09-22-2022, 04:04 PM | #68 |
Ring Leader of G8X Haters
25265
Rep 8,764
09-22-2022, 04:10 PM | #69 |
Brother
812
Rep 656
Wow. I suppose we truly are entering a new era. I imagine they would use their v6 in this new coupe-variant as an alternative.
09-22-2022, 04:13 PM | #70 | |
25265
Rep 8,764
09-22-2022, 04:19 PM | #71 |
Brother
812
Rep 656
09-22-2022, 06:32 PM | #72 | |
Rep 6,131
Looks-wise this is pretty consistent with AMG in my opinion. They have always been incredibly understated cars. What bothers me here is that the C43 looks 99% identical to the C63 now. With the outgoing model you could easily tell one from the other. The C43 looked identical to a C300 with upgraded wheels.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
AlexFL7926.50 |
09-23-2022, 03:14 PM | #73 |
Rep 3,307
The Merc hybrid setup really is quite ingenious. A very modular setup, they could basically bolt behind any of their ICE powertrains. It consists of a 6kwh battery and a EDU(that houses electric motor, two speed gearbox, lsd). Merc uses the same setup on their AMG GT 63E. Twin turbo V8 and 9G-tronic transmission is conventional, after the driveshaft they add the battery pack/EDU. In the case of the C63E, they added an electrically assisted turbo to the 4cylinder. Definitely a turbo tech that other brands will adopt. We will get a good look at next gen M5 powertrain on Sept 27 with the XM, said to be 25kwh battery pack with the electric motor sandwiched between ICE and ZF gearbox. BMWblog said the XM will come in just under 6,000lbs.
09-23-2022, 03:23 PM | #74 | |
Rep 4,614
09-23-2022, 03:37 PM | #75 | |
Rep 2,357
The graph is of the old CLA45 vs the new one. The engine in the new C63 is based on the new CLA45 but with a bit more power - 350kw compared to the 310kw on the graph |
09-23-2022, 05:05 PM | #76 |
Rep 3,307
We will see what the official number is, right now all that was said was "around 2700kg". Wasn't expecting anything, cars are going to get heavier for the foreseeable future. BMW won't escape the added weight of going hybrid. I'd be surprised if the M5 is under 5000lbs(barring some extensive use of light weight materials). Panamera E-hybrid is over 5000lbs and has a smaller 17.9kwh battery.
