05-18-2020, 12:24 PM | #23 | |
Rep 3,156
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
tdott3956.00 |
05-18-2020, 12:45 PM | #25 |
///M Powered for Life
11517
Rep 10,345
Oem ccb calipers take the m2c iron rotors, plug and play
05-18-2020, 12:48 PM | #26 |
Rep 3,997
I don't think so without some custom work, the 6pot caliper from CCB or M2comp would require the 400mm M2comp rotors to be bolt-on.
05-18-2020, 01:09 PM | #27 | |
Rep 3,997
Adding a quote from @Terra on the math for a quick brake bias calculation which shows it's close enough to not matter.
05-18-2020, 01:10 PM | #28 |
Supreme Allied Commander
3895
Rep 54,605
Drives: F80 M3
Did you happen to take any photos of the spindles side by side? I wonder if there are any geometry differences that may positively or negatively affect handling.
tdott3956.00 |
05-18-2020, 02:01 PM | #29 |
Rep 12,318
That's pretty neat. I think the OEM E9x M3 brakes are probably the weakest link of the car. It's not bad per se, but when you get out of say a Porsche, it feels like brakes from a school bus. Also don't find them as confidence inspiring as my stock Z4MR brakes.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
05-19-2020, 08:03 AM | #32 | |
Rep 3,997
SandM36.00 |
05-19-2020, 08:06 AM | #33 |
Rep 3,997
Yes the front wheel bearings are interchangeable. They will require the use of M14 lugs so your existing lugs/studs will not work with the f8x hub. The rear I am not sure about but in theory it should be also, but it's a lot more work to press out the rear bearing to remove the hub.
05-19-2020, 12:39 PM | #35 | |
Rep 1,408
I wouldn't want to switch the rear bearings since they are fine and the process is a bit intense. I'd be running M14 in the front and stock in the rear. Might still be worth doing though. |
05-19-2020, 12:57 PM | #36 | |
Rep 1,271
05-19-2020, 02:50 PM | #37 |
Rep 3,997
Thanks, definitely one of my favorite things. I made sure before buying this house the height in my garage would at-least allow for it even tho it's not enough for a full size lift, the lift has paid for itself several times over. I wish I had done it sooner.
SYT_Shadow11517.00 |
05-19-2020, 02:57 PM | #38 |
11517
Rep 10,345
Lifts are so wonderful... one day I'll have one again
05-19-2020, 03:02 PM | #39 | ||
Rep 1,271
06-09-2020, 03:54 PM | #41 |
Rep 65
tdott,
you mentioned that you got the f80 abs sensor. When you splice to the e92 connector, you just wire the same color coded wired? it is the same number of wire? |
06-09-2020, 03:58 PM | #42 |
Rep 3,997
Yes it's only two wires.
06-09-2020, 09:47 PM | #43 |
Rep 65
06-10-2020, 06:32 PM | #44 |
Dom
1081
Rep 1,722
If anyone is interest, I just removed my 2020 M2C brakes in favor of AP Essex brakes. They had 181 miles of use during my break in period. So they were treated quite well. Send me a PM if interested. Full setup, F/R Calipers, Rotors, Pads and lines plus front heat shield.
