08-21-2024, 11:42 PM | #45 | |
Rep 121
2024 M3Cx - Isle of Man Green, Tartufo, CF Exterior & Interior
08-21-2024, 11:46 PM | #46 | |
Rep 19,452
08-21-2024, 11:47 PM | #47 |
Rep 19,452
No, but read the following post. ^
08-22-2024, 02:02 AM | #48 | |
#buildnotbought
12534
Rep 5,260
In most standard torque charts, the difference in tightening torque between an M10 and M12 bolt is roughly 80% (when threaded in steel) And given that the expected accuracy of a torque wrench is 3-4%, I'd say yes, that 'whole wopping 2mm' makes quite the difference. And it's not that you don't remember that the bolt isn't M12 but M10, it's that you don't recognize that 45lbs-ft (61Nm) is a very low value for a M12 bolt (let alone a M14 bolt to quote you further). You don't need 45 years of experience working on cars to get that gut feeling. And naming them grade 10.3 ...what's that? A bolt with 300N/mm˛ yield strength while having 1000N/mm˛ tensile strength?
08-22-2024, 05:36 AM | #50 | |
Rep 19,452
An M10 brake caliper mounting bolt (over) torqued to 94 pound-foot is more likely to fail (break) than an M12 (under) torqued to 44 pound-foot will fail (by backing out of its thread). Noobs have a tendency to over-torque bolts, which break at the time of assembly, or worse the bolts eventually fail due to over-tension. That was and is my point. I didn't see the need to delve into an in-depth engineering discussion to make the point. Regarding torque wrenches, I can point to at least 20 posts of mine over the years trying to explain (to noobs) why the use of click-type 3/8-drive torque wrenches when setting spark plug torque in a cylinderhead is bad practice. But that's a different discussion for a different day... Last edited by Efthreeoh; 08-22-2024 at 10:40 AM.. |
