KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
10-13-2023, 10:19 PM | #1101 | |
Rep 82
the front may clear but honestly you're probably going to rub front and back |
10-14-2023, 11:21 AM | #1102 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Rear most likely will rub but I honestly have not tested that specific rear spec because the manufacturer’s max recommended rim width for 295/30/19 is 11”.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
DrFerry6734.50 |
10-18-2023, 10:39 AM | #1104 | |
Rep 6,734
You wouldn't be the first person to stretch a tire beyond the recommended limit. That's up to you. The tire in pics looks to be pushed beyond ideal rim width but will you die? No. It just might not perform as well as it could.
'23 X7
10-18-2023, 11:44 AM | #1105 |
Rep 68
I second this. I've been running a 305/30 on a 12.5 on my other car for the last 4.5 years with no issues but I drive that car SLOW. I was even worse with the setup before that was a 255/35 on an 11. I'm not doing that when I get wheels for the M3, probably will run a 295 on a 10.5 or 11. In fact it's the exact opposite at the moment since the previous owner slapped 295/35's on the ZCP wheels. Man I'm getting old....
10-18-2023, 11:45 AM | #1106 | |
Rep 1,751
in fact, a little stretch is preferred in some cases. i think the G8X run 285/30/20 on a 10.5 wheel on PS4S star which gives a little stretch.
10-18-2023, 03:04 PM | #1107 | |
Rep 6,734
I agree with what you are saying. I generally run tires on the max recommended rim width to maximize sidewall support and tread width. For example, 10.5" with a 265/35/18, while many people run that same tire on a 9.5 or a 10. The example you gave with the G8x still falls within the manufacturer's recommended max rim width. But, again, 295 is not meant for a 11.5 wheel (according to the tire manufacturers spec).
'23 X7
10-18-2023, 04:24 PM | #1108 | |
Rep 1,751
10-24-2023, 10:22 AM | #1109 |
Rep 562
I'm currently running the Essex AP Racing BBK CP9561 caliper/380mm disc
Does anyone know if the Front 19x9.5, ET25 BBS LM-Rs will clear this bbk? Before I pull the trigger i'm hoping to confirm fitment. I reached out to Essex and they said they "don't know" as LMRs are not on their confirmed fitment list.
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
11-30-2023, 04:54 AM | #1110 |
Rep 2
FORGESTAR f14
Someone pls help
I have a set of Forgestars F14 and I'm trying to get perfect fitment. I would prefer staying on Oem height. I have a BMW E93 M3 08. 19×9.5 et22 19×10 et28 |
11-30-2023, 04:55 AM | #1111 | |
Rep 2
Forgestar f14
11-30-2023, 01:22 PM | #1112 | |
Dont listen to me
810
Rep 579
Also to get a good ball park of 'perfectly flush' without doing it the mathematical way, you can take a 4 foot construction level and place it vertically (90° to the ground) next to your fenders, and then put a ruler horizontally where the top of the rim edge and the tire sidewall meet and measure from the tire to the edge of the level. That will give you the thickness of the spacer that will be required to get the tire in line with the fender. Depending on your tolerance of aggressive stance, you can deviate a little more or little less if your measurement is within the standardized sizes that spacers come in.
Instagram: @thatwhitem4
DrFerry6734.50 |
01-20-2024, 02:19 AM | #1114 |
Rep 24
Would anyone know what size tires I would be able to run? Im getting a set of custom LM-Rs from friend of mine. Im currently on stock ZCP suspension, will eventually move to coilovers later on down the line.
19x9.5 +13 19x11 +19 Would it be possible to run 275/30/19 front and 295/30/19 in the rear? Or what tire sizes would be recommended for this setup? |
01-20-2024, 06:35 PM | #1115 | |
Rep 1,751
05-21-2024, 04:57 AM | #1116 |
Rep 583
Not sure if this constitutes aggressive but need some help with a set of wheels I'm looking to run - 18x10 +22 square. How much camber will this require? I'm all stock and not planning to run camber plates.
05-22-2024, 11:37 PM | #1117 |
Rep 3
Hi all, wonderful forum.
I have a question about fitment. What do you guys think about this specs? Rear 19x10 ET25 with 275/35? Front 19x9 ET15 with 245/35? Got a nice deal with this wheels. Else i'm thinking about a more aggresive fitment. R 19x11 ET 25-30? tires 295/30 F19x10 ET 20 tires 265/30 Car is lowered on H&R springs. Greetings from Sweden /Henrik |
05-23-2024, 12:08 PM | #1118 | |
Rep 5,974
The rear is identical to the Comp pack 359M wheels which are 10et25 with 265/35. You may need to add at least a 5 mm spacer to get similar outspacing to the 9et15 front wheel. Your more aggressive setup with an 11et25-30 should fit just fine with 11et25 with 295/30 being used by others. The 10et20 with 265 should work but the tire is really stretched. A 275 or 285 is commonly used. Depending on your front struts there a chance there could be contact by not with a 265. Is a 265 designed to work with a 10” wide wheel? |
05-23-2024, 11:45 PM | #1119 | |
Rep 3
The wheels that i will get a good pricing on is the AG 359, but i have read that they can rub in the front with such a low ET. Really dont know if i should go for them, like the OG style. About the 265 tire. I googled what tire size will fit a 10 inch wheel. Recommended was 265 or 275, max size was 285. Thanx again for the help, really appreciated |
05-24-2024, 12:01 AM | #1120 | |
Rep 5,974
05-24-2024, 12:04 AM | #1121 | |
Rep 73
05-24-2024, 12:40 AM | #1122 | |
Rep 5,974
