BMW X5 and X6 Forum 2014-Current
      04-18-2024, 01:01 PM   #23
agnesgam
Drives: BMW F16
Car has been in the garage for a week now! I am loosing my patients! They read the codes and drove it 3 miles during this week. Today I got an email that I need me transmission for the price of £6500
They did not even check if the ATF lever is correct never mind dropping the oil pan to see how it looks. I am taking my car back. What a waste of time. Going to another garage tomorrow
      04-18-2024, 09:21 PM   #24
m4forum
Drives: M3
sorry for the outcome ... the reality is that some places just want to replace parts instead of fixing the problem.
as I said this sounds an hydraulic pressure issue ... but requires people which knowledge and goodwill to get it done.
hopefully will find one
      04-19-2024, 07:43 AM   #25
agnesgam
Drives: BMW F16
I went to pick the car today from the garage to take it to a different place.
It is unbelievable how fast thia problem progressed! I was told to warm the car up before I start driving it otherwise I have no chance. So I did. Car changed 1 to 2 with a massive delay. Felt like it took @2 sec the jump itself from 1 to 2. Immediately drivetrain malfunction and I have just 1st gear available.
Case is closed now. New gearbox ordered from ZF! £6500 poorer but hopefully that will be end of the matter!
      04-19-2024, 07:58 AM   #26
m4forum
Drives: M3
do you hear any type of grinding/metallic noise which can indicate gear/bearing issues?
At the end was identified the real root cause?
Do they need the core? If not I would be very interested to evaluate the mechatronics of the failed transmission.
      04-19-2024, 08:13 AM   #27
agnesgam
Drives: BMW F16
No grinding, nothing.
Still no reverse!
Car engages drive with a strong kick. Delays shifting terribly. Goes to max 2nd gear and the error come up goes to limp mode and I am stuck on 1st gear.
He said he warmed the car up on idle the other day. Took over 1h to do so. Started driving it and error popped up. He did the reset and car drove fine after that. I asked if he thinks it is down to AFT pressure. He said lever is fine. It looks to him like mechatronics have issue. I had 4 weeks of reading and searching for solutions. All problems related to gears “ gears not plausible” ended up with a new gearbox.
      05-08-2024, 06:21 AM   #28
Transtec
Drives: X6
Hi there. I had the same issue with X6 and I put a good used unit in it and reprogrammed with updated software ,and it still had the same issue after start up ,but after a few days it started to work fine….. till a few days ago where it happened again after 5 months. Is yours fixed with a new unit?
      05-08-2024, 02:50 PM   #29
stocktree
Drives: x5
Must be a wiring or control module issue. Or possibly a sensor giving the wrong info to the control module.
      05-08-2024, 04:25 PM   #30
Chilled
Chilled's Avatar
Australia
371
Drives: F85 X5M
So what is the exact actual issue you are having, did you pull any error codes or just going based on what the mechanic is telling you?
When they got you the used transmission, did they also replace the mechatronic/valve body or just the transmission? The mechatronic is within the transmission but due to coding they could of chose to keep you old unit.
The TCM/mechatronic would/should of been replaces as part of the same transmission replacement with a used unit and the TCM module and the wiring to the solenoids is all infused in plastic.
xbimmers
