11-29-2007, 12:54 PM | #67 | |
Rep 13,023
If "gone crazy" is the thing, checking all the boxes for audio equipment in this M3 could set you back some $3250 after Sirius, HD Radio and iPod/USB adapter are added. And remember, you need the iDrive to get this Enhanced system... at least $4,000 total, approximately. Damn... So whoever opt for this system better listen to it before ordering because cheap is not going to be, much less if the plan is to "improve" it later with subs or amps if you are not satisfied for any reason... Last edited by Technic; 11-29-2007 at 01:25 PM.. |
11-29-2007, 01:19 PM | #68 | |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
11-29-2007, 03:27 PM | #69 | |
Moderator / European Editor
1552
Rep 6,754
And I still can't believe that you get Power rear windows whereas the Euro cars don't even have opening/tilting rear windows. Does the 335i Coupe have them? Best regards, south |
11-29-2007, 03:41 PM | #70 |
Rep 5,124
11-29-2007, 03:49 PM | #71 |
Reincarnated
245
Rep 4,227
Then I might venture to guess this brochure is still in planning stages and is not final. A couple of options on here don't make sense.
11-29-2007, 03:54 PM | #72 | |
Rep 24
Of course, the rear shade will be available on both. |
11-29-2007, 09:27 PM | #73 |
Rep 1,603
Drives: F80 M3
Yeah, I think the brochure may get edited. After all, the base stereo in the US 335 = Logic 7. Why go cheaper in the M3? Sure, it cuts the base price a bit, but it's tough to think that the upgraded model would have a cheaper base stereo.
11-29-2007, 10:31 PM | #74 | |
Rep 471
That must be why Ferrari uses Magnetic Suspension. There are pros and cons for everything but to dismiss the factory mag suspension and claim that Bilstein PSS9 are the answer to everyones needs is foolish at best. -Adam |
11-29-2007, 11:56 PM | #75 |
Rep 5,124
yeah we were talking about actual power rear windows, not the shades. but yes, the ordering guide says that the sedan has the option for hand operated pull down shades for the rear side windows and, like the coupe, a power operated shade for the rear window.
11-30-2007, 02:57 AM | #76 | |
Rep 10,407
The EDC system in the M3 is not a suspension system "with magnets". It will likely use a set of electronically controlled valves to regulate oil levels and or flows in the shock absorbers (like PASM). Perhaps you are confusing this system with one using magneto-rheological fluids? Even these systems do not contain magnets in the traditional sense but the magnetic fields are created by electro-magnets (simply coils of wire). |
11-30-2007, 10:33 AM | #77 |
Rep 3,288
I agree with what Swamp said about getting out the door at only $54k. Plus the EDC is a great technology that really gives the M3 depth as far as usability and versatility. Would you really want to miss out on that?
However, swamp are you sure about the damper's using oil? I was under the impression that the EDC used the Delphi magnetic dampers. Which would explain how they have variable stiffness that can be changed while driving. This system is also on the Ferrari 599 GTB. It uses iron shavings inside the dampers (shocks) along with current that magnetises the damper. More current would equal a stiffer ride. |
11-30-2007, 10:46 AM | #78 | |
Rep 8,033
11-30-2007, 11:37 AM | #79 | |
Rep 652
Crying is for babies, little girls, men who have just had their ears ripped off, and men who have toasted MDCT's due to service errors.
11-30-2007, 12:50 PM | #80 | |
Rep 10,407
However, in any case the system works by a valve controlling the oil flow, either a coil or direct electrical type of valve. It is not a magneto-rheological fluid system nor does it contain permanent magnets. |
11-30-2007, 12:56 PM | #81 | |
Rep 8,033
11-30-2007, 01:07 PM | #82 | ||
1552
Rep 6,754
http://www.zf.com/content/en/import/...yerContentPage And yes, you're right, it works via a valve controlling/limiting the oil flow. Quote:
11-30-2007, 06:38 PM | #84 | |
Rep 3,288
Man, now I have to eat my hat. I knew I should have bought that straw brimmed hat the other weekend. It would of passed through so much easier.
Just to save face, I've found this article as cached by Google on Oct 31, 2007. Quote:
While the above article is no longer on the actual website, thats pretty much what it said. Their current article posted is this: http://sci-mag.com/art1/art1p3.html Last edited by UltimateBMW; 11-30-2007 at 07:01 PM.. |
12-01-2007, 01:39 AM | #85 |
Rep 493
Drives: '23 M4 G83; '23 M850i
On page 4, it states there is an optional "additional storage box" that is located in the partition between the 2 rear seats. This is only available for coupes.
1. I don't see this listed as an option 2. Anyone know what it looks like, what it is? V/r George |
12-03-2007, 11:51 PM | #86 | |
Rep 57
Depends are where the guy is buying. In Japan, I can bypass the two 5% (automobile) +5% (VAT) expensive taxes but I have to get a $2000, two day rolling chassis emissions test. In Korea, you pay almost no taxes. No gas guzzler, no import, no VAT, no sales taxes. I believe the EU and Gulf countries all have their Status of Forces agreements to avoid certain if not all taxes for US military personal vehicles. Essentially you are treated as a diplomat bringing his own car into the country. If the car is delivered overseas and has xxx miles on it. When the car is shipped into the US after the tour it enters with no taxes and is covered for the duration of the remaining warrantee / service. I've been overseas so long I can't stand the thought of having to pay taxes on a car. I'm looking at MSRP - Military discount + shipping + $3000 in customs / emissions / recycling / weight / engine size taxes. Much cheaper than the $90,000 that the M3's are sold for here in Japan. |
01-19-2008, 05:06 AM | #87 |
Rep 23
DSG?
330i, Sapphire Black, Terra, Black OEM 162s, Colormatched Grille, Winter, Sport, Comfort Access, Premium, Active Steering, I-drive/Nav, Sat, Step.
