Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board
      04-23-2018, 10:47 AM   #67
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
Originally Posted by jaye944 View Post
In critical moments men sometimes see exactly what they wish to see
The most ridiculous statement I've EVER read.
Sometimes things work 100% of the time. The fact that you quoted Spock on perhaps the grandest blanket statement of all time actually makes it even worse.
      04-23-2018, 11:12 AM   #68
jaye944
Drives: a
Fascinating
      04-23-2018, 11:12 AM   #69
Habs11
Drives: 2015 X5 35i
Originally Posted by Hawkeye View Post
It is actually ridiculously flawed logic... to the point that I thought you were joking originally.
it was not flawed logic - certainly not ridiculously flawed... you just didn't follow it. i provided more detail in a subsequent post. the logic is the solution without all the detailed steps provided later.
hopefully those that didn't get it will understand one of the solutions provided - these types of questions are not only good for the brain but they provide insight into a thinking process. if you've ever done myers-briggs or DIsC or something like that it's very interesting to understand where you fall on the spectrum.... if you don't understand it's not an intelligence thing it's just the way people approach problems.
      04-23-2018, 11:17 AM   #70
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
Fascinating
I felt the same way.
      04-23-2018, 12:08 PM   #71
jaye944
Drives: a
Live Long and Prosper
      04-23-2018, 12:37 PM   #72
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
      04-23-2018, 01:21 PM   #73
jaye944
Drives: a
r
      04-23-2018, 03:24 PM   #74
Hawkeye
Hawkeye's Avatar
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Originally Posted by Habs11 View Post
If you see two blacks, means two whites were taken away, you know you are in white - that didn't happen
True - but this is not the scenario that was presented
If you see a black and a white, means two whites were taken away or a black and a white were taken away - but that didn't happen
If you see two whites, means two blacks were taken away or a black and a white were taken away - know from above that a black and a white were not taken away so two blacks were taken away
This is the flawed part. You can't use a situation not being the case as a reason for the outcomes not being possible like this. You do know that if you saw one black and one white that one option is a black and a white were taken away. That does not mean that NOT seeing a black and a white means that a black and a white were NOT taken away.
So, give me my white car
The logic is flawed, and this question only works if you assume the other two parties have deductive reasoning as well. You could easily be in a black car and if the other two don't deduce that if they were in a black car the third person would know what color their car is.... this whole problem doesn't work.
Your later detailed explanation did a much better job, but your first post (quoted above) was a very flawed argument.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      04-24-2018, 03:09 AM   #75
e92zero
Drives: 2011 E92 BW
Just saw this. It's actually not too hard.
only combinations are as follow assuming you are the 3rd person:
1: white white white
2: white white black
If it's situation 2, person A cannot know what color his/her car is for sure so he/she won't guess to risk losing money. However, person B will know immediately his/her car is white because he/she sees a white and a black. Person B will know for sure his/her car is not black because person A would have given the answer already and won. The only answer left is situation 1 which means you are in a white car.
      04-24-2018, 04:08 AM   #76
jmg
jmg's Avatar
19282
Drives: G82 M4C X-Drive
Originally Posted by PshhhhhMW View Post
The only problem with all this logic is you're assuming the other two share it. With a 50/50 shot, I can see the game ending within the first minute depending on participants.
Not really. Two conditions are presented to give the participants the greatest amount of motivation to think logically, even at the most basic level with more than enough time to come to a logical conclusion:
1) 30 minute window: They are given more than ample to time to think out each scenario.
2) A wrong guess is an automatic loss to the guesser, and automatic win to the other 2. Each person is motivated to be correct and NOT make a 50/50 guess, therefore will run all the logical deductions. The fact that both Jane and Max did not guess within the first 20 minutes means they have thought through the challenge and have deduced that what they see is inconclusive.
2022 G82///M4 Competition X-Drive - KW-HAS, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
Ordered • 2025 ///M2
      04-24-2018, 09:11 AM   #77
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Or they can't figure it out, what if both care more about not buying 2 cars than possibly getting 1? They sit there because not gonna guess.
Hawkeye2064.50
      04-24-2018, 11:59 AM   #78
jmg
jmg's Avatar
19282
20 minutes is a long time to not think about it. Besides, that's not the point of the riddle.
      04-24-2018, 12:05 PM   #79
RickFLM4
RickFLM4's Avatar
Drives: M4
How about a new riddle so this thread fades away?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      04-24-2018, 12:25 PM   #80
TheWatchGuy
TheWatchGuy's Avatar
3929
Drives: 335xi
plot twist, OP is in car #3 and needed help.
      04-24-2018, 12:27 PM   #81
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
A man is found dead inside a car. The deceased has suffered a gunshot wound to the head. There are no bullet holes in the car or the glass. The windows are up, doors are locked, keys in the ignition and no gun found inside the car. How is this possible?
      04-24-2018, 01:42 PM   #82
RickFLM4
RickFLM4's Avatar
Drives: M4
Someone shot him in the head, put him in the car and locked the door with a second set of keys?
      04-24-2018, 02:05 PM   #83
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
Negative. Nothing stated about a second set of keys. Like where your head is at though. I'll PM you the answer but will wait to post it here.
      04-24-2018, 02:17 PM   #84
RickFLM4
RickFLM4's Avatar
Drives: M4
Geez I'm 0-2 and this one is easier than the first.
      04-24-2018, 02:21 PM   #85
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
Try again? What weighs a ton forward but is not backward?
      04-24-2018, 02:30 PM   #86
Red/Red
Guest
n/a
Drives:
Car color
Have a 2011 335d with a red exterior and a red interior. Anyone else have one like that?
Thanks!
      04-24-2018, 03:12 PM   #87
King Rudi
King Rudi's Avatar
13071
Drives: Meat Suit
Thanks!
I'm sorry. I don't think our judges are going to accept that answer.
      04-24-2018, 03:13 PM   #88
RickFLM4
RickFLM4's Avatar
Drives: M4
I think you gave away the answer in the question.
