BMW X5 and X6 Forum 2014-Current
      04-06-2024, 08:27 PM   #1233
perezds
Drives: X5
New to BMWs and about to pull the trigger on a 2014 X5 (F15). It drove straight and seemed to handle well, but squeaks going over speed bumps. It has 91,000 miles and the dealer (not BMW) has replaced the tires and aligned the vehicle. From what I am reading, the noises could be from the control arms or the “thrust” arms. Knowing this to be the case, should I try to get the dealer to knock more money off the price? Right now he’s asking $14,500…all opinions appreciated! Thanks!
      04-24-2024, 08:49 PM   #1234
K.hanBimmer97
Drives: 2017 Bmw X5
Hey Guys,
New here, just bought a 2017 x5 35i Drive but noticed the daytime running light was out. I looked under the hood and seem to be missing the module. Does it anyone where I can find the daytime running light module?
      04-24-2024, 11:33 PM   #1235
LateParty2018X535d
LateParty2018X535d's Avatar
Drives: F15 - 2018 BMW X5 35d - Stock
  [0.00]
Originally Posted by freddymac View Post
I took my car to the dealership for an oil change and was informed that the oil pan plug was stripped. I immediately mentioned that they are the only ones who have serviced my vehicle, and it appears that the technician made an error. The service advisor informed me that BMW cars have an aluminum oil pan, and this problem is quite common and is considered a technical defect with BMW. Has anyone else faced this issue? The cost to replace the pan is almost $5,000.
Wow that is ridiculous… you point out that they did it. That’s their fault. I’d take that further over $5k. New owner and haven’t had this issue but a non BMW technician reviewed all technicical service bulletins for this car for me and this issue came up except slightly different: he said it means you need to change oil pan bolt each oil change. That’s all I got.
      04-25-2024, 09:51 AM   #1236
FCX5
FCX5's Avatar
Drives: X5 50i
Rear air suspension sagging when parked in incline. $4000+ to fix at dealer. Covered by BMW extended warranty. That repair alone is more than how much I paid for my CPO Wrap warranty! It would have really sucked to pay that much out of pocket. 2018 50i with 50K miles...
      04-30-2024, 11:42 AM   #1237
FALKLAN
Sing your death song!
FALKLAN's Avatar
Drives: 2015 X5 xD35d | 2003 MB ML500
Question
Howdy!
I haven't been on this site much since registering but I could use a little help.
2015 x5 35d mechatronics sleeve/gasket kit
Do those exist for the 8hp transmission?
The attached image file is a kit for a ZF 6HP transmission. I presumed there would be such a kit for an 8HP transmission.
Thanks much!
      05-02-2024, 11:35 PM   #1238
ahab_01
ahab_01's Avatar
Drives: 2016 BMW 228i
Could use some guidance on what to look for:
Getting chassis Malfunction upon start up and multiple times thereafter. Somedays not at all. ISTA codes relate to the icm ride height and headlight beam throw (see pic)
Is this a battery issue? do I need an ICM? what do I look for? I'm new to using ISTA.
thanks in advance !
      05-12-2024, 06:35 PM   #1239
Trippy_Zen
Drives: BMW F15 X5
F15 crank no start
What's up Bimmers, I recently made the mistake of jumping my E36 with my F15 and it killed it. She cranks but doesn't start. I just wanted to know if anyone knows if its a burnt relay or if I actually fried my computers.
Any information and options are appreciated
      05-14-2024, 01:11 PM   #1240
RED_Y_
Drives: 2014 X5 3.5d
Check you PCU (Power control unit) first. Did you connect cables to the battery terminals in the trunk?
      05-17-2024, 11:26 PM   #1241
anshudutt
Drives: 2017 BMW X5 xdrive40e
Nbtevo_q update to nbtevo_y
I did iStep firmware flash today to update NBTevo_q to Y. Flshing went without a problem but my idrive is still at the old iStep version and NBTevo changed to Y. Is it because I did not select the VCM update in the E-sys option before starting Tal-Execution?
Is there any way I can force the Flash/update iStep?
Thanks
      05-18-2024, 07:06 PM   #1242
Lamontx5
Lamontx5's Avatar
Drives: 2016 X5 35i
Code 1f4a10. Will crank,but won't start. 2016 x5 35i
      05-22-2024, 12:56 PM   #1243
cals
cals
cals's Avatar
17
Drives: E34, E39, E60, F10, E70, F15
2017 BMW X5  [0.00]
2001 BMW E39  [0.00]
2004 BMW E60  [0.00]
2011 BMW F10  [0.00]
2007 BMW X5  [0.00]
A/C Warm on Driver Side
Got the car during winter so truly testing using A/C until now
At lowest setting, 16C (60F), A/C blows Cold on Passenger Side but noticeably warmer on Driver side, both in Max A/C and /AC
-vent dial setting are in cold (both sides)
I had this issue on my e70 -but reversed, it was warm on Passenger- and ended up being due low refrigerant, however, as it was (and is) supposed to be a closed system so a leak was the true culprit.
No codes present, already searched the forum but not many results
Any other areas I should look at?
      05-22-2024, 12:59 PM   #1244
cals
cals
cals's Avatar
17
2017 BMW X5  [0.00]
2001 BMW E39  [0.00]
2004 BMW E60  [0.00]
2011 BMW F10  [0.00]
2007 BMW X5  [0.00]
thanks in advance !
just a suggestion....have you checked the ride sensor itself? could be broken/damaged/disconnected or have a short/loose connector --which *may* explain why sometimes you do not get the error...
xbimmers
