07-27-2010, 04:01 PM | #23 | ||
Careful, I Bite.....
155
Rep 504
Not a very good explanation. If your max bid is $22.00 and the other person bids $17.00, then your last, automatic bid will jump to $17.50 (not $17.00 as stated above). If they put $20.00 as a max bid, again the last bid will be yours, at $20.50 (not $20.00 as stated above). Here's what eBay says about proxy bidding: Q - What is proxy bidding? A - (From the 'Help' pages) Here's how bidding on eBay works: 1. When you place a bid, you enter the maximum amount you'd be willing to pay for the item. Your maximum amount is kept confidential from other bidders and the seller. 2. The eBay system compares your bid to those of the other bidders. 3. The system places bids on your behalf, using only as much of your bid as is necessary to maintain your high bid position (or to meet the reserve price). The system will bid up to your maximum amount. 4. If another bidder has a higher maximum, you'll be outbid. BUT, if no other bidder has a higher maximum, you win the item. And you could pay significantly less than your maximum price! This means you don't have to keep coming back to re-bid every time another bid is placed. Q - I entered a proxy bid, but I changed my mind and would like to bid more. How do I bid more? A - Simply bid again. You can always raise your bid, you just can't lower it. If you try to "snipe" an item, the other person may have put in a max bid, which will always beat out your same bid, because it was earlier. Also, if you think that everyone who has an excellent record is trustworthy, you'd be wrong. Excellent reviews can also be bought on eBay. Look up "positive feedback" on eBay. Here's what eBay says about bidding: Q - What is the most efficient way to bid? A - A good general rule of thumb frequently given by Answer Center Responders is to: Bid once. Bid the maximum amount you are willing to pay. Bid as late in the auction as you are comfortable...the later the better. Many seasoned eBayers will agree that the most inefficient way to bid, is called "nibble bidding". Nibble bidding occurs when a member bids against another members proxy bid by bidding one increment at a time in an attempt to outbid the earlier proxy. Or, in a reserve price auction.....the bidder will bid in increments in an attempt to reach the reserve price. |
07-27-2010, 05:07 PM | #24 |
Some say...
239
Rep 4,296
Drives: Fresh
Way to be nit picky, Just giving a general explanation with round numbers to make it easy to understand. The idea is the same.
I have exhaust and an intake... |
