02-07-2023, 09:51 PM | #45 |
Rep 213
Update: needed new tires installed, and now I’m in search of a boost leak
2012 DCT N55 135i
VRSF chargepipe, JB4, VRSF Downpipe, VRSF 7" Intercooler, Riss Racing Exhuast, Bms Intake, Fuel It Stage 2 Bucketless LPFP |
02-27-2023, 10:29 AM | #46 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
You ever find the boost leak?
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
02-28-2023, 10:26 AM | #47 |
Rep 213
Update:
Found the boost leak, but need to get the wastegate calibrated now.
2012 DCT N55 135i
MLJR235116.50 Eschmacher334.50 |
03-17-2023, 12:53 PM | #50 |
Rep 213
Sorry for the lack of updates, I’ve been chasing down a boost leak and a coolant leak
And I’ve been swamped at work will try and find sometime to get all this done
2012 DCT N55 135i
05-01-2023, 12:40 PM | #52 |
Rep 75
My 2018 M2 on the BM3 STG 2+ e30 map
https://bootmod3.net/log?id=643b41eeae729b6e18f92d5d https://bootmod3.net/log?id=643b41e0d10b430ec6959bbb Last edited by TheSandman_M2; 05-01-2023 at 12:48 PM.. |
05-03-2023, 11:43 AM | #53 | |
Car Hypochondriac
335
Rep 903
05-03-2023, 02:39 PM | #54 |
Rep 75
Ya, thats with the CTS turbo. It pulls pretty good, can't wait to get it custom tuned. I did get a leak on the braided line, the dark stop at the crimp. They had to take the turbo back out to get to it.
2018 M2 with a few mods.
Charge, boost and inlet pipes, Nexsys, Stage 2 HPFP, Stage 3 LPFP, Stage 1 injectors, TC Klines, Phoenix intake manifold, Bend Calibration fuel filter, Turbosmart BOV, PTF BM3 Flexfuel kit, BM3 custom tune, xHP trans tune, CTS Boss turbo, Full SPL, diff bushings, motor & trans mounts Last edited by TheSandman_M2; 05-03-2023 at 02:45 PM.. |
05-09-2023, 04:30 PM | #57 |
Rep 21
Hi Sandman compliments for your ride!! Reading your mod list made me
By conflicting information i mean that on the initial post of this turbo in the forum people started to question the dynographs shared and it seems no one is managing to give dyno results on full boost with this turbo. As you can also see on your first log it takes more than 15 seconds to reach boost target. |
05-09-2023, 08:59 PM | #58 |
Rep 75
Thanks, I think I have a mod addiction problem. Looks like I start it at 3200 RPM and reach target at 3900 RPM. I think that's pretty good, 4th gear. On the other one, 3rd gear, I start it at 2900 RPM and reach target at 4100 RPM. It may have spooled faster if I started at 3200-3400 RPM. Not sure how you get 15 secs to reach target? I'll get more logs when I get it back. I only got the two before I noticed the oil leak.
If you look at my dragy time you'll notice my awesome 60ft. It was spinning pretty good, need to lower my tire pressure. But what's really crazy is the 126 mph, so the cars moving pretty good even with the shitty 60 ft. Here's the same car, same map, VTT GC+ https://bootmod3.net/log?id=64175698c090c6177ea54c40 https://bootmod3.net/log?id=6417562fd10b43bc842239a7 Same Car, custom tune, VTT GC+ https://bootmod3.net/log?id=64173648c090c6177ea54bc1 |
05-17-2023, 06:11 PM | #59 | |
@_sunbish
294
Rep 612
Do you have a IG? You're somewhat local to me, I'd like to check out the car.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
05-22-2023, 07:42 PM | #61 |
Rep 75
They reinforced my manifold, they seem to have a problem cracking. Then the lines are a little tricky, what thay said about my install.
Charge, boost and inlet pipes, Nexsys, Stage 2 HPFP, Stage 3 LPFP, Stage 1 injectors, TC Klines, Phoenix intake manifold, Bend Calibration fuel filter, Turbosmart BOV, PTF BM3 Flexfuel kit, BM3 custom tune, xHP trans tune, CTS Boss turbo, Full SPL, diff bushings, motor & trans mounts |
05-23-2023, 06:16 AM | #63 |
Rep 26
Yea I’m having issues with the lines what did your guy do to get them to work? My mechanic had to heat up one of the oil lines and bend it and the water lines are just not working out.
05-23-2023, 07:23 AM | #64 |
Rep 75
I'm not sure if they fixed the problem on not. The cracks may be on older manifolds and if they say they've updated them, they admit there's a problem. My installer has seen three or four cracked manifolds now. He's putting the same turbo in his car though, with it reinforced.
cesar_m2_Brazil3.00 |
07-24-2023, 11:53 AM | #66 |
Rep 75
Man, didn't you just put it in?
