New Dynavin N6 product sounds encouraging
06-16-2014, 03:24 AM | #89 |
No 55mph
1623
Rep 8,479
1st off - congrats on becoming a forum sponsor
Well, this looks to be their best solution to date. I like the fix regarding the fitment to dash, but the fact that the DVD/CD unit is now separate to enable this is kind of inconvenient... Couple questions:
I realize some of my questions you may be biased as you are selling the unit, but I would assume you would give your honest impressions since after a couple of these go out there will no doubt be reviews from actual customers anyway...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-16-2014, 12:38 PM | #90 | |
102
Rep 952
Good questions.....
06-16-2014, 01:28 PM | #91 | |
102
Rep 952
Ive learned from my time here though that everyone's understanding, knowledge and expectations are different....so while people's reviews may vary, what I like to do is stick to the facts, honest pros and cons, and the best way to set things up to meet each persons individual wants and needs. This unit wont be the right thing for everybody so getting all the information out there accurately is the best way to make sure people get the right solution for their needs.....and that is good for business.... Last edited by jeffb335; 06-16-2014 at 01:59 PM.. |
06-16-2014, 01:52 PM | #92 |
No 55mph
1623
Rep 8,479
Thanx
I appreciate your detailed reply - hopefully some of my questions, & your answers will also help others. I'll look in to the Metra relo kit, I currently use the brushed aluminum center console trim - if all else fails & I don't like the looks of the supplied black, I can wrap the Dynavin kit with brushed aluminum Dinoc (which I already have) or go with a CF trim which would look better with the matted black... Are the Nav maps on an SD card? Just wondering the process as to updating the maps when necessary. Keep us posted on release date...
06-16-2014, 01:58 PM | #93 |
102
Rep 952
I personally think black looks fine since all the other center console inset parts are black.
But....I've still got a bunch of the silver relocation parts on hand so if you end up needing one just let me know, I've got enough to last a while.... yeah, maps are on an SD card, easy to update when the time comes, just put the card in your computer and go to naviextras.com, jump through a couple hoops and you will be presented with a "menu" of upgrade options and costs. Make your selections, update, and put the card back in the dynavin. Done. Last edited by jeffb335; 06-16-2014 at 02:08 PM.. |
06-16-2014, 02:08 PM | #94 | |
No 55mph
1623
Rep 8,479
I got all kinds of options now
06-17-2014, 09:34 AM | #95 |
Rep 2
Factory Chimes & PDC
Does anyone know if ANY Dynavin products, D99, N6, etc. allow you to retain the factory BMW chime sounds & PDC without having to relocate the oem stereo. The documentation on this new N6 model says it will but is this a new feature? Were previous versions unable to etain these sounds? Lastly, does anyone know if the warning chimes are some Dynavin sound or the authentic OEM BMW sounds?
Any input on this would be great. |
06-17-2014, 12:04 PM | #96 | |
102
Rep 952
No, nothing else does, or has. EXCEPT the D99 and later had the option to do PDC beeps. We dont know what the sounds will be yet. The prototype I have been using does not yet have this functionality. Since the N6 unit itself will be generating the tones I dont expect them to be "authentic OEM BMW sounds" but they may be close (pure speculation here). Dynavin did mention to me a while back that the DSP chip is used for tones so they can be fairly complex, not just crude beeps. Ill see if dynavin has a better answer.... |
06-17-2014, 03:55 PM | #97 |
Rep 273
Not sure if this has been answered already, but would the $99 logic 7 adapater work for other aftermarket stereos/older dynavin units or is it specific to this new dynavin model?
06-19-2014, 11:54 AM | #100 |
102
Rep 952
Edit: I just added the following to the beginning of this thread so it doesnt get buried....
I thought I would give you guys an idea of what the install is like....pretty straightforward. I didnt cover EVERYTHING here as there will be some variation between installs depending on what you are starting with and where you are going....but what I cover here is pretty universal to all installs and should give you a rough idea of what you are getting into. starting point, its a good idea to lay down a towel over your center console to avoid any accidental scratches while you are working. Carefully use a screwdriver or trim removal tool to pop out the trim around the HVAC controls, be careful and use a towel if needed so you dont mar any of the plastic. Unplug the HVAC controls, these plugs use a little rotating lever to push the plug out of the controls, If your car has the second row of buttons below the HVAC unclip and unplug these as well: Unclip the HVAC controls from its surrounding trim piece. Take out the two screws under the stereo, pull it out and unplug it. Take out the screws holding the radio bracket in the dash and pull the bracket out. Now you have a big hole in your dash, at this point you want to route your ipod/USB/aux cables or whatever else you might be running in your particular install to wherever they need to go. Glove compartment is the obvious place but you can do console, storage cubbys, ashtray, whatever... You will also need to install the GPS antenna and bluetooth mic. If your car has the second row of buttons this is also the time when you would do the relocation of those to the console ashtray area using either the dynavin replacement ashtray assembly OR the metra storage tray kit. Not pictured here but basically you pull up the top console trim, take out the ashtray and replace it with the button relocation solution of your choice. In my personal car I snaked the GPS antenna lead up to the center dash location (where the center channel speaker is on a L7 equipped car), with the older dynavin units I had the gps antenna on TOP of the dash in this location as putting it under the dash reduced the signal strength, So far with the N6 it seems to be running fine with the GPS antenna stuck on the metal crossbar inside the dash, under the vent/speaker assembly. Since I DO have a center channel speaker I have the antenna pushed off to the passenger side so its not under the speaker. For the mic, for best results you may want to play around with the location a bit, in my car I ran it up the pillar and to the oem location next to the sunroof controls, I like this location for cosmetic reasons BUT its noisy as the mic is up in a cavity in the roof, only inches away from the roof panel and sunroof, so there is wind noise. To combat this I looked around my garage and came up with a "macgyver" fix for it.... I had some 3/4" adhesive backed weatherstripping foam laying around so I cut some of that up and put it over the back side of the mic, insulating it from the noise from the roof of the car. You could use any number of things for this, I would think some of the thicker dynamats would work nicely as well.....even carve out an old egg crate mattress piece....basically any kind of sound insulating foam cut to the right shape and stuffed in there behind the mic would work. Just make sure the business end of the mic is facing the grill and the cabin. Take the HVAC controls and file off the corner of the tabs that stick out, this is not a critical part of the unit and allows the HVAC controls to fit correctly in the new trim piece as part of the dynavin. Holding the HVAC controls in position next to the dynavin should make it clear what needs to be shaved. Snap the controls into the dynavin. Install the metal bottom clips onto the dynavin if they are not already in place. Now its time to put everything back in, plug the radio antenna, the GPS antenna, the ipod/usb cord, etc... Plug in the dynavins main wire harness and plug the canbus box into the harness as well. Slide everything partially back into the dash and at this point turn everything on and make sure everything is up and running including the HVAC, if everything checks out, slide it the rest of the way back clipping the bottom spring clips into place and inserting the two retaining screws into place. DONE! One note on a small speedbump I hit in my install.....I dont know if this will happen on all cars or if it will be specific to certain HVAC controls, years/models/etc.... When I first pushed the unit back into place, the bottom (the part by the HVAC controls) would not go all the way back into place, it was sticking out maybe 1/8". I started looking around and it appears the HVAC controls were a little too deep and they were hitting part of the dash behind them, keeping the bottom from going all the way back and being flush. Specifically this little ear inside the dash where to the oem radio bracket mounts was in the way. Closer inspection revealed that the part was upholstered with foam and vinyl, AND had a plastic nub on it. Both of these factors added more than 1/8" of thickness to the ear and was keeping the dynavin from going all the way in. So I simply trimmed the upholstery and foam off with a utility knife. Then I snipped off the plastic nub with some diagonal cutters and cleaned it up with the utility knife. As you can see the ear is still there, its just doesnt have all the "stuff" on it getting in the way Did the same on the left side and I was then able to slide everything all the way back into the dash and the fit was great Last edited by jeffb335; 06-24-2014 at 08:22 AM.. |
06-19-2014, 01:17 PM | #102 | |
102
Rep 952
well.....in july when they are released and available ill probably start an official thread, im kind of holding off on that until they are on the shelf and a few are installed in the field before I do that. So this thread can be the pre-release speculation and discussion thread and the official thread can be more for post release facts, usage Q&A and advice, reviews, etc.... Ill edit one of my first page posts though to include the install post above so that its easier to find in the meantime....so its not buried here on page 5.... Last edited by jeffb335; 06-19-2014 at 01:45 PM.. |
06-19-2014, 01:25 PM | #103 |
Rep 5,316
Drives: G80 M3 6MT
I just did a CIC retrofit (from no iDrive) for 1k, so they are going to have to get very competitive with pricing if they want to move these.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
06-19-2014, 09:55 PM | #104 |
102
Rep 952
06-20-2014, 06:41 AM | #105 |
Rep 5,316
Drives: G80 M3 6MT
Maybe, but in this case everyone knows that Apples (CIC) is ALWAYS better then oranges (Dynavin)
Scott, Partner
06-20-2014, 07:32 AM | #106 |
Rep 407
Sorry to jump into this. But I am not sure I want to rip out the entire dash to do a CIC retrofit. So dynavin is for people who want to avoid all that hassle of finding the parts, harness, days to refit and program the car.
06-20-2014, 09:12 AM | #107 | |
Rep 5,316
Drives: G80 M3 6MT
I will say if your car is base this will be a much easier way of adding bluetooth and iPod connectivity then if you did CIC.
Scott, Partner
06-20-2014, 09:29 AM | #108 |
Rep 609
I'm going to wager that it's probably $2-300 cheaper and everything is pretty much right there, with a much easier install time.
The only thing I can think of that CIC has going for it, might be that it's easier to have factory work done on the vehicle with the OEM head unit. |
06-20-2014, 12:23 PM | #109 | |
Rep 333
Drives: 2016 Dodge Charger SRT 392
Anyway can't wait for this! |
06-20-2014, 12:29 PM | #110 | |
Rep 5,316
Drives: G80 M3 6MT
I don't know whats up your ass thats getting you so annoyed. I'm just saying that they really should make the price a little bit lower because they're coming close the the price of a factory nav retrofit. How about the fact that this would a pain in the ass to use while driving always looking down and away from the road? It might seem great but these things always have one or two quirky issues which we aren't aware of yet because it hasn't been sold yet. And that wasn't my metaphor buddy.
Scott, Partner
