this issue. I am particularly interested to have it fixed since it's present on both warm/cold engine, and it really is unpleasant when it occurs (about 50% of the time for every rev session past 2k RPM).
Skål från Sverige...via Texas y-all
speedsnice1209.00 rdriggett130.50 |
07-01-2021, 04:17 AM | #163 |
Rep 76
I can hear a Nissan VQ esq. rasp around 1800-2200 rpm in this video. Does the resonated AA el midpipe clear that up?
https://www.instagram.com/reel/CGF58gSFKw7/ |
07-07-2021, 08:57 PM | #164 |
Rep 218
Drives: '20 M2 Competition & '18 X1
Finally got around to installing my EL Midpipe (non-res)! The car sounds phenomenal. Heres a short clip until I get around doing something more indepth.
2020 BSM M2 Competition | Blue Stitching | 6MT | Sunroof | My M2C European Delivery Story! | AA EL Midpipe | TMS Skid Plate
07-07-2021, 09:23 PM | #165 |
Rep 1,681
Would you say it's noticeably louder than stock?
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
07-08-2021, 09:30 AM | #166 |
24520
Rep 191,519
Glad you like it
07-08-2021, 10:23 PM | #168 | |
Rep 1,681
The other issues thread has someone with a Remus Race and Resonated setup and doesn't think it's loud. At this point I'll just install my stuff and make my own judgement.
Current: ///M2C
07-08-2021, 11:56 PM | #169 | ||
Rep 692
Vic
Nicname354.00 |
07-09-2021, 01:21 AM | #170 |
Rep 638
Drives: M2C
Fucking hell I remember the "paralysis by analysis" I was feeling prior to purchasing something. SOOO many options. Soooo many opinions. Sooo many slight variations in video conditions (eg iPhone vs not. Wind vs not. Indoors vs outdoors).
Eventually just said FUCK IT and got the EL and never looked back. I'll never know if I would've liked single more than EL but it doesn't matter. I like EL tons. If I one day find someone with single and hear it with my own ears and prefer it then I can make the judgment call as to whether I wanna swap. And I think of that as a win-win because in the "bad case" that I like single more then I'll just spend another 1-2k (which won't hurt much since it's spread out across a different year) and it'll make the car seem brand new again. Anyways for anyone reading that is stuck on deciding: make a choice! You're unlikely to regret it. If needed start small and conservative (eg just midpipe) with opportunity to expand if you feel the need (eg swap muffler. Or swap down pipes. I felt the need to do neither) |
07-11-2021, 06:52 PM | #171 | |
~Spyder
645
Rep 879
Despite the lamenting posts you may have seen from me, I DON’T regret getting the AA non res EL midpipe. I am just baffled that this issue isn’t particular to one setup or another, it can happen cold/warm, or at different rpm levels (some reported ~2k, some vids show 3k, mine is at 1,5k). I strive for better/perfection, and without this issue, the AA EL will certainly fit that title… As an engineer, it is my innate instinct to troubleshoot why things occur, and this AA EL tiny/raspiness issue seemingly doesn’t have a common root cause. If it did…perhaps a solution would already present itself! |
ESB1198.00 |
07-12-2021, 10:03 AM | #172 |
Rep 188
Is it perhaps vibrating at the coupling of the mid pipe to the back box? I think I read that the pipe diameters were slightly different from each other. Wonder if wrapping the smaller pipe with aluminum tape to increase its diameter would help?
07-12-2021, 10:24 AM | #173 |
24520
Rep 191,519
Best advice ever
Supadice1029.00 |
07-13-2021, 03:21 PM | #174 |
Rep 110
I get a really loud pop when starting after the car has cooled down a bit (like after going into Bavarian Beers R Us for a few minutes). It is obnoxiously loud, but after the bang all is normal. Is there a way to code this out? EL non res, stock DP and Muffler.
Bill
2020 M2C 6MT SO |
07-13-2021, 10:16 PM | #175 |
KYHOMPB
219
Rep 461
Yes, you can disable the "GTS roar" with something like Bootmod3. Not sure why it's programmed as standard on the M2C from the factory as I had to actually enable this feature previously on my 2018 M3 Comp.
07-22-2021, 04:18 PM | #176 |
~Spyder
645
Rep 879
Has anyone mated the AA EL with Dinan M2C axleback? Most ELs owners tend to match with Remus, AA or MPE primarily, but I haven't seen any Dinan owner with an AA EL.
As I posted here: https://f87.bimmerpost.com/forums/sh...&postcount=200 I think I found the best sounding S55 exhaust setup. Yes, I realize that sound is subjective, however, I seriously doubt that anyone here would say that this sound raspy, tinny, droning or anything negative. This in my mind is the MONEY EXHAUST setup - bar none...low deep rumble, throaty, really really mean! P.S. the video shows an M4 with Dinan axleback, which is VERY different than the Dinan M2C axleback. Wonder what the sound difference (note, frequency, raspiness, etc.) between these 2 is. //EDIT: there are a few M4/M3 owners who are sporting the Dinan exhaust and the AA EL, but to my knowledge, no M2C owners posted anything on Bimmerpost, so no real world feedback for our platform. ///
inTgr8r2434.50 |
