03-23-2022, 08:58 PM | #23 |
Rep 1,976
As others have stated, either your post is not clear, or it is clear and IMO you are wrong. If he’s charging you what he quoted that’s that, pay it and stfu. If he trying to charge you EXTRA labor on TOP of the original quote then you are correct and I would only want to pay for the actual labor performed.
Secondly if he quoted you the completed job I’m not sure what the point of putting the labor rate was. |
03-24-2022, 04:32 AM | #24 |
Rep 1,563
My question is did they put enough insulation in to stop the heat loss that's causing the ice dam's Skylights are known leakers just due to the nature, but the kitchen?
03-24-2022, 07:28 AM | #25 |
Rep 1,251
I feel bad for the contractor
TheWatchGuy3907.50 wrickem2137.50 |
03-24-2022, 09:30 AM | #26 | |
Rep 4,857
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
03-24-2022, 10:14 AM | #27 | ||
Rep 615
In the end, what I'm upset about is I agreed to the estimate with the assumption and expectation that it was built upon the quoted $60/man hour. When I see far less labor go into the job than what they estimated naturally that should raise flags. Had I known the estimate was based on a minimum of 8hrs per day per man, I would have never agreed to it, or I would have made sure there was an estimated # of days needed and it was agreed to make the most use out of each day. I feel like I was taken advantage of by not disclosing the 8hr minimum and working such short hours for multiple days. But I have, however, talked with him, and he understands where I'm coming from and agrees the quote should have stated 8hrs min/day and says I'm in the right to question it. He wants 3350 now, and I'll give it to him, and I think we will be fine, but it's a lesson learned on my part and hopefully one learned on his end to make sure he quotes those types of details. And now that I'm re-painting because they just painted a base white I'm seeing how uneven everything is. It's like they used too thick of drywall. But oh well I guess.
F15 35d M Sport (SOLD ) | F30 328i | 2020 Tacoma TRD Pro
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
03-24-2022, 08:01 PM | #28 | |
Rep 39
Drives: 2023 X3 M40i
