Bluetooth Streaming solution on Pre-Combox (with iPod 6FL)
11-18-2013, 05:24 PM | #67 |
Rep 152
Drives: '21 M340xi
Doesn't fully work with iPhone 5s
I just got my WMA1000 today. It works perfectly with my old 4S & iPad 2. Unfortunately, it only partially works with my new iPhone 5s. The car recognizes that it's hooked up to an iPod and the music plays, but there is no track information and you cannot use the steering wheel controls. I assumed since the specs said iPhone 5 and the 5s had JUST come out it would work, but I was wrong.
11-18-2013, 07:27 PM | #68 |
Rep 208
Drives: 2024 X3M Comp
Try re-pairing it. It works with my friends's iPhone 5s
11-18-2013, 07:39 PM | #69 |
Rep 152
Drives: '21 M340xi
11-18-2013, 09:48 PM | #70 |
Rep 208
You can try either of the following. Reset all settings - Settings > General > Reset > Reset All Settings [It should say the following (This will reset all settings. No data or media will be deleted.)]
Or Hold the top power button and the home button until the Apple logo appears. Also, I read that their is an issue with Bluetooth on the 64bit iOS 7 (iPhone 5s), iOS 7.1 is supposed to fix it when they release it (that May or may not fix your issue). Hope you get it going, I tested it with my friend's 5s when it first came out and it worked then. |
11-24-2013, 12:05 AM | #71 |
Rep 1,271
There is supposed to a firmware update for the WMA1000 on their website that supports the 5 and 5s. Make sure it's the latest firmware. My 5s works flawlessly. It actually works the same as my 4s worked when it was plugged directly into the Y adaptor.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
11-26-2013, 10:04 AM | #72 | |
Rep 857
11-27-2013, 09:33 PM | #73 | ||
Rep 1,271
11-28-2013, 06:30 PM | #74 |
Washed Weekly
Rep 155
Hi all. I've been using the WMA1000 with the Y-cable on my 2008 build LCI and noticed that, like what others have said, you need the 3.5mm audio cable plugged into the aux input. Is there any way to use this device to send the audio via the USB only? I know I can plug in a USB device to play music - but can I get the bluetooth tune2air to send the audio via the USB input in the car?
Basically I'm trying to work out if its the Y cable that splits the audio to the 3.5mm audio cable or the tune2air. Thanks all. |
11-28-2013, 08:57 PM | #75 | |
Rep 8
Oh, make sure before you do this that your car at least works with an iphone/ipod plugged only into USB. If it doesn't the WMA2000 is not for you. |
11-29-2013, 10:11 PM | #76 |
Rep 1,100
I don't think that you need a USB port to stream through bluetooth, if you get an adapter like this: http://www.amazon.com/Belkin-Bluetoo.../dp/B004CLYJ2I
MY PROGRESS LINK: http://www.e90post.com/forums/showthread.php?t=766852
''Happiness in intelligent people is the rarest thing I know.''Ernest Hemingway |
11-29-2013, 10:23 PM | #77 | |
Rep 152
Drives: '21 M340xi
11-30-2013, 05:54 PM | #79 |
Rep 152
Drives: '21 M340xi
The phone can connect to multiple Bluetooth devices at a time. Mine connects to the WMA1000 and car and switches between music/calls automatically and seamlessly.
11-30-2013, 07:06 PM | #80 | |
Rep 639
Anyone using it with a pre LCI CCC system? Last edited by Pete Schweaty; 11-30-2013 at 07:16 PM.. |
12-02-2013, 12:18 PM | #81 | |
Rep 1,951
Perhaps it's the case that combox cars still support the legacy Y cable architecture for the sake of older iPods, in which case either will work, but I don't know if that's true. And regardless, unless you have a combox, you must use the Y cable and WMA1000
12-11-2013, 01:51 AM | #83 |
Rep 347
Question for you guys: When you listen to music then shut off the car then return to the car, does it just pick up the music where it left off? I listen to Sirius and I have to manually pause the music when I shut off the car, then push play when I come back. I know I'm being picky, but I'd like to know you're experience.
12-11-2013, 09:16 AM | #84 |
Rep 208
HI,
That depends if Sirius remains the focus music app. If you turn off your car and go about your business and then comeback, you can see if Sirius is still the focus music app by looking at the music buttons and see if it still shows your last song. Your phone will default back to the regular music app which means you loose the last song played on Sirius. Its not an issue with the Tune2Air, its more to do with the phone. Hope that helps. |
12-11-2013, 09:33 AM | #85 |
underground
67
Rep 333
Drives: alpine white 335 E92
So I have a 2010 335, only have aux hook up in the arm rest. What do I need to order. Part number?
12-11-2013, 09:55 AM | #87 |
underground
67
Rep 333
I have a USB in the glovebox, aux in the arm rest. That's all I know.
12-11-2013, 09:56 AM | #88 |
Rep 1,995
