01-03-2021, 03:56 PM | #155 | |
Rep 7,340
The idea that a Model 3 Performance, for example, is less fun to drive than some huge SUV with an automatic transmission is highly questionable. BMW will make EVs, most people here will eventually buy them, and 95% of them will not look back. Obviously, ICE cars will still have niches and play a role for a long time. |
dreamingat30fps5420.50 |
01-03-2021, 04:41 PM | #156 |
Rep 329
I think the used price of Tesla cars is so high because of the reliable nature of the powertrain. The prices for a used Model 3 are almost as much as new ones. BMW and Mercedes used cars drop off the cliff at 50K+ miles or so.
Perhaps having fewer things for people to touch like AC vent tabs and buttons means the car will appear much less beat up or damaged after many years of use. Maintenance history also isn't much of an issue with Tesla as it is with gasoline cars so that will likely keep the price range closer to the price of a new Tesla vs over 50% or more drop for used gas cars, especially German ones. |
01-04-2021, 07:15 AM | #158 | |
Rep 2,665
I just had my oil, transmission. engine air filter and differential fluid replaced on my car, sure wasn't cheap and wouldn't mind all of these items going away. EDIT- the data logging is a complete different issue but I don't believe they have mastered it anywhere close to what everyone's phone is already doing.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
01-04-2021, 07:32 AM | #159 |
Rep 690
Drives: 06 Black Sapphire Z4MR
1) When prices become attainable,
2) When I don't ever have to worry finding a charge point 3) When I don't need to go back to approved facilities to fix the car 4) When they stop looking like a manju/mantou, especially in white 5) When the tesla fan bois stop their moral superiority in their everyday life and stop praising Elon like he is the second coming https://www.youtube.com/watch?app=desktop&v=PLxPAwIeL0w *obviously this is a joke* 6) When Canadian winters stop affecting their range
Revolution of our Times
I will return to the track, one day. |
01-04-2021, 10:03 AM | #160 | |
Rep 1,792
01-04-2021, 10:30 AM | #161 |
Rep 2,956
Likely for most of us it will be "never" as ICE is still the dominant selling vehicle on the plant and by the time many of us switch over there will be so many alternatives that Tesla will be like any other auto manufacturer vying for a piece of the pie. The model 3's going to look pretty dated in 2035 when BMW, Audi, MB, Honda, Toyota, etc are all trotting out shiney new EV's.
01-04-2021, 01:23 PM | #162 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
A Model 3 weighs LESS than a BMW 340i.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
01-04-2021, 02:16 PM | #164 |
Rep 1,830
To be fair, weights are up over the generations for 3 series...
Dual motor model 3 applications are ~1830kgs (4030lbs) which is a couple hundred pounds heavier than a loaded 340xi at around 3800lbs. |
01-04-2021, 02:20 PM | #165 |
Ring Leader of G8X Haters
25176
Rep 8,768
BMW lists the 2021 M340i xDrive at 3979, so not much heavier.
01-04-2021, 02:43 PM | #166 |
1821
Rep 5,337
Depending on where you live. In California you can get one for less than $37K total, out the door. And the same $37K Model 3 is 400 lbs lighter than the BMW 340i.
01-04-2021, 02:45 PM | #167 |
Rep 2,665
I am also surprised the Model 3's weight is as low as it is. Pretty close to the BMW 3 series but then the Model S (4900 lbs) weighs about 900 lbs. more than the Model 3? Seems like a real pig for the size of the vehicle.
01-04-2021, 02:45 PM | #168 | |
1821
Rep 5,337
Granted it cost $136K.
01-04-2021, 02:47 PM | #169 | |
Rep 2,665
01-04-2021, 02:47 PM | #170 | ||
25176
Rep 8,768
I would love to see a Model S refresh. New interior, some styling updates, and a more engaging chassis. I would definitely get one. |
01-04-2021, 02:49 PM | #171 | |
1821
Rep 5,337
The BASE Model 3, without the 2 motors driving it and a significantly smaller battery pack, is no heavier than your average small ICE sedan at around 3,500 lbs, and significantly lighter than your average BMW. When you step up on battery size, that's when the weight increases dramatically. The AWD long range and performance models of the Model 3 variant weighs about 100 lbs heavier than the 340i (but accelerates to 60 about 1/2 second faster (the Performance model does, the Long Range model requires a $2,000 'upgrade' from Tesla to match the 340i). But the range difference between the Dual Motor Long Range to the standard RWD base model is in excess of 100 miles. It's a huge difference if you ever plan on taking a extended drive of more than 5 hours for sure.
01-04-2021, 02:54 PM | #172 |
Rep 1,830
The performance of the single motor also compares closer to a 330i and not a 340i.. because everyone cares about 0-60 and nothing more. I can't speak of handling or feel, I assume they both aren't amazing.
01-04-2021, 02:54 PM | #173 |
1821
Rep 5,337
Do your own research.
A base RWD Model 3 cost $37,000. There's a $1,500 instant rebate from CA, plus a $2,000 clean vehicle rebate you can apply for, for a total of $3,500 off the price of the car, which amounts to just about cover the tax and license fees. So for just around $37,xxx you can buy a base RWD Model 3 that weighs somewhere around 3,500 lbs, which is almost 400 lbs lighter than a BMW M340i xDrive. The dual motor iterations of the Model 3, bot in Long Range guise and Performance guise, has a significantly larger battery pack (more weight) and an additional motor driving the front wheels (more weight). What exactly seems off?
chris7197393.50 |
01-04-2021, 03:00 PM | #174 | |
Rep 19,368
The OP has been brainwashed into believing there is only one manufacturer building viable EVs. This, even as he declares his brand independence. That's the power of social media hype combined with failure to do homework. There are two threads here: "When will you buy an EV?" "Would you ever buy a Tesla?" The first one could be a productive discussion. The second has been rehashed 97 times on this forum alone is repost after repost after repost. I was going to attempt to fix the situation, but this hydra has run amok too long to be stopped so it is what it is. |
01-04-2021, 03:03 PM | #175 | |
Rep 2,665
https://www.caranddriver.com/reviews...y-maintenance/
01-04-2021, 03:20 PM | #176 | |
1821
Rep 5,337
Disclaimer: I've bought nothing but BMWs for the last 25 years. Going as far back as I can remember I have had nearly nothing but BMWs in my garage. At one point I even have a BMW gasoline car, a BMW diesel, and a BMW electric in my garage. I am about as BMW fan-boi as one can get. Yet when my C7 Corvette Grand Sport blew an engine at Laguna Seca, and GM decided it's not worth their time to try and fix it and cut me a check for the car, what did I buy? A Model 3 Dual Motor Long Range. Not a BMW 3 or 4 series, not a BMW X3, nor any future BMW "I" offerings (I don't need a car, I still have 2 BMWs in the garage for 2 adult drivers). When I test drove a Tesla Dual Motor last October, it drove better, accelerate better, and handled better than ANY BMW I have driven except my Z4 M Coupe. And the Z4 M is hard to live with on a daily basis (although I will if I have to like I have in the past). Unlike any of the newer BMWs, they handle well despite the weight, the Tesla handled well BECAUSE of the weight. All of it is down low underneath you. None of that 500+ lbs of motor siting high up. So much of the mass is concentrated down low, and there's so much mass improving traction, and so much torque easily available at all times without waiting for an engine to spool up, that it drove like nothing else I've ever driven. Even compared to the C7 Grand Sport with its massive 6.1 liter V-8, you simply can't compare how quickly all the power and torque is available to you in an electric motor. The Corvette was FAST. Fastest car I've owned. Eye opening fast. But it felt SLOW by comparison. Even though the 0-60 in the Tesla is only marginally faster than the C7, the sensation it delivered is NEXT LEVEL. And the Corvette sits down low, with low ground clearance, and a pushrod V8 sitting as low as possible in the engine bay, and even then you can't compare having ALL the weight of the car sitting fully underneath you, not around your mid-section. The biggest difference is, the Model 3 came with 235mm wide ALL SEASON tires. So they will give up the ghost long before the Z4 M Coupe in a corner, or the C7 Grand Sport (which came with 285mm front, 335mm rear MICHELIN PILOT CUP 2's). So the maximum speed one can carry in a corner is highly dependent on the tire the Tesla is using. But as for handling and feel? My Dual Motor Long Range will tackle any corner with aplomb and composure. And since I still have a BMW that will do 600+ miles on a single fill-up (okay, the best I've done is 580 miles, but that's with multiple stints at 100mph on stretches) and can fill up virtually anywhere there's diesel sold, I don't really care one way or another that the Tesla can't be filled up in less than 20 minutes when it's ran dry. In 6 weeks it's only been "topped off" twice. And that's when I plug it in at night, and next morning it's magically filled up. As a long, LONG time car guy, and an early adapter of electricity as a mode of transportation, but a LATE comer to Tesla, I will say this. Don't buy a Tesla. Don't EVER buy a Tesla. Because if and when you do, you will see the world entirely differently, and you will never be able to buy a car like a normie anymore. I walked away from this experience knowing I will never, ever buy a car differently. I test drove a car with zero sales pressure. The guy left a key with me with zero pressure to return it. Never discussed with me when I have to order, never bothered to ask me to put down a deposit. All he said was, "when you're ready to place an order, just go to Tesla.com. And if you have a referral code, make sure you enter it to get free 1,000 miles charging." We never talked price. Never even whipped out a piece of paper with the "quadrant." No talks of "how much can you afford?" "What's your monthly payment budget?" "What does it take to put you in a Tesla today?" I literally never even talked to a sales person except to arrange for the test drive. And after I placed the order, every thing was handled through an online portal. On the day I picked up the car, it was "here's your key Mr HACK, there's some paperwork in the car. Once you sign it, pull up to the front of the dealership and return it to the attendant. Congratulations." I was in and out of the "dealership" in less than 30 minutes, and that included time walking over to Starbucks for a cup of coffee. In the first week I had the car, someone kicked up a piece of rock on the freeway and cracked my windshield. I arranged for service to replace the windshield using my phone's Tesla app, drop the car off the very next Monday, and had the car back on the same day. And again, talked to a "service advisor" for less than 10 minutes, he texted me a Uber voucher good for $200 so I can get around for the rest of the day. Done. Compared to my last car purchase, which we spent over 2 days back and forth with the dealership haggling, car spent over 9 months at the dealership in the 18 months I owned it, and just the NIGHTMARE process of dealing with a third party that does not have anyone's best interest in mind? This ownership experience has completely changed my perception of how the automotive industry sucks in general and how the whole dealership model is just the worst. So yeah. DON'T EVER BUY A TESLA. Heed my words.
KingOfJericho2454.00 chris7197393.50 |
