01-06-2022, 04:01 PM | #67 | |
BimmerPost Supporting Vendor
3596
Rep 6,846
With the fitment you are considering and tire sizes mentioned, I don't foresee any issues at all even with a 200tw tire if you keep your alignment specs with the added negative camber. This fitment is a direct fit with most street tires and the camber will help to tuck in the wider 200tw compound. With the higher rear offset and shorter rolling diameter, you'll have a great rub free track fitment. Let me know if you have any questions. -Ian
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
01-06-2022, 04:33 PM | #68 | |
Instagram: matte_f80_competition
127
Rep 219
With my current setup, the tire model and size are essentially the same as M4 GTS and M3/4 CS so my understanding is that the overall diameter is the same as stock, maybe on the tall side comparing with non-Comp M3/M4. I also understand from some other posts that M3 F80 has less room inside the front fenders comparing with M4 F82. When you stated "I don't foresee any issues at all even with a 200tw tire if you keep your alignment specs with the added negative camber", did you mean you don't foresee any rubbing both front and rear with the target new setup if my current ride height and camber angles (F: -3.1; R: -2.2) remain unchanged? I definitely hope the shorter overall diameter of the target new setup (F: -0.7"; R: -0.5") would be more than enough to compensate its wider width (F: +0.9"; R: +1.1") (remarks: and the higher rear offset).
18' M3 (F80) ZCP 6-Speed - IG: matte_f80_competition
Ind Frozen Dark Grey/M-Perf CF Pkg/MPE/KW CS 2-W/Girodisc+Carbotech/Vorsteiner VFF103 Track: Michelin Pilot Sport Cup 2 F: 265/35-19 R: 285/30-20 Street: Michelin PS4S F: 265/30-20 R: 285/30-20 |
01-06-2022, 04:59 PM | #69 | |
3596
Rep 6,846
Often times when moving to a wider wheel and tire with a lower offset, a slightly shorter tire will be needed to compensate. Even if the current setup is the same diameter as the M4 GTS fitment, the extra width and lower offset cause an issue. Yes the target new setup should work just fine without any rubbing with your current alignment specs. The shorter tire should alleviate the rubbing and the negative camber you have will provide added insurance against any possible fender rub. -Ian
Bon F80127.00 |
01-06-2022, 09:56 PM | #70 | |
127
Rep 219
01-13-2022, 02:29 PM | #71 |
3596
Rep 6,846
BMW F82 M4 with 19" SM-10 Wheels in Anthracite The Flow Formed SM-10 packs high end features typically found only on Forged wheels. Knurled beading, a tough inner lip, I beam spokes and impressive brake clearance make the SM-10 an unparalleled value. Most fitments are in stock and ready to ship today! F: 19x10 ET25 w/ 275/30-19 R: 19x11" ET44 w/305/30-19 Tires: Michelin PS4S
01-20-2022, 01:12 AM | #72 |
127
Rep 219
Hi Ian, further to my previous question, I'm wondering if the wider [COLOR="Green"]19x10" ET25[/COLOR] FRONT wheels fit as well (e.g. better handling, more flexibility to go with even wider tires in the future).
With these wider FRONT wheels: I. I understand that I will need to run 3-5mm spacers at the front too clear my KW Clubsport II. The 0.5" wider wheels will increase the tire section width by ~0.2" III. The tire tread width will probably remain unchanged Given my clearance concern (the [COLOR="Red"]current setup[/COLOR] has a lot of rubbing with the inner fender liners under compression load at the track) is with the tires (I. would have address all clearance concern with the wheels), does it mean the wider [COLOR="Green"]19x10" ET25[/COLOR] FRONT wheels should not reduce any clearance?
01-20-2022, 03:53 PM | #73 | |
3596
Rep 6,846
-Ian
01-20-2022, 05:04 PM | #74 | |
127
Rep 219
My thinking process is that since the rubbing with my [COLOR="Red"]current setup[/COLOR] is with the tires only, with the [COLOR="Green"]target new setup[/COLOR] the wider 19x10" should not introduce more rubbing comparing with the narrower 19x9.5" if the offset is very similar and as long as it's still clear my coilover. Please correct me if I am mistaken.
01-20-2022, 06:24 PM | #75 | |
3596
Rep 6,846
Unfortunately it's really tough to give exact answers regarding the camber spec needed and spacer thickness as it will depend on a number of factors. Some tires run wider than others in a given size and your spring configuration and ride height will also play a role in determining the position of your lower height adjuster and how much inner clearance is needed. Most likely a 3mm spacer will not be sufficient with the 19x10" ET25 and a 275/30-19 track tire due to the KW coilovers. It is however hard to guess and really just requires in person test fitting. Regarding the lower control arms, unfortunately camber gained there does not help with fender clearance as you are essentially moving the bottom of the tire outward rather than tucking the top in (under the fender lip). I recommend getting in touch via a phone call at (925) 264-6438. Our BMW expert Tom can walk you through all these details and more to ensure you get the perfect setup for your application. -Ian
Bon F80127.00 |
02-10-2022, 12:05 PM | #76 |
3596
Rep 6,846
It's Group Buy Season! Don't miss out on your chance to save big on 17" ARC-8s, 18" ARC-8 and EC-7, and 19" SM-10 BMW fitments. Hit the link below to learn more: Click Here to Join Specs: Front - 18x9.5" ET22 and 275/35-18 tires Rear - 18x11" ET44 with 305/35-18 tires Tires - Nitto NT01
06-02-2022, 01:58 PM | #77 |
Boosted
19
Rep 51
Hi! I currently am running stock 19" 437Ms with 255/35 and 275/35 PSS tires with 12mm front and 15mm rear spacers.
I want to get the OEM+ recommended 19" setup on EC-7s. Just wondering with the same tire setup if it would still be flush? Planning to run A/S 4 tires in Seattle area and don't want to compromise traction. Side question: Is there an option where I wouldn't need spacers and still be flush? Want to delete spacers to add some sort of wheel lock. |
Expert@ApexWheels3596.00 |
06-03-2022, 12:23 PM | #78 | |
3596
Rep 6,846
Compared to the stock 437M offsets (19x9 ET29 front // 19x10 ET40 Rear) Our front wheels will sit in nearly the same place as the 437M while our rear 19x10 ET25 wheel will be 15mm more aggressive with no spacers. If you stuck with the 9" front EC-7, you would need spacers to get a flush fit. One alternative would be to use our 19x9.5 ET22 wheel up front instead. This wheel will be 14.4mm more aggressive on the front than the 19x9 ET30s with no spacers required and should allow you to run the 255/35-19s as a direct fit. This combined with the 19x10 ET25 in the rear is going to be your best option from our lineup for a flush spacer-free fitment. -Tom
06-04-2022, 03:53 PM | #79 |
Boosted
19
Rep 51
Sounds good! I'll look into this setup. Would it still be flush if i went 19x9.5 ET22 in the rear? Thinking of maybe a square setup as an alternative option. Or would i need to go 19x9.5 ET25.
06-06-2022, 03:35 PM | #80 | |
3596
Rep 6,846
-Tom
06-06-2022, 06:01 PM | #81 |
3596
Rep 6,846
We have a limited supply of specific tire sizes in stock and ready to ship! If you are interested in any of the tire options listed below, please email expert@apexraceparts.com with “Tire Discount” as part of the email subject. We can provide additional discounts on wheel and tire packages with these tire sizes or in some cases we can make a one-time exception to our standard ordering rules and ship tires without wheels! Please reach out for package and shipping quotes if you’re interested. Nitto NT01 235/40-17 We are not able to order any tires that are currently out of stock on our website. This offer does not apply to tire fitments outside of the above list. We have JRZ Suspension packages on sale, in stock, and ready to ship at stellar pricing for a handful of BMW chassis. This is an awesome chance to upgrade your suspension and dramatically improve the performance of your BMW, while avoiding the typical long lead times. Our entire inventory is shown below. All kits are in stock and on sale anywhere from $400 to $600 off: BMW E46 - 1 left in stock! JRZ RS PRO Double Adjustable Remote Reservoir BMW E9X 3 Series - 1 left in stock! JRZ RS ONE Single Adjustable BMW E8X 1 Series - 1 left in stock! JRZ RS ONE Single Adjustable BMW F3X 3 & 4 Series - 1 left in stock! JRZ RS TWO Double Adjustable BMW F22 2 Series- 1 left in stock! JRZ RS TWO Double Adjustable If you're interested in purchasing a set, send in an email to expert@apexraceparts.com to get in touch or configure your kit on our suspension page.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey Last edited by Expert@ApexWheels; 06-17-2022 at 12:53 PM.. |
06-14-2022, 09:43 AM | #82 |
Rep 19
Hope you guys are doing well!
Could you please PM me a price for a square set of SM-10 19x10 +25 in anthracite shipped to 08816? |
06-17-2022, 12:52 PM | #83 | |
3596
Rep 6,846
-Tom
07-14-2022, 03:02 PM | #84 |
Rep 661
Any GBs running for 18" SM10s?
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 |
07-14-2022, 03:16 PM | #85 |
3596
Rep 6,846
Hi there,
Unfortunately, we do not have any 18" SM-10 Group Buys running at the moment. However, I would suggest following us on social media and subscribing to our newsletter to stay up to date with any future Group Buy announcements we make moving forward! -Geirsen
03-10-2023, 05:52 PM | #86 |
3596
Rep 6,846
APEX | Tax Season Sale: Up to 20% off + Free Shipping* on our most popular designs.
Tax Season Sale Put that refund to work with our Tax Season Sale ongoing now. Save up to 20% off + Free Shipping* on a huge variety of in-stock fitments. Buy Now APEX Flow Formed: Up to 20% off Our most popular wheels. Our original Flow Formed classic ARC-8 and EC-7 wheels and Evolution line SM-10 and FL-5 designs are all heavily represented in this sale. Every diameter we currently produce and a wide array of sizes and offsets are discounted bringing even more value to our most affordable wheel lines. Buy Now Ready to Ship The majority of these wheels are in stock and ready to ship. With No APEX Flow Formed Group Buys scheduled for the first half of 2023, don’t miss this chance to lock in a deep discount with free shipping*. Get your wheels on the way now to make track day planning and tire sourcing easier than ever. Fitment Guides We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. Not the wheels you’re looking for? We’re kicking off Tax Season with a bang. Click here to view our ongoing Sprint Line Forged Group Buys. *Free Shipping to the 48 Contiguous States only. Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
03-21-2023, 03:39 PM | #87 |
3596
Rep 6,846
11-21-2023, 05:03 PM | #88 |
3596
Rep 6,846
Apex Wheels | Black Friday Sale - 15-40% off Forged and Flow Formed wheels
Our biggest sale of the year is now live! Don’t miss your chance to lock in a deep discount on sets of our Forged and Flow Formed wheels as the holiday season kicks off. All our wheels are on sale with huge discounts available sitewide. Free shipping will also be available for all orders during the sale.* Buy Now Our popular Forged offerings at an even more affordable price. Save 15% on the lightest wheels we make including our VS-5RS, SM-10RS, and EC-7RS. 20 - 40% Off Flow Formed Wheels A better value than ever, our Flow Formed BMW wheels are 20% off across the board. From our classic ARC-8s and EC-7s to our Evolution Line SM-10s, there's a perfect fitment out there for every car. In addition to that, our FL-5s will be 40% off as we sell through the remaining inventory on hand to phase out this design. Accessories Caps, Spacers, Studkits, Bolts, Nuts. No matter what you need to get your fitment dialed in, our sale has you covered with a 20% discount on these critical upgrades for your BMW. With a variety of options on offer be sure to consult our Fitment Guides before ordering. If you still have questions, our fitment experts are standing by to help with inquiries, but will be overwhelmed as we near the sale’s end. Beat the procrastinators and reach out early for help with your next set of Apex wheels. Buy Now Need time before you buy? This sale ends on November 30th at midnight PST. *Free shipping to the lower 48 US states Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
