Some wiring diagrams for the members
09-24-2023, 01:14 PM | #111 | |
Rep 23
Do you have a link to that forum? The one I posted in (from this site) is not getting any responses |
09-24-2023, 04:16 PM | #112 |
Rep 13,133
You are going to have to do your own research to find 5 series info.
That link I put in the last entry is a 5 series board. Also since that system was built by Technic(the one in the link) of Technicpnp.com I would suggest trying to get in touch with him since he has seen all the BMW systems across all the Series for the last 20 years or so. This is in the no good deed goes unpunished area now |
09-25-2023, 06:32 AM | #113 | |
Rep 23
I was reading this on my phone and didn’t see the link you posted in the last response …(it didn’t show) I’ll take a look Thanks!! 😁 Last edited by Dark Vader; 09-25-2023 at 06:38 AM.. |
09-25-2023, 06:51 AM | #114 | |
Rep 23
Awesome! The thread is old (like my car) but I’m going to read through it and chime in… hopefully there’s still someone alive over there… lol Thanks again |
04-07-2024, 08:20 PM | #115 |
Rep 36
Hey i was wondering, where does the Auxiliary USB port in the center console get its power from? cause the USB plug has no power and was wodnering what fuse provides the power to it, or if it get's power directly from the Head Unit. as all my other features are working.
tested the USB by plugging in phone and noticing no charging, so then tested with a USB LED strip that was working plugged into a USB A port and no light. |
04-07-2024, 08:44 PM | #116 |
Rep 13,133
As far as I know to have the center console usb active you have to have
the 6FL option that requires a Mulf 2 hi or Combox module in the trunk behind the US rear passenger seat under the floor of the trunk in a non convertible . I don't believe it is fused. The Mulf2 Hi or Combox may be fuse though. You bought it used you need to find out what it came with . Use mdecoder.com Then check for module in trunk. Last edited by ctuna; 04-07-2024 at 08:50 PM.. |
04-09-2024, 12:42 PM | #117 |
Rep 36
S609 Navigation System Professional
S620 Voice Control S639 Preparation F Mobile Phone Cpl. USA/CDN S645 BMW US Radio S655 Satellite Tuner S677 HiFi System Professional DSP S694 Provisions For BMW 6 CD Changer S6AA BMW TeleServices S6AB Control, Teleservices S6FL USB/Audio Interface S6UH Traffic Information yes it has the 6FL code. i figured there would be a fuse, as most i see with USB down also have the aux in port down as well, but my Aux in 3.5mm jack port works fine. would be nice to have an accessible wiring diagram ( thanks BMW AG for being a prick) so i can at least see precisely what colors go to the USB port so i can circuit test for opens or shorts, and know which pins specifcally are set aside for it on the MULF. the car does not have the COMBOX upgrade, it's the standard telematics/mulf/satellite/idrive, with the harman becker L7 optical amp. |
04-09-2024, 05:29 PM | #118 |
Rep 13,133
There are pin-outs for the Mulf 2 Hi online.
And the retrofit threads cover this to. If you have IstaD for diagnostics (highly recommended) it has the pin outs and wiring diagram's to. Ista D is like having a shop manual with guided troubleshooting for just about everything and schematics and illustrations to. If you just do search for Mulf 2 Hi BMW on the open web a lot of stuff will show up . https://www.m3post.com/forums/attach...0&d=1673628175 The usb has it's own Fakra connector. This above has the pinouts for the Mulf 2 hi and combox. Last edited by ctuna; 04-09-2024 at 05:49 PM.. |
04-10-2024, 03:03 PM | #119 |
Rep 36
Man i've tried to find a link for ISTA, and it seems everyone with access is charging now. Bimmergeeks had their mega access removed, and NewTIS was hit by BMW AG cease and desist.
and thanks for the link. appreciate the assist. Last edited by Podunk; 04-10-2024 at 03:16 PM.. |
04-10-2024, 05:20 PM | #120 | |
Rep 279
Drives: Green '07 & Arctic '08 335i's
04-10-2024, 10:28 PM | #121 | |
Rep 36
but then again i should have known it would have an intermediary as USB is a 5 volt plug on PC's so any USB accessory would only function with a 5 volt reference, and cars are 12 volts, so a bit of a derp oversight on my part. as of right now i'm putting this on the "to do" list, but it's kind of at the bottom as i am using the accessory outlet with a USB converter to power the BT adapter for aux, and charge my phone. ( yay workarounds!) and getting factory suspension back on it is top priority right now. |
BRG_N54313.00 |
04-11-2024, 11:22 AM | #122 | |||
Rep 279
TTL is 5V, so there is lots of regulation and conditioning from 12V to 5V going on all over a modern car. The COMBOX is responsible for providing the 5V to the USB port, so provided it's all coded and wired correctly, could be a bad COMBOX. Again, the cable from the trunk to the armrest provides the connection, but does not have the 1.5A you will get from a computer or port designed to charge a smartphone. |
04-11-2024, 07:22 PM | #123 |
Rep 36
I think there is something getting lost in communication, i have not converted to combox, and probably won't be anytime soon, as getting to the MULF is a major PITA when the seats don't fold down, so i'm still on MULF/Telematics, instead of All in One COMBOX
As for coding, i used Bimmergeeks protools when i replaced the L7 DSP TOP Hifi Digital media amplifier, and verified the codes for 6FL are present, and pretty much ran down the list for coding just to make sure i hit the amp, cause i wasn't positive which part of the system it is, i am thinking M-ASK, but in all other instances that refers to the head unit not the amp, so i don't know. but at least I have sound where i didn't before. |
04-28-2024, 01:44 PM | #124 |
Rep 1
I want to add the rear door speakers and the front center one. To do this would I just need to swap out the amp and run the additional wire for the speakers I’m adding?
